How to 'connect to network' using Dongal (AN-FW100) and LG 50 PZ570 TV
Have 50" Pz570 plasma 3d smart tv and Wifi dongal but shows network setting: None Network status: Not connected Can not find how to connect.
SOURCE: USRobotics USR5461 - WiFi local network intermittently available and unable to connect
I've been having the same problem where even hard wiring to the router won't work. I called USR and they had me reset to factory defaults. Now three days later, the same behavior is happening. I reset to factory defaults and it works again but I don't know for how long. Maybe these things just wear out after a while...who know.
Posted on Apr 20, 2008
Tanker944
  • 12 Answers
SOURCE: LG Incite: Connect to a multiple-user WiFi network
To enable or disable Wi-Fi
  1. Choose Start, choose Settings, choose the Connections tab, and then choose Wireless Manager.
  2. Choose the Wi-Fi button. If it is turned off, the button will appear as a lighter color and display an icon marked with an "X".
  3. Choose Done.
clear.gif To set up a Wi-Fi connection
  2. Scroll to Wi-Fi and press ENTER. The device will detect available Wi-Fi networks.
  3. Select the network you want to connect to, and then choose OK.
  4. Select Internet or Work, and then choose Connect.
    If you select a secure network, you may have to enter a network key that is provided by the network administrator.
clear.gif To edit a Wi-Fi connection
  2. Choose Menu, and then choose Wi-Fi Settings.
  3. Scroll to the connection that you want to edit, choose Menu, and then choose Edit.
  4. Make changes as needed, and then choose Finish.
clear.gif To delete a Wi-Fi connection
  3. Scroll to the connection that you want to delete, choose Menu, and then choose Remove Settings.
clear.gif To change Wi-Fi settings
  2. Choose Menu, choose Wi-Fi Settings, and then choose the Wireless tab.
  3. Scroll to the connection that has the settings that you want to change, choose Menu, and then choose Edit.
  4. Change any of the following information:
    • In Network name, enter a name for the connection.
    • In Connects to, select The Internet or Work.
    • If the network is a hidden network, which means that it does not broadcast its Service Set Identifier (SSID), select This is a hidden network.
    • If you want to connect directly to another device or computer, and not to a network through an access point, select This is a device to device (ad-hoc) connection.
  5. Choose Next.
  6. On the Configure Network Authentication screen, do the following:
    • Select the authentication and data encryption methods.
    • Enter the network key information or select the The key is automatically provided check box.
      If it is necessary, ask the network administrator for authentication, encryption, and network key information.
  7. Choose Next.
  8. Select or clear the Use IEEE 802.1X network access control check box.
  9. To use Extensible Authentication Protocol (EAP) or smart card authentication, make the selections appropriate to your choice of authentication.
  10. Choose Finish.
Posted on Aug 05, 2009
SOURCE: new LG Wireless USB dongle connected to new LG
onyour computer you must install the nero home network disk that came with the tv or it will not work.
Posted on Feb 13, 2011
  • 172 Answers
SOURCE: Problem with setting up a wireless connection
Looks like, you are installing in vista or Windows 7..Sometimes in these OS , it needs elevated privilages..Try to enable in Network connection by clicking RIGHT CLICK on network icon & run as Administrator privilage..OR try to install with Administrator privilages...I hope this will work
OR if there is driver problem,,Try to download drivers from the below link
http://homesupport.cisco.com/en-us/wireless/valet/AM10
Please rate & vote if you like solutions
Thanks
Sandeep
Posted on Mar 13, 2011
  • 11800 Answers
SOURCE: I'm trying to connect apple
Invalid format means that the signal coming from the Apple tv is in a format your tv can't support - there is nothing you can do in the tv to fix that: the tv searches thru all the formats it can display automatically, if it can't recognize it it gives that message. You will have to connect the Apple TV to the tv set using the analogue connectors - the round, colored RCA ones - they send an signal that is recognized by all tv's.
If your unit is the newer model, without the RCA ones, then you must change the resolution: from the manual
1 Press and hold both MENU and + on the Apple Remote for about 6 seconds.
2 Press + or - on the Apple Remote to cycle through the display resolutions.
3 When Apple TV reaches an acceptable display resolution and "If you can see the Apple
logo, select OK" appears on your TV screen, press PLAY.
Posted on Apr 28, 2011
How do I connect to wifi?
Setup menu - WiFi - LAN - Network if this does not work try going to web browser to get an error message.
Samsung 3D LED Smart TV Setup menu WiFi LAN Network
Mar 14, 2016 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
How to connect to WiFi
go to settings and then wifi,,,,,dongleblack!! lol
May 16, 2015 | LG 50-Inch 1080p 3D THX Smart Plasma TV...
Why is lg tv frozen on lg lifes good screen
may be tv firmware has corrupted please contact lg customer care for technical support
Jan 01, 2015 | LG 50PM6700 50" 1080p 3D Slim Bezel Plasma...
LG 50 inch tv keeps switching on and off
I'm afraid the power supply is defect, or just any "intelligent" device is generating the IR codes to switch it of and on. Could be an old laptop or a smart phone, with a program to remote control other devices.
Oct 07, 2014 | LG 50-Inch 1080p 3D THX Smart Plasma TV...
I need to connect to wifi using a dongal
is this a question or a statement?
I once used a wireless to wired ethernet dongal to hook up a tivo to trick it into thinking it had a wired connection because it wouldn't stream saved content to the sub-boxes in a total home dvr setup over the wireless.
It worked, true story!
Nov 16, 2013 | Humax HFA100 DTV Receiver
Micromax cdma2000 HSIA Modem is not connected please help me about this modem
I am not able to connect with reliance SMART INTERNET SIM . WITH My micromax CDMA2000 HSIA MODEM Dongal !!
Please help !!
Oct 24, 2012 | Computers & Internet
Can't get sound to work with RBG cable from PC to TV
Sound will not work with mere RGB connection. The audio out of the PC should be conected to Audio in socket to TV.
May 02, 2012 | LG 50 50PZ950 50 3D Plasma TV
Can,t access or read my emails tells me that
my lapto problem is network adapter and wifi and vga drive pleas help me iam living in iraq
Feb 22, 2009 | Dell Inspiron 1150 Notebook
Televison & Video Logo
Top Televison & Video Experts
