Question about Acer Aspire 3003LCi Notebook
Adding memory My Aspire3003LC has got 256MB DDR memory. I've got my hands on some extra but need to know how to install it. Before I reach for my screwdriver can I get some advice as to where I need to put it?
  • Rosemary Power May 23, 2007
    I'm 100% sure the memorys right. Thanks for the advice!
    Genius:
  • 2,985 Answers
General advice. under the base there is a flap with a large slot screw. your manual should tell you how to do it. Or seek help from the Acer Tech Support. Are you sure you have the correct memory?
Posted on May 22, 2007
I want to upgrade my processor and memory on my acer travelmate 4000. I currently have an Intel Pentium M 1.5GHz 496RAM processor. I have 2 memory slots each containing 256MB type DDR PC2700, DDR...
I suggest adding 2X 1GB DDR PC2700 memory sticks. Crucial also recommends it, but as long as it's only 1gb thats DDR PC2700 per stick it's compatible, so you can shop around if you like and choose the cheapest.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Computers & Internet
I want to know which memory to buy for my pc. I checked it on crucial.com and it said I could upgrade to 1gb. When I looked inside the cover I saw a 256mb memory chip but could not see how many slots it...
hello, here's a part of the spec from the hp website. It looks like you've got 256mb on board memory and one expansion memory slot in which you can fit a 1024mb card, giving you a max memory of 1280mb (1024+256).
Hope this helps!
nicam49
Hardware
Product Name zv5410US US Product Number PR465UA#ABA Microprocessor 1.8GHz AMD™ Athlon™ 64 Processor 3000+ with PowerNow!™ Microprocessor Cache 1MB L2 Cache Memory 512MB DDR SDRAM (2 x 256MB) at 333MHz Memory Max 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB) Video Graphics NVIDIA GeForce 4 440 Go Video Memory 64MB DDR (dedicated) Hard Drive 60GB (4200RPM) Hard Drive Diskette Drive External USB Floppy Drive available for customers via hpshopping.com or local retailers
Jan 11, 2011 | HP Pavilion zv5410US Notebook
Adding computer memory
The only thing you could do is put in a 256MB module in the slot that you have access to. Only one socket is user upgradable. The second socket is only upgradable by a Dell service center. They would have to install a second 256 module to get you to the 512MB max.
Jan 22, 2010 | Computers & Internet
I have a Easy Note M5 280DW and would like to know if I can upgrade the RAM?
Standard Memory 256 (256MB x1 Removable) Maximum Memory 1 GB The standard memory of your system is 256 Mbytes and the maximum memory it supports is 1 Gbytes.
So you can either upgrade the RAM by adding 1 stick of 256 Mbytes (for a total of 512 MB) or buy two sticks of 512 Mbytes each (for a total and maximum memory of 1 Gbytes).
You are looking for PC2700 DDR Memory.
In any case, check the memory you have installed.
You can download a free utility like CPUZ that will give your information about your system, including the number of memory slots available and used and the memory (amount and type) installed: http://www.cpuid.com/download/cpuz/cpuz_152_setup.exe
Aug 03, 2009 | Packard Bell Computers & Internet
Want to replace 2x 256mb of memory with 2x 512mb of memory into my hp compaq presario v4000
Hi there.
Yes you can upgrade the memory to 2 x 512MB DDR SDRAM memory.
You will be pleased to know that the system supports up to 2GB DDR SDRAM memory (2 x 1GB)
Please be gentle when installing the new memory taking care to remove the battery and the mains power from the laptop first before installing.
Have fun and thanks for using FixYa!!
Mar 24, 2009 | HP Compaq Presario v4000 Notebook
PC Motherboard Memory upgrade
From Asus tech: Memory 3 184-pin DIMM slots for PC1600/PC2100 DDR SDRAM
Supports up to 2GB memory
No ECC supportThis is only compatible RAM so make sure your new chip is PC1600 or PC2100. If you mis the 2 it the faster RAM will run at the slower chip speed. Hope this helps.
Feb 20, 2009 | ASUS P4B266 Motherboard
Adding memory to tx pro mainboard
You do not say what memory you are trying to install.
The ASUS P4S800D motherboard has four memory slots that hold DDR PC2700 or DDR PC3200 with a maximum of 1GB per slot, so the installed maximum is 4GB.
DDR memory is generally available in 128MB, 256MB, 512MB and 1GB modules. If you already have memory installed, it must be at least 128MB so you cannot add modules to 'bring memory to 128'.
Either you have a different motherboard and posted in the wrong section, your memory calculations are wrong, or you have used older PC-133,PC-100 or PC-66 memory instead of DDR. The last is unlikely as older SDRAM has two notches and won't physically fit into a DDR slot that only has one notch.
Please re-post with the specific motherboard model just to confirm and a list of the memory modules you are trying to use.
Jan 01, 2009 | ASUS P4S800D-X Motherboard
SAMSUNG 1GB RAM 400MHZ PC3200
RAM has to be
Four 184-pin DDR DIMM sockets
Supports PC3200 (400 MHz) /PC2700 (333 MHz) / PC2100 (266 MHz) DDR DIMM type
Maximum HP/Compaq approved memory module is 1 GB
Maximum HP/Compaq approved memory is 4 GB
It has to be the same.
• If you are replacing a memory module, put the
new memory module in the same memory slot
from which the old memory was removed.
Or
• If you are adding a memory module, install the
new module into the socket nearest the
preinstalled module, and install additional
modules in the next available sockets
Jan 14, 2008 | Computers & Internet
Acer Aspire 3003LCi Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
