Question about Sport & Outdoor - Others
Pitching instructions for the executive 320 tent
3 Suggested Answers
SOURCE: I need pitching instructions for
Jim,
these are the instructions I devised as I had no instructions either...
Great Outdoors Executive 320 tent
Two rooms plus a fully enclosable veranda.
(4.9m long x 4.3m wide x 2.4m high)
Main Tent Assembly :
Lay the tent out on the ground (making allowance for the slope of the ground, prevailing wind, general access, etc).
Peg down the main corners and centres of each wall, keeping the tent square and evenly tensioned. Peg down remaining loops.
Assemble two sets of side support poles. These have been numbered (from the front, looking towards the tent (ie, facing the veranda)) :
Left-hand side : L1, L2, L3, L4 & L5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports LF1 & LF2 and LB1 & LB2 (ie, 2 sets of poles 5 & 9).
Right-hand side : R1, R2, R3, R4 & R5 (corresponding to poles 1, 24, 3, 4 & 1).
Add front & rear supports RF1 & RF2 and RB1 & RB2 (ie, 2 sets of poles 5 & 9).
Place poles in the loops along the sides ensuring that the 4 brown loops (at each end of the sides) are looped behind the projecting studs (this ensures the sides don't slide into the centres.
Lift & tension one side, then the other.
Assemble the centre poles (numbered C1, C2, C3, C4, C5, C6 & C7 (corresponding to poles 12, 13, 8A, 24, 3, 4 & 8)).
Slide the centre poles through the centre of the tent. Use poles 14A & 15 to hold up the rear of the tent, poles 14A & A in the centre, & two further sets of 14A & 15, one set at the front of the tent & one set for the veranda. Tension by expanding the poles.
Assemble poles A, BE, C2, BE & A through the centre of the tent, clip onto ridge poles & tension. (Note : poles A should be inserted from the outside, through the elasticised holes before being inserted into poles BE).
Attach a guy rope to the rear of the tent (top of centre pole 15) & tension.
Veranda Assembly :
Assemble 4 sets of poles (10 & 30) & place in corners & centres of the veranda. Attach guy ropes & tension. Attach veranda walls (using Velcro strips).
Porch Assembly :
Select which side is to be an entrance. Unzip the window covering & use two poles (10 & 30) to lift it. Tension with 2 guy ropes on each pole.
hope the above helps.
Warwick Annear
annear@xtra.co.nz
Posted on Dec 31, 2010
SOURCE: I am trying to purchase
hi there, i have one for sale if you are still looking for one, yes they are the largest they made internal maesurements are 14' x 16' plus an 8' awning. please email me at eskape2@hotmail.com
Posted on Oct 29, 2011
Need instructions on assembling 2-5 person house shaped tent
House shaped tent is not an adequate description to make erektion suggestions.
Broadly speaking tents are divided into categories of dome, tunnel, ridge, bell or frame.
The ridge tent is sort of house shaped and the classic frame tent also, though this is usually referred to as a bungalow or perhaps chalet tent. None of these types peaks in the centre of the top and neither does a house, usually.
A small marquee peaks in the centre of the top and is also vaguely house-shaped but it seems somehow unlikely you have a small marquee..
It is also important to know whether there is an inner and an outer tent or flysheet and a sewn-in groundsheet, single pole, ridge pole, frame, fibreglass rods or perhaps an A frame.
I can't advise much without knowing what sort of tent you have but I advise you to practice, practice, practice and colour code or number each pole assembly. Bad weather when pitching for the first time is too late to be trying to read instructions and wondering which pole section goes where.
I also advise taking extra pegs and guy ropes in case of accidents or really foul weather. Tents are provided with minimum equipment for moderate weather pitched on hard packed loam type ground.
For different types of ground; sandy soil or rocky different designs of pegs are available and should be used along with heavy stones or sandbags. Double pegging is also advisable in some circumstances.
Preparation and attention to detail is the key to a successful camping trip. No extra precautions often turns a simple camping trip into pure misery. I once camped at the top of a high cliff when bad weather was expected. I double-pegged and fitted extra guy ropes and slept right through a gale while my companion laid awake petrified. The tent never moved but in the morning we were the only campers left on that part of the site.
