Question about Refrigerators
I have a Kenmore fridge model 596.72912200 that came with the townhouse I just bought and moved into this Saturday. The ice maker worked fine until today, it has stopped making ice. I tried lifting the arm to stop it and then put it back down, it did not work, still no ice. Also, it has started making this noise like a creaking sound today too. Both fridge and freezer are cold as they should be. How do I get the ice maker to start working again, and what is happening with the creaking noise and can I make it stop? Thank you so much for you help. The creaking is ongoing...
  • 19 more comments
  • Sheila Kanekoa Nov 07, 2012
    No it does not, it just has a wire arm like thing on the side. There is a sticker on the front that says something like raise are to stop lower to start. I am at work right now so I don't know the exact wording. I can see a plug and wire in the inside back of the freezer, it seems to be plugged in all the way.
  • Richard Roth
    Richard Roth Nov 07, 2012
    OK, and is all the food frozen really good in the freezer?
  • Sheila Kanekoa Nov 08, 2012
    yes, it is all rock hard
  • Richard Roth
    Richard Roth Nov 08, 2012
    Is the "creaking" coming from the ice maker? Also, touch the bottom of the ice maker to see if it is hot. The heater that is on the ice maker may be stuck on and if that is the case it will not allow water to flow into the ice maker. Be careful when you touch it in case it is hot. It will burn you for sure. Post back your results.
  • Richard Roth
    In the mean time, we will start with this.
  • Richard Roth
    Whirlpool icemakers have a motor modular mounted on the front of the icemaker with holes marked V, L, H, T, M and N.
  • Richard Roth
    These are test points to make Whirlpool icemaker repair easy.
  • Richard Roth
    To access this modular simply remove the cover off the front of the icemaker. To check this icemaker you will have to make a jumper wire. Take a six-inch piece of insulted wire and skin about 1/2 inch on each end.
  • Richard Roth
    Now before you proceed, look in the ice mold (where the ice forms). Is there any ice in it?
  • Richard Roth
    Yes - If there is ice in the mold take that jumper wire and place one end in the hole marked T and the other end in the hole marked H for about 15 seconds then remove it. If when you do this the icemaker dumps the ice in the mold and the feeler arm lifts up and then back down, the thermostat inside the icemaker is bad (provided the temperature in the freezer is ok). Note that I recommend changing the entire icemaker if the thermostat is bad.
  • Richard Roth
    If when you do this ice still will not dump, the motor modular is bad and needs replacing. If it dumps but the feeler arm will not lift up and then back down make sure the feel arm hasn't jumped out of place, it should be inserted in a hole on the back of the icemaker head.
  • Richard Roth
    If there is no ice in the mold take that jumper wire and place one end in the hole marked V and the other end in the hole marked L just long enough to see if water enters the icemaker then remove it.
  • Richard Roth
    This should power up the water valve and water should enter the icemaker. If when you do this water doesn't enter the icemaker, look inside the tube that enters the back of the icemaker to bring water to it and see if it is stopped up with ice. If so remove it, clean all the ice out of it and replace the water inlet valve. If its not stopped up with ice, replace the water inlet valve.
  • Richard Roth
    If when you do this water does enter the icemaker take that jumper wire and place one end in the hole marked T and the other in the hole marked H for about 15 seconds. When you do this, the icemaker should go through the cycle, the feeler arm should lift up and the water should enter the icemaker. If all of this happens the thermostat inside the icemaker is bad and you need to replace the ice maker.
  • Richard Roth
    Let me know how all that goes. Sorry about all the post but FixYa only allows so many characters in a post.
  • Richard Roth
    Here is the ice maker to order in case it is badhttp://click.linksynergy.com/fs-bin/clic... The part comes with a 365 day, any part, any reason return policy.
  • Richard Roth
    thank you for your help! it is not hot, and the creaking seems to be coming from somewhere in the fridge more than the freezer. I don't have any wire to make a jumper wire, so I will have to go to City Mill tomorrow on my way home from work to purchase. I will let you know how it goes. Is Kenmore made by Whirlpool? I ask because the fridge/freezer I have says Kenmore on the outside not Whirlpool. Thanks again for you help!
  • Richard Roth
    Yes, Kenmore is made by Whirlpool. If you need to read the whole test procedure for the ice maker, please go to my website athttp://appliancecafe.com/phpbb and signup for the forum and then go to the ice maker section for the complete procedure. That way I won't flood this post with all the steps. Keep me posted!
  • Sheila Kanekoa Nov 13, 2012
    Hi Richard, I finally had time to get to Home Depot... your suggestion worked and I have now have a working ice maker. Thank you!!!
  • Richard Roth
    Richard Roth Nov 13, 2012
    I'm glad I was able to help you. Thanks for using FixYa!
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Does your ice maker have the on off switch on the front of it?
Posted on Nov 07, 2012
Testimonial: "Richard was a great help!"
ronaldo_ross
  • 1056 Answers
SOURCE: Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Posted on Jun 28, 2009
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
  • 531 Answers
SOURCE: Maytag refrigerator ice maker, pouring water out where ice should
change ice maker or check defrost
Posted on Apr 06, 2009
  • 9 Answers
SOURCE: freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Posted on Jul 09, 2009
  • 193 Answers
SOURCE: ice maker and water stopped working, hear a
the sound from the icemaker is coming form the water solenoid valve, which needs to be replaced. if your frezer is cold then the fan is fine, most are switched to turn off when you open the door so you arent likely to see it running unless you set up a camcorder in your fridge :-)
Posted on Aug 14, 2009
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
I have a side by side Kenmore fridge, model# 106.53532300. The ice maker has stopped making ice all of a sudden. Everything else works fine.
Ice makers do go bad and it is inevitable. Check the ice maker connection and make sure that all is in order. If all seems okay and the ice maker does not work, replace it.
Dec 19, 2010 | Kenmore Refrigerators
Bought floor model of Kenmore 79737 fridge - it is in display mode (lights on no cooling) kids at store cannot tell me how to switch off manual does not address
My fridge did the same thing. I was told to:
Hold either one of the fridge doors open and press the fridge temp and ultra ice buttons simultaneously for 5 seconds. The temps came on and the fridge started working.
May 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge & Freezer won't get cold, but air is blowing
Is the compressor in the lower back working. You may short of gas . have it regassed
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Side by Side not making ice
This problem is most likely the water control valve on rear of refrigerator. If your ice maker is empty pour tap water inside it and let it freeze. If it dumps the ice then the water control valve. If nothing happens the the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side fridge - ice dispenser stopped working
You might check out this site and ask a question. They have drawings on many of the fridges and I have bought many parts from them.
http://www.appliancepartspros.com/partsearch/
Jul 28, 2009 | Refrigerators
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore fridge ice maker not working
only two things this could be, either your water valve is bad or your icemaker is bad. you can get a kit which comes with both for a little over a hundred bucks, and you can change them yourself.
Mar 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
276 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
