Hp Printer P1008 Engine Scanner Error How this Problem Sort Uot
5 Suggested Answers
  • 169 Answers
SOURCE: HP Laserjet P1008 not Printing
What you need to do is go to the printersmenu in the control panel and then see which printer is set as the default printer.If the selection is correct,see if any documents are pending in the print queue or not.If it still does not solve your concern then your printer has taken up an IP address that is no more recognized by your computer.So you need to change the port to which the computer is printing.If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz.
Posted on Jun 19, 2009
sandimcp
SOURCE: Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Posted on Sep 01, 2010
  • 3 Answers
SOURCE: hp laserjet p1008 printer sharing print command
Which OS is this? If its on Windows 2003 or 2008 server then using the print management console as opposed to the start > printers option should resolve this issue. Print console can be found under admin tools in the start menu
Posted on Dec 07, 2010
  • 102366 Answers
SOURCE: hp p1008 printer drivers download for red hat linux
You may download the driver here.
Posted on May 15, 2012
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
My 1005mfp HP printer scanner error 20 how I
Hp are tricky scanners to install and setup. You need to unplug the USB cable, power on the scanner and begin a fresh setup.
Let the software tell you when to reconnect the USB cable to the computer. Let it finish setup and reboot computer. Once in windows, the setup will complete automatically.
Go in START menu and click on the HP Solution Center in the HP folder to activate the scanner.You can't jsut press the SCAN button on the scanner. It won't work. You need to start the software first or use Photoshop.
Also, the way to fix this Error 20 is to first ensure that your HP Printer is set up to be the default printer on your PC. It's often the case that the printer you have on your system will either not be the default, or will have some sort of error that will prevent it from being properly used. You should click onto "Printers & Faxes" on your system and then right click onto your HP Printer, and select "Set As Default". This will allow your PC to use the printer every time you print,removing some confusion.
More Help... HP LaserJet Error Codes and HP Printer Support
Thanks,
Sep 19, 2014 | Office Equipment & Supplies
HOW TO SET HP LASERJET 1005 PRINTER SCANER ERROR 12
how to solve engine scanner error for hp laserjet p1005
Oct 10, 2010 | HP LaserJet M1005 All-In-One Printer
Hp laserjet 3055 has code 52 scanner error and wont print or copy
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Jan 15, 2010 | HP LaserJet 3055 All-In-One Printer
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    52 scanner error
    HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
    HP LASER PRINTERS 2, 2D, 3, 3D
    1. Defective cable laser scanner to dc controller.
    2. Defective laser scanner assembly.
    HP LASER PRINTERS 2P, 2P+, 3P
    1. Bad scanner motor.
    2. bad dc controller.
    HP LASER PRINTERS 3SI, 4SI, 4V
    1. Faulty cable assembly.
    2. Scanner motor problem.
    3. Defective laser scanner assembly.
    4. Defective dc controller.
    HP LASER PRINTERS 4, 4+, 5
    1. Faulty laser scanner cable.
    HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
    1. Temporary error. Scanner startup failure.
    2. Improperly fitted scanning assembly.
    3. Scanner cable problem.
    4. Defective laser scanner assembly.
    5. Defective dc controller board.
    HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
    1. Temporary error. scanner rotation error.
    2. Replace contact image sensor.
    4. Replace laser scanner.
    5. Replace cables to laser scanner and engine board
    HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
    1. Scanner start up error
    2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
    3. Replace scanner ***'y.
    4. Replace the engine board.
    5. Replace the D.C. controller only on the 8000.
    HP LASER PRINTER 2300 ERROR 52.X
    1. A temporary scanner start up error.
    2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
    3. Replace the scanner ***'y.
    HP LASER PRINTERS 4200, 4300 ERROR 52.XX
    1. Printer scanner speed error has occurred.
    2. Replace laser scanner ***'y
    3. Replace the D.C. controller ***'y
    HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
    1. Error code K - No Black Color.
    2. Error code C - No Cyan Color
    3. Error code M - No Magenta color
    4. Error code Y - No Yellow color
    5. Replace laser scanner ***'y
    6. Replace the D.C. controller ***'y
    HP LASER PRINTERS 5000, 5100
    4. Replace cable ***'y from scanner to D.C. controller.
    HP LASER PRINTERS 8100, 8150
    1.Laser scanner error/start up/rotation error
    2.Replace laser scanner ***'y.
    3.Replace D.C. controller board.
    4.Replace cable ***'y from scanner to D.C. controller
    HP LASER PRINTER 4500, 4550
    1. Temporary error. Laser scanner error/start up/rotation error
    2. Replace laser scanner.
    3. Replace D.C. controller ***'y
    HP COLOR LASER PRINTERS 4600, 5500
    1.Laser scanner error/start up/rotation error.
    2.Take the toners out and reseat them, or replace them
    3. Replace laser scanner ***'y
    4. Replace D.C controller board.
    HP LASER PRINTER 8500, 8550
    2. Replace laser scanner motor.
    HP LASER PRINTER 9000
    1. Temporary laser scanner error/start up/rotation error
    3. Replace upper cable guide assembly.
    4. Replace DC controller.
    Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
    148 people viewed this question
    jasbo
    jasbo
