Question about Dell Computers & Internet
Dell laptop boot problem
Hi, i have dell laptop cant boot to windows, when i start windows it says internal boot hard drive is not found, even i removed hard drive then reseated again , but still telling same, any solution?
  • Mike Nov 07, 2012
    Does the hard drive show up in the BIOS?Do you have another laptop you can use to test the drive?Do you have another hard drive you can use to test the computer?Do you know the model of your laptop? (e.g. Inspiron, Latitude, XPS, Studio XPS, or Studio followed by letters/numbers)
  • Dell Master
  • 7,627 Answers
Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally. IF THAT FAILS, reboot while tapping F-8 or what ever will get you to an options list or Boot Menu, my laptop is F-10 for Boot Menu, for example.
Posted on Nov 07, 2012
CptOblivious
  • 5 Answers
SOURCE: reseat the hard drive
shut down the laptop.
then, disconnect the laptop power, and battery.
remove the harddrive, then connect the harddrive firmly back into place.
reconnect power/battery and boot.
Posted on Mar 25, 2009
  • 7 Answers
SOURCE: how to reseat the hard disk drive
If the HD has never been removed it is unlikely it needs reseated. You need to go into the BIOS (press F1 during start-up) and see if the HD is visable under the drives section. If it is not then it is dead and needs replaced. Data recovery may be necessary if you need anything from it.
However to reseat it, turn the laptop over and there are two screws that come out to slide the HD out from the side. Pull it out and then push it back in firmly and replace the screws.
http://support.dell.com/support/edocs/systems/latd630/en/SM_EN/index.htm
Posted on Jun 07, 2009
computus
  • 487 Answers
SOURCE: have a Dell Inspiron 1525
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Posted on Aug 04, 2010
WinstonMeyn
  • 141 Answers
SOURCE: when i turn on my
This seems the Hdd is Not getting Detected , First thing you can try is inserting the hdd back in the system and then get into Setup Utility by Pressing F2 and check whether the hdd is listed or not , If the HDD is not listed that means HDD has gone bad .you need to get a new HDD
Posted on Aug 29, 2010
  • 12 Answers
SOURCE: opened laptop to find '
Please make sure if you open the back part of the laptop check the Harddrive if it is firmly connected. bacause it is possible that the reason why the laptop doesn't detect it is because of the physical connection.
Posted on Oct 01, 2010
Password protected
If it is the hdd password, nothing to be done just purchase a new hdd. Windows password? there are programs on the net that will remove it.
Mar 22, 2014 | Dell Inspiron 2200 Notebook
I installed a new internal hard drive in my Inspiron 1750 laptop. I am getting a No boot sector on internal hard drive error. How do I get it to boot up and get recognized?
Have you installed the Windows OS on the new HDD? Insert the new Windows OS in the DVD rom drive, shut down, Unplug, remove battery, plug in, at boot the new OS DVD should start and ask Press any key to boot from CD/DVD, tap key.
Feb 03, 2013 | Dell Inspiron 1750 Laptop
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
Dell inspiron 1525 shows black screen after dell logo?
The computer cant find a bootable device. Either your boot sector on your Hard drive is gone/damaged (most likely a virus) or the Hard drive failed. Start with booting with your windows disk and try to do a repair installation.
Nov 03, 2010 | Dell Inspiron 1525 Notebook
Can i boot from usb
I'm sorry but the answer is no.
You only have floppy, hard drive and cd-rom options. With some Dell models the USB is seen as a secondary hard drive from within the BIOS so maybe (if your bios supports it) you can change boot order there.
Usually thats not the case so you mainly have to boot from the CD/DVD to install or run a DOS or linux command.
Regards.
Feb 09, 2010 | Dell Latitude C600 Notebook
Boot from non Dell raid controller
Check the Boot Sequence again -- if there are any "SCSI" devices listed, enable them, and make your CD-ROM the "primary" boot-device (so that you can install Windows) and make this "SCSI" device the SECONDARY boot-device, and disable the internal hard-drive, so that it won't be used as a boot-device.
Dec 27, 2009 | Dell Computers & Internet
Windows Failed to load because Kernel file is missing
try pressing f8 when you load vista and then select start normally
if that doest not work and gives you the same error then restart and press F12 as soon as you see the dell logo, put in the vista installation disk that you got with the laptop and select boot with disk option.
try and repair or the recovery option .
NOTE : IT IS RECOMMENDED TO TAKE BACK UP OF YOUR FILES BEFORE USING THE RECOVERY OPTION .
May 17, 2009 | Dell Inspiron 1521 Notebook
Reseat the hard drive
Mar 25, 2009 | Dell Computers & Internet
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Problems booting into windows xp
If you can not boot into windows yyou can try to do an inline repair of windows
Please refer to this web address http://support.microsoft.com/kb/315341/ to get a better understanding for what is an inline repair.
Nov 15, 2008 | Dell 160 GB 7200 RPM SATA Internal for...
Computers & Internet Logo
189 people viewed this question
Alun Cox
