I have DishNetwork for 2 TV I can setup my TV2 Help My Dish receiver is model 625
  • 441 Answers
Tv 2 is a coax connection only, run channel scan to find out what channel (60, 72) common.
Posted on Nov 07, 2012
SOURCE: I have a coby tv but dishnetwork doesn't have a
Try using code 626 or code 633.
Posted on Mar 06, 2011
markevans
  • 148 Answers
SOURCE: Dish Network Remote
not every remote is capable of controlling every unit via remote codes. however, there is a set up in the manual that takes time to use. basically you will use the output from one remote to establish the same output for the new remote. its a step by step process. try a universal remote such as theater master which allows you to use a computer to control functions by assigning them to certain keys. this will be far easier. the mx700 is a capable unit for complex functions on multiple equipment and has a screen to guide you during actual use as to what each key is going to do. you will set up the specifications yourself, such as channel up or channel down, or menu or guide. you get to use already established key locations or choose from 10 along side the screen to state whatever you want, and then after its set up, those buttons do the work you programmed them to do.
good luck
mark
Posted on Dec 24, 2007
roety
  • 585 Answers
SOURCE: How do you setup samsung tv to receive Dish
Hi my name is Roety,
I can help you with your issue ,
If the dish box is connected directly to the TV to the RF connector set the TV to channel 3
If it is TV # 2 you can use 60 or 73 (set also in main TV menu)
Or you can use the AV or component input/outputs/
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Posted on Dec 15, 2009
PhilwithDISH
  • 123 Answers
SOURCE: sylvania tv lc220sl1 trying to hook up with dish
We would be happy to help get your picture back. The first thing we want to ensure is that all connected equipment is on.Check what type of cable is used to connect the TV to the receiver. If you areusing a Coax Cable to connect the receiver to TV1, check the receiver'sback panel for the output name. If your receiver has a "TV CH 3/4Out" (non-ViP Receiver): Tune TV to channel 3 or channel 4, backif it is labeled "Home Distribution" (ViP Receiver): Tune TVto channel 62 or 75. If using non-Coax (RCA, Component, orHDMI) to connect receiver to TV1, cycle through the inputs until pictureappears; Most TVs have a "TV/Video", "Input", or"Source" button. We want to ensure that the TV and the receiverare connected properly, please visit this link to for more information:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. Once we havemade sure everything is connected properly, unplug receiver for 10 seconds thenplug it back in, this will reset the receiver. If we are still not getting apicture connect another component (VCR, DVD Player, etc.) to the same TV, usingsame cable, same input, and same channel to see if it works. If you get apicture with the other component give us a call at 1-800-333-DISH (3474) forsome additional troubleshooting. If it doesn't work with the other componentthen replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Feb 28, 2011
SOURCE: My Dish Network Remote 2
the microprocessor cordinating the functions in your device may be faulty and requires replacement
Posted on Sep 22, 2011
I turned the living room tv on this morning and it is black and white and says no signal. The other tvs are working fine. I have turned it off and turned it back on still nothing
Hi my name is Mike Houston of DISH Network and I see youturned on the living room TV and it was black & white and had no signal.Depending if it's a Dual receiver and if the issue is TV1 or TV2 but there issome thing's you can check to make sure it is on the right channel. I will sendyou two links to help with the setup for both TV1 and TV2, if you have anymorequestions or concerns please e-mail me back at Michael.houston@dishnetwork.com;http://www.dishnetwork.com/SupportSection/bbs-screenand http://www.dishnetwork.com/SupportSection/black-blue-tv2.
Sep 04, 2011 | DISH Network 322 DTV Receiver
Remote for tv2 does not workJsmhmc@aol.com Describe your ViP622 DVR DTV Receiver / 180-Hours Video Recorder Problem
Hi jsmhmc, my name is Mike Houston of DISH Network and I seeyou're TV2 remote does not work. There are something's that can be done to resolve thisissue, please make sure there are fresh batteries in the remote. Please takethe TV2 remote to the main receiver to reprogram the remote, I will send a linkto help with these steps just select the receiver model you have and ourinstructions on setup will appear; http://www.dishnetwork.com/SupportSection/remote-setup.If there are any questions or concerns please e-mail me at michael.houston@dishnetwork.com
Aug 26, 2011 | DISH Network ViP622 DVR DTV Receiver /...
How do i change tv 2 with reciever or remote 1, lost remote 2.
Hi this isMike Houston of DISH Network and I see you have lost your TV2 remote. Until youget your 2nd remote you can put the receiver in Single Mode and putTV1 on the channel you want to watch for TV2 and then put it back in Dual Mode.I can help you in getting your TV2 remote so you can watch TV on both setswithout having to change the Mode setting on TV1, I will send you my e-mail andyou can contact me through there; michael.houston@dishnetwork.com.
Aug 08, 2011 | DISH Network DVR-625 DTV Receiver /...
