Question about Sewing Machines
Want to no how to use a semco 83 co sewing machine
Just bout one an have no idea how to use it
CAN YOU PLEASE HELP ME WITH YOUR OWN IDEAS?
the first idea would be to have you include what it is you wish ideas about.
Jan 24, 2015 | Sewing Machines
Repairing timing on New Home sewing machine
Yes there is. Ebay has a few, if not too many, options for sale.
http://popular.ebay.com/sporting-goods/altimeter-watch.htm
Jan 31, 2013 | Sewing Machines
Do you have any idea about a manual for cascade sewing maching
nope... no ideas. You might have better luck if you can find the manufacturer
Dec 06, 2012 | Sewing Machines
The hand wheel will not turn. I have no idea what happened, got any ideas?
Usually it is a bit of thread stuck in the raceway area, take the raceway and bobbin case out and have a good look.
Apr 09, 2010 | Singer 1120 Mechanical Sewing Machine
Machine just won't stitch, any ideas?
resest the needle depth and check the timing to insure the bell crank is allowing the needle to reach deep enough into the bobin housing
Jan 20, 2010 | Sewing Machines
Husky 55 chainsaw
All chainsaws are air cooled. The problem is the cylinder head often sits underneath the gas tank. People fill their tanks with a mixture of gasoline and oil and often spill it or overfill the tank causing that oily mixture to coat the cylinder often. Then all the saw dust and dirt sticks to the oil and pretty soon the cooling fins on the cylinder head and all the parts surrounding it are coated with an oily dirty grime that keeps air from circulating around the cylinder head letting it cool normally. I'm not that familiar with a Husky but you need to be careful about other parts in the area, but you need to clean off the cylinder head so that it can get some cooling and quit heating up the gas in your tank. Usually there is a vent in the gas cap also and if it's plugged it will cause the gas tank to pressure up and force more gas than is necessary into the carburetor. Either clean the vent or buy a new gas cap.
Apr 23, 2009 | Husqvarna Viking 1
Sewing MAchine Problem
redo the bobbin, maybe its backwards.
Jun 23, 2008 | Kenmore Sewing Machines
Error E-1 in Servo drive
what sewing machine is it? (make/model)
Jun 21, 2008 | Sewing Machines
Sewing Machines Logo
945 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
