Question about Fargo DTC550 Thermal Card Printer
HOW TO SOLVE A HOPPER JAM PROBLEM - Fargo DTC550 Thermal Card Printer
  • BEN NKANSAH Nov 07, 2012
    STILL NO ANSWER TO MY QUESTION
Canon ir 8500 papper jam code 020E
E020-0000 : The hopper connector is left disconnected. The hopper motor (M9/M10) is faulty. The toner sensor (TS1/TS2) is faulty. The DC controller PCB is faulty. During printing, the toner supply signal is '0' (absence of toner) for 2 mins.
Jun 05, 2016 | Canon Office Equipment & Supplies
Canon ir c2550 error code e000025-0001
Dear
The error code indicates the toner is not supplying for (Y). The hopper motor is locked. The probable cause the sensor is not detect within 5sec. when motor is on at hopper assy. Check. the sensor,clean-replace,check the jam of motor gears,check the harness up to DC con board, check the DC con board.
Thanks.
Jan 14, 2015 | Canon Office Equipment & Supplies
Sticky back card static causing them to stick togeather and not feed from the hopper
Hello Richard,
Sorry for the delay in replying to your request.
Feeding cards (especially self-adhesive types) from the rear hopper, can sometimes be frustrating. You have done the right thing by separating the cards (this applies to all cards - just fan down both sides like a dealer would with a pack of cards). This important.
Please try the following additional trick though;
Remove the rear hopper.
On the front panel, select Menu -> Test Card -> Yes (to confirm).
The rear hopper roller will start to rotate.
Take a fresh cleaning card (from the cleaning kit - 3633-0053) out of its wrapper. It MUST be damp.
Fold it into a loop and manually hold the cleaning card against the hopper roller as it turns (with gentle hand pressure). The idea of folding the cleaning card is to prevent it from being accidentally dragged into the rear of the printer.
After about 12 seconds, an Out of Cards 02:00 error will be displayed. Press Retry.
Turn the card over and repeat until there are no Black marks left of the cleaning card. Repeat as necessary moving to a fresh part of the cleaning card each time.
If the card should accidentally go too far into the printer, a Card Jam 06:05 error will be shown. Just open the lid, and close it again to clear the card jam error. The sequence will carry on from the previous stage (the hopper roller will start turning again shortly after closing the lid).
Once you are happy the roller is thoroughly clean, on the next Out of Cards error, press Cancel.
Discard the cleaning card which will probably have dried out by this point. Replace the rear hopper.
Card feeding should then be trouble-free.
If the problem should persist, contact your local Magicard support centre.
Kind Regards,
MC.
Nov 21, 2013 | Magicard Rio Pro Single Sided Photo ID...
Coo and 70 code with the wrench light on, do not see any paper jam
the toner hopper motor is not turning, you need to strip it out then clean the hopper.
Oct 01, 2013 | Minolta DiALTA Di183 Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Paper jam and give code C0070 at the screen. Model Minolta 4000
Hi this is a standars problem you will need to take apart the back of the toner hopper where the toner goes in the drive motor or worm gears will be damaged and will need to be replaced or the motor some times you just need to clean around the sensor toner hopper sensor and it will fix the issue
Feb 25, 2011 | Minolta EP4000/5000 CS/PRO Copier
In which direction do you turn the barrel to make finer coffee?
HI
Clockwise is the direction for making the grind finer, but make sure that the machine is running at the time you turn the hopper. If its not running, you trap beans under the burrs and jam the motor, which could do damage. There are numbers on the bottom of the hopper, but they are just a reference to go by.
Jul 29, 2009 | Rancilio (RAROCKYND) Grinder
Hi i have fargo dtc525 card printer i am using that printer scince 1 year, now not working error massage HOPPER 1 EAMPTY this type of message showing please tell me solution.
hopper 1 empty means that you do not have any cards in it. The printer has 2 hoppers, and your program maybe defaulting to hopper 1. Select hopper 1 and cards to it and that should solve the problem.
Nov 30, 2008 | Fargo DTC525 ID Card Printer
Card hopper jamming
Could be that your cleaning unit is not installed or is old. Or, it could be too few cards in the card hopper. You could apply a little weight to the cards in the hopper to see if that helps. And/or try changing out the cleaning cartridge.
Oct 04, 2008 | Fargo DTC520 Thermal Label Printer
Fargo DTC550 Thermal Card Printer Logo
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
