Question about HP Photosmart C6180 All-In-One InkJet Printer
C6180 Black ink does not print We can hear the head moving,
And sonds as though it is laying down ink, but comes up blank. Same document prints perfect when we change the font color.
  • Prince1111 Jan 06, 2009
    exactly the same problem for me, all other inks work but not the black, it seems that it's printing and making all the right noises but no black. I have changed the cartridge twice to check that first!
  • kiljoy Jan 07, 2009
    I too have the same problem, admittedly I tried to use a substitute ink but going back to genuine replacement has not worked
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Blank paper comes out when print is pressed
Can you hear the print head moving??
If so then ink has run out OR is dry in print head, go into Printer software and locate "printhead clean".
If print head is not moving maybe fault internally.
Mar 23, 2010 | HP LaserJet 1015 Printer
Black ink will not print on Photosmart C6150; Ink
I'd do the reboot of the printer.Turn it off,unplug for 60 seconds,plug it back in,turn it back on and see if the black will work.After plugging back in it should clean the print head and then you can do a test page to make sure.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00728224&cc=th&lc=en&dlc=en&product=1153494
This site will show you how to print a test page.
Jan 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Will only print color even though there is black ink left...If I set it to print with black ink, blank pages come out. I know there is black ink left so why doesnt it print when I set it to print black??
Hi Mel,
It sounds like your print head could be blocked or the black cartridge has gummed up.
Have you tried taking the black ink out, put a rag over the hole where it would normally come out (carefully as it could go all over you) and gently shake the cartridge, then replace it back in to your printer.
Try printing in black and see if it helps, if not then i would be quite sure that its the print head, if this is the case then the only way would be to contact HP as I'm not sure if its possible to remove the print head or even if HP supply replacements.
I hope this helps a little
Mike
Sep 26, 2009 | HP DeskJet D2560 InkJet Printer
C6180 failed alignment test, will not print color properly
All colors need to be present to pass alignment. Usually what I see is the yellow is empty. You can blot the print cartridge on a damp paper towel to verify the inks are working and this also cleans the head.
Jun 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
My HP Photosmart C6180 All in One printer is not printing ing black even though I have replaced the black ink. It will print the colour sections but comes out blank for black. Any suggestions as to what...
Remove the black cartridge from the all-in-one and clean the copper contacts of the cartridge with a soft cotton cloth and then try to align the cartridges once and then try to print the self-test page. Also check the ink level and expiry date present on the cartridge.
May 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Print head moves but no ink is delivered
try cleaning nozzles.
Mr.Musculo is very helpfull - put the print head in warmed solution (35 grad.celsius)
Jan 09, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Both colored & black ink tanks are new but nothing comes out
I have had this problem before. Try removing print head and cartirdges. get warm water in bowl and swirl head in water until water remains clear. Need to empty and refill water a few times. Pat dry with absorbent paper. Re-install head and cartridges and do a clean.
Dec 27, 2007 | Canon i80 InkJet Printer
Big Black not printing
Sounds to me your print head is plugged up. This is not usual though because the majority of people use black ink much more. So, in your printer utility, do a deep cleaning. If that does not work, there is a thing called a purge unit in it. This is a usual way of draining waste ink to a pad that soaks it up. if the hose, or other parts are clogged, it backs the ink up and causes the print head to clog. If this is the start of it, do not waste your ink cleaning, and try not to let it sit too long. Contact canon, and let them kno what you think it is.
Oct 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
