Question about Drills
Hilti te 706-avr motor is working but hammur not working
SHEZIL NOT WORKING AND DRILL
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Check selector for right position
Posted on Nov 21, 2012
rowdy45176
  • 2176 Answers
SOURCE: Hilti TE-60 hammer drill
what I would do if you have a fax machine is call 1-800-879-8000 and request a schematic on this tool first. Some of their products are not that easy to disassemble. I never have worked on the TE-60 but have on some of their other products and they are all different. Hope this helps
Posted on Dec 19, 2008
  • 123 Answers
SOURCE: Hilti TE 17 Rotary Hammer repair switch fix
If you are talking about the wire going from the switch to the stator it difficult to get to. You have to remove the motor end cap, cooling fan and handle holding the switch. this will get you to the brush holders. These can be brittle so you need to be carefull. Turn the motor over and tap the end of the armature on concrete checking the brush holders every couple of taps to see if they are coming out of the motor housing. after they clear they will just come out. If you havn't done so already remove the wires going to the brush holders. Your stator will simply slide out after your brush holder comes out. This will give you access to the wires to repair.
Hope this helps.
Posted on Oct 29, 2009
Testimonial: "worked well for me"
  • 61 Answers
SOURCE: I have a Hilti TE 905 AVR the service light came
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Posted on Dec 13, 2009
SOURCE: service light on
Hilti TE 706 is not having any carbon brushes... its a brushless SR motor. this indicator normally comes after 150 working Hrs. and then machine automatically stops to avoid damage of the internal parts.
In this situation it is advisable to send that machine to hilti service center for normal service and oil changing. and at that time service person will reset that service indicator by connecting machine to computer.
Posted on Dec 25, 2009
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
How to stop buzzing sound on hilti te 706-avr
  1. try to pull the trigger more back then its stand free , because i think that a dust ring insite the trigger was come loose and get inside the trigger so it will not fully come back in its normal rest position but its stands maybe a little fraction triggered , replace the switch .
Apr 24, 2015 | Hilti Drills
Hilti TE 905 AVR wont hammer
sounds like it needs a rebuild kit. Hilti.com for parts or to contact Hilti to see if you can get parts. It will also have the parts breakdown.
Feb 21, 2014 | Drills
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Hilti 905 avr starts up slow and uneven speed.
Some of them typically to start up slow. Less wear on the motor. Also make sure you're not using too much drop cord. No more than 100 ft 12/3. May be the brushes if you've had it for awhile. Please rate me
Mar 26, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
I need wiring schematics for hilti te 905 avr
Wiring schematics can be found by Hilti 1-800 number but they probally will not help you. The 905 is programed to shut down for service every 40 hours plus 10 warning. Then in my case I am stuck with a 200 dollar bill to send the tool from Winnipeg to Montreal for reprograming. Its a joke in my situation and its on me from Hilti, what a good name but what a scam.
Mar 14, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Hilti TE-5 does not drill
Check the motor if the motor has power and then the gears are not working. If the motor doesnt have any power then you need to check for power. To get at the gears you are going to need to remove the chuck
Feb 18, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Service light on
When the service light comes on in a normal Hilti all you need to do is replace the brushes,....however on a te-706 there are no brushes to replace, you will need to contact Hilti and have them service it.
Nov 14, 2008 | Drills
Drills Logo
447 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
