Buzzer do not stop in samsung washing machine
Last 5 minutes buzzer makes sound but in my case my machine sound do not stop until i off from the main switch and on the very next day buzzer again starts buzzing pls help me
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 07, 2012
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
  • 1073 Answers
SOURCE: Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Posted on Apr 21, 2008
SOURCE: washing machine buzzing
buy a new washing machine
Posted on May 18, 2008
SOURCE: samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Posted on Jun 27, 2008
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
We have moved house and plumbed in our machine and code 5E has come up Any ideas what is going wrong and how to fix it
The '5E' Error is displayed when the water is not draining properly from the Washing Machine. If the water does not drain in 15 minutes, a buzzer will sound , and the remaining time indicator will show '5E' Error. You can perform following steps to resolve the issue : Clean the debris filter.
Jul 13, 2017 | Samsung Washing Machines
My machine is showing se
SE also comes up as 5e
? Clean the debris filter.
? Make sure the drain hose is not clogged.To make it unclogged, Detach the drain hose from washing machine. Attach the spray nozzle to the end of the hose. Aim the sprayer into the clogged washer hose and spray water kinetically down the hose. Continue spraying until the hose is no longer clogged.
? Make sure the drain hose is not frozen.
? Make sure the drain hose is installed correctly.
Dec 16, 2016 | Washing Machines
How do i fix miele w1113: stopped with oversudsing; buzzer sounds; "intake", "drain", "- - -"
the pump is not running when it is in a cycle, just when the machine is forced into a drain and spin. we have a bad drain pump motor and possible a bad board or main control. http://ww2.justanswer.com/uploads/jgrella16/2011-09-22_041351_w1100_w1200_ti_112304.pdf
Jul 28, 2014 | Miele Touchtronic W1113 Washing Machine
When i start my washing machine E9 appear and buzzer sounds indicating a problem
when i start my washing machine buzzer automatically start
Feb 24, 2011 | Washing Machines
Hi my washing machine lights are all flashing, it does this a lot and it lasts from minutes to days, when it does this the washer will not do anything at all until it stops wen its ready. any ideas?...
This is fault in the main controller board and so it shows up as a error. So best to check your main printed board which houses the micro-controller unit. check for moisture or faulty capacitors or loose joints or connections.
Feb 02, 2011 | Washing Machines
How do I stop my bosch washing machine beeping at the end of the wash cycle?
If the machine is still under warranaty contact seller and get it fixed; if you do something inside, like disconnecting something yourself, your warranty will be invalid for further work. If its out of warranty get teh wiring diagram on line and isolate part making sound/buzzer, experiment taking wring connectors from spades. If machine is ok with them disconnected, which I would assume, then you have solved it. If not insulate or perforate sound maker/buzzer to lessen noise
Dec 07, 2010 | Bosch Washing Machines
2008 Samsung front end loader develops a 4E error
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Jul 12, 2010 | Samsung WF337AA Front Load Washer
My samsung washer is broken it reaches the last 5 minutes and than i have 5E flashing at me and it stops
5E is a water drain error so either a blocked filter, blocked outlet or faulty pump...
Dec 17, 2009 | Samsung Washing Machines
Error 4E + timer countdown is delaying
Sep 02, 2009 | Samsung WF337AA Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
