Question about Sharp UX P200 Plain Paper Thermal transfer Fax
Line error I cannot clear line error, please tell me how
  • Hillrock Jan 09, 2008
    When receiving a fax, I get part of it and then I get the message "line error" amd I don't get the rest of the fax.What is the problem?
I was able to solve my "line error" problem by selecting 'Behind PBX' configuration. But I'm using a different printer (Dell A960 all-in-one).
Posted on Jun 08, 2008
Dump the machine
Posted on Oct 25, 2007
What does error code h3-00 indicate?
Sharp ARM 550/620/700 Reset Machine with Error Code ...
? 1:26
www.youtube.com/watch?v=BXs8PmMXFtk
May 5, 2011 - Uploaded by Thomas Trumpler hi thmas please tell me how to clear sharp mx-m620n copiermemory chip to use it ... How do I clear error code h3-00 on mysharp mx--453.
Sep 30, 2015 | Sharp DX-C401 Color Copier, Printer,...
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
Unable to print from computer after router was replaced
Hello and Welcome to fixYa!
Please do make sure that the device is turned On, and the device drivers are properly installed and the cable is plugged in properly...Also do make sure that there is no error message at the printer end... Clear that if any....
If you got an error message or something,do tell me...
Best of luck,,
Please do Rate the solution, if found helpful,
Regards.
Jul 13, 2010 | Brother MFC 8840D All-In-One Laser Printer
ImageRUNNER 3300 All-In-One Laser Printer: PLEASE TELL ME SOLUTION FOR THE ERROR CODE OF IR22...
* 2 8 * ( service mode )
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on
If does not helps replace fixing film assy
May 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Error paper output slot. the paper is jammed clear
Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
Ash
Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Fax machine communication error 43 on kx-f750
communication error 43 is error of telephone line.there is some distarstion in telephone line.some noise in line .due to this it is facing problem.just clear ur line .or check with an other line.by mian jee
Dec 02, 2008 | Office Equipment & Supplies
Error message w/Samsung ML 2150 Laser Printer - Engine LSU Error
Your Laser unit at the top section where the paper exit is faulty. You have no choice but to change it.
Nov 11, 2008 | Samsung ML-2150 Laser Printer
Line error
I have a Sharp UX-300. When I get a line error, the easiest way to clear it is to unplug the fax machine from the power outlet and let it stand for at least a minute. Then plug it back in to the power outlet. If this does not clear the problem, use a regular phone to check if the phone line between the fax machine and the wall is 'OK'.
Nov 15, 2007 | Sharp UX 355L Plain Paper Thermal transfer...
50 service problem
Please try below solution.
ERROR 50 - Service
A 50 service error can be either a temporary error or a permanent problem requiring service.
Temporary Error: Power off for 20 minutes to allow the capacitor on the DC controller to fully discharge. If you don't allow this capacitor to discharge, you will still get a Error 50 even if you have fixed the problem.  This may clear the error - either temporarily or permanently. If it clears the error it was most likely caused by a low power problem  i.e. low line voltage causing the power supply circuits to drop out of regulation. Low/unstable power (low line voltage, brownout condition).  If it doesn't clear the error you may have one of the problems listed below
On the HP LaserJet 4L/4ML, errors are indicated by a series of indicator lights.  This printer has four lights, Paper Jam, Paper Out, Data, and Online.
If all four lights are on, press and hold the blue panel button to display a secondary light pattern.
An error 50 is indicated by the ready and error lights with the blue panel button pressed.
Turn the printer off for 15 minutes to see if the error clears.  If not, you will need to remove the fuser assembly to perform further checks.  This requires removal of the cover, an unpleasant task, and measurement of the fuser terminals.
Note: THERE ARE FURTHER STEPS TO CHECK THE ISSUE, HOWEVER IT IS NOT RECOMMENED TO CHECK USING YOU  ARE A USER, FURTHER STEPS NEED TO BE DONE ONLY IF YOU ARE COMFORTABLE AND INVOLVES MECHNICAL ISSUES OF PRINTER.
For your convienience, I will would like to provide the web link that shows the picture of the scene
link is:
http://www.fixyourownprinter.com/reference/guides/fuser/ex
try the things that are mentioned in web link. If the issue persists, then Printer needs to serviced.
I hope that this should resolve the issue for you.
If you need any further assistance, please let me know. I'll be glad to help you.
Bye.
Oct 18, 2007 | HP LaserJet 4 plus Printer
Sharp UX P200 Plain Paper Thermal transfer Fax Logo
788 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