I own a Dish Network DVR-625 receiver. On TV2, the picture is all fuzzy. I have tried replacing the coax cable and the TV is brand new and picture looks good when connected to another receiver. Could it...
Michlward136,
It does sound like it's the tuner on that receiver going bad, and I can definitely help you get that taken care of. You may need a replacement receiver to be mailed out which I can definitely help with.
Whenever you're ready to get that setup you can reach me at thomas.faust@dishnetwork.com, all I will need is your account or phone # and I can get that setup!
Tommy Faust
DISH Network
May 23, 2011 | DISH Network DVR-625 DTV Receiver /...
When I change the channel on tv2, it also changes the channel on tv1. I have changed the address for tv2's remote, but it still changes tv1's channel.
Hi my nameis Mike Houston of DISH Network and I see your TV2 changes TV1 as well, thereis an easy fix to this problem. You will want to make sure the receiver is inDual Mode and then make sure the TV2 connection on the back of the receiver isin the right port. I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/same-video-2-tvs.I will leave my e-mail if you have any questions Michael.houston@dishnetwork.com.
May 22, 2011 | DISH Network DVR-625 DTV Receiver /...
New jensen jdtv-1020 won't see either air or cable signal as TV2 with Dish DVR 625. An older Emerson color TV sees cable 100 but the new jensen does not see it during auto detect.
Hello, Matthew Gonzales with DISH Network customer service here. First thing to try is putting the TV on channel 73. At TV1, press menu on the remote, followed by 6-1-5 (system setup-installation-modulator setup), make sure that TV2 out is on cable mode, which should default to channel 73. If you're still not getting a picture, try performing a hard reset on the receiver. To perform a hard reset, unplug the receiver from its power outlet, wait 15 seconds, then plug it back in. The receiver reboots (which can take about 5 minutes), then check TV2 again. If there is still no picture, make sure all of the cabling is secure, and bypass any other devices (VCR, DVD player, etc.). If this does not fix the problem, please feel free to email me at matthew.gonzales@dishnetwork.com and I will make sure we get this taken care of for you.
Dec 27, 2010 | DISH Network DVR-625 DTV Receiver /...
I have dishnetwork tv1 reciever is fine and shows tv2 is working but cannot see nothing but a blue screen on tv2. Dishnetwork will come out for 95.00 but the last 2 times they were here(free of charge),...
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on.Wealso need to know what channel your TV2 is currently on, we will do this byturning the TV off then back on and noting the channel or input that appears onscreen when the TV is powered on, if the TV is not on channel 60 or 73, tune to60 or 73. Then Access "Modulator Setup"from TV1 by pressing"Menu", 6 for "System Setup", 1 for"Installation", then 5 for "Modulator Setup". Tune TV2 tothe channel that appears under "TV2 Out" on screen. If stillno picture and the mode for TV2 is "Cable", change it to"Air" and change the channel on your TV2 to 60, if it is already on"Air" then change it to "Cable" then change TV2 to channel73. If the issue is only on ONE receiver, unplug the DISH receiver for10 seconds and plug back in. The next thing we want to check is the connectionon the back of your receiver labeled "Home Distribution", this cablecarries the picture all the way to your TV2. Start by removing the connectionand screwing it back in, make sure all the connections going to your TV2 arehand tight. These steps should get your TV2 up and running.
We want to thank you for being a valued DISH Network customer!
Phillip Chang
Oct 02, 2010 | JVC AV-27530 27" TV
Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
Jan 11, 2010 | DISH Network DVR-625 DTV Receiver /...
How do i use the ant. passthrough on tv2 in dual mode w/ dish dvr625
ANT. passthrough for an ant. connected to your 625 receiver will only work on tv 1. The only way to do this is to RF modulate your tv 2 coax to an RCA and hook the RcA cable to your tv2. then use another ant. to connect coax allowing you to pick up dish programing on an input and then going to the channels to enjoy local over the air programming.
Nov 26, 2009 | DISH Network DVR-625 DTV Receiver /...
Hi,my brand new UHF remote wont operate the #2 tv??
Go to the tv 1 location with your TV2 remote. Turn TV1 on and using TV1's remote press menu-menu. You will be at the System Info Screen. Take TV2 REMOTE and press and hold the SAT button on the top left until all buttons on the top light up. Release the SAT button. Now key in a two digit number from 1to 16 and press the # key. The SAT button will flash three times. Now press the record button until the remote address for TV2 changes to the number you chose. When accomplished exit out of the screen with th TV1 remote and you should now be able to control TV 2. As a precaution ensure the remote antenna is on the back of the receiver. If you still have difficulty it may be required to move the remote antenna closer to TV2. I hope this answers your question. Thanks for using Fix Ya and let me know if I can of further assistance.
Dec 12, 2008 | DISH Network DVR-625 DTV Receiver /...
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
