Sony KDL-46W40XX/42XX - lost digital channels
Hi there.. I have a Sony KDL-46W4000 european model and i have a problem with it. I receive my TV channels via DVB-C both MPEG2 and MPEG4 channels. It suddenly started to periodically delete all my digital TV channels, and i have been forced to search again, and sort all my channels again. Is there a way to get a firmware update or something? Sony does not send firmware out though the cable TV here in Denmark. Can it be done with a USB stick? And where do i download the firmware? Here's my product information on my TV: 0004324515 B.U-EG-Q-C.T.GG-A.CY.Z Thanks - Mikael
SOURCE: Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Posted on Nov 23, 2008
  • 87 Answers
SOURCE: No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
Posted on May 04, 2009
SOURCE: How to update digital channels correctly
the information I needed was in the FAQ's area. Thanks
Posted on Jun 06, 2009
  • 51 Answers
SOURCE: Digital Visio 42" LCD TV stopped receiving digital TV
Check all your connections in the back, if they're all good replace the main board in the tv.
Posted on Aug 22, 2009
SOURCE: No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Posted on Dec 10, 2009
Using an antenna on KDL-32S5100
No you do not. Your Sony already has a digital tuner. If you are not getting all the channels you think you should, you just need to keep progromming your TV with the antenna at different locations to maximise your signal.
Apr 17, 2012 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
SONY LCD DIGITAL COLOUR TV MODEL KDL 46S2000 - KDL26S2030 - ALL TUNED OK THEN LOST SEVERAL CHANNELS HAVE TRIED RE-TUNING AND CHECKED TECHNICAL SET-UP BUT STILL CANNOT GET BBC 1,2, AND SEVERAL FREEVIEW...
if you have cable and that happens then the tv has a problem in the IF or tunner section.that means the tunner has to be replaced or the IF IC needs to be replaced.if you do not have cable that means you are blocked out.have a tech look at your tv.good luck.
Sep 22, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony KDL-V32XBR1. The turner seems to be having issues. If I scan for channels I only find a few but my other flat panel receives a full range of channel.
U are using a antenna to do a recieving for a Free AIR DTV incomming braoadcasting tv signal channels siganal?Yes.U are using two different tv antennas signals wright?The Sony one just require a stronger and a better antenna signal,not all flat LCD or Plama tvs recieve the same strenghth signals.Some tvs design require a strong or a very strong signals strenght to get all the tv Free AIR DTV braoadcasting tv channels.Buy a better tv antenna design like a Digital amtenna will solved this problems for the Sony tv.
Sep 11, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
I have a Sony Bravia KDL-46V2000 LCD television. I was watching a digital program on channel. All of a sudden the screen frooze and I turn to another channel and the screen display no channel allocated. I...
I have the same problem, the only solution I found so far is to disconnect the TV from the mains supply - not very comfortable. The problem seems to happen more and more frequently.
Feb 08, 2011 | Sony KDL-46V2000 46 in. LCD Television
I have lost digital reception. I can play DVDs and get analogue TV.
You need to make sure your reception is strong enough to receive digital reception otherwise you will only receive analogue reception and dvd playback ability is normally nothing to do with the TV's reception.
Ensure you have strong reception before doing an auto tune to search for the channels. Good luck.
Sep 14, 2010 | Sony KDL-52XBR9 52 in. LCD HDTV
Hi Digital channels lost and will not hold
this is a fault of your digital tuner on the mainboard on some models they can be replaced alone others you may need to replace the whole board
Apr 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Lost all digital channels - Sony KDL-52W3100
Use ur original remote of the tv u want setup to the DTV box go menu switch cable back to air
reseption.Set tv channel 3 hook up the DTV box and rescan the channels u have it.
Aug 15, 2009 | Televison & Video
May 04, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony Bravia does not see my digital channels
Hi buck lite,
Your cable company is telling the truth, you have digital cable. When auto scanned for digital channels the tv is lookig for OTR(over the air) signals. These are broadcast signals you will need an antenna to receive. Depending where you are and the type of antenna you use you probably could pick up some digital channels. Let me know if this helps and please rate this solution. Lone99star
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