May 11, 2016 | Sport & Outdoor - Others
Tip
HOW DO I PUT UP A TENT
Don't panic if you've never pitched a tent before. It seems scary when you first get started but with a bit of practice you will be doing it within minutes.
The most important thing is to practice putting it up before you go on your camping trip. There's nothing worse than the sun setting and no light left around you as you struggle to pitch your tent.
Here are my tips to help you get started: Make sure the area where you want to put your tent is clear, without any rocks or big bumps underneath, otherwise you won't be comfortable.
Don't pitch your tent on a low lying ground. If it rains - your tent site will be flooded.
To protect your tent you should lay a groundsheet down as tents can be damaged by punctures and moisture. Now take out the poles and insert them into the proper sleeves of the tent. The instruction manuals are usually pretty straight forward and helpful. Place both ends of the pole in the metal rings and the poles with flex as the tent begins to take shape. Straighten the tent by pulling the material straight and making sure the poles are stretched taut to the outer point. Now secure the tent into the stakes at the corners. Make sure they are really firmly in the ground so they can resist wind and being knocked into.
on Aug 20, 2012 | Camping, Backpacking & Hiking
Where can I find all the pvc joints for a magellan yukon 20x9 tent
  1. Ten Minute Tent: Magellan Yukon 20x9 Family Camping ...
    ? 10:42
    www.youtube.com/watch?v=r3gtkzAi8cA
    Mar 23, 2011 - Uploaded by HLujan45
    Mr., Tent and Darlene pitch a large family camping tent. theMagellan Yukon. Clear, simple step-by step ...Missing: pvc ‎joints
Jul 19, 2015 | Camping, Backpacking & Hiking
Hi I'm ddesperately trying to find instructions for a tent we just bought which is a Cantera 9. Would you be able to provide this for me please?
I have never seen your tent but found these instructions online. Hope they help:
Erection / Pitching
This tent pitches inner first and uses the popular ring and pin method to locate the poles on both the inner and outer and takes two to erect. The poles are all colour coded making it very easy to identify which poles go in which sleeves. The inner uses six poles to hold up, three for the main living area and one each for the bedroom pods. Once all poles are threaded, its advisable that one person gets inside the inner tent and supports the main poles as they are located. Tip here and for most tents of this design, make sure the first pole you locate on the main living area is the pole on the bottom of the crossover at the top of the tent, this then takes the weight of the poles above making it easier to secure. Locate the main poles and then the bedroom pod poles using the ring and pin system. The inner tent will then require pegging down and this takes around twenty pegs to secure. Finally once the inner is secure the outer flysheet is pulled over the inner, tied on the main poles and then finally pegged. The final thing to do is to locate the two porch poles and secure with the ring and pins and then peg out the guy ropes.
http://www.365campingcaravanning.com/reviews_familytents_1.htm
Also perhaps this video will give you an idea of what it is supposed to look like when it\'s up. https://www.youtube.com/watch?v=7SyVVIXV7l0
Good Luck!
Jul 24, 2014 | Sport & Outdoor - Others
HOW TO PUT A TENT UP
Hi I have the full instructions for pitching the Lichfield Condor Family Dome tent with 2 bedrooms if anyone wants a copy happy to email it :)
Jun 16, 2013 | Sport & Outdoor - Others
Set up lakefield 10MAN TENT 2000 FRAME
Sorry I'm very late to the party, but I was just looking for the instructions for my own Lakefield 2000 tent which my bro borrowed some time ago. It's a great family tent - but not that straightforward to pitch. Eventually the instructions turned up, so I'm posting them for some other poor soul who's really stuck!61ec3342-f228-41d3-895c-127c2c5ffe3b.jpg
Jan 17, 2013 | Sport & Outdoor - Others
I need pitching instructions for a Great Outdoors Apollo 4 man tent
Take out all poles and stakes and tend and seperate.. First lay tent on ground and streatch out where you wish to pitch the tent. Then take stakes and place them in the four corners of tent through the loops so ththat when you hammer in the stakes the tent is nice and stretched out tightly. There should be two more loops on each side int the middle. When the tent is secure to the ground, take the poles that should have been put together and feed them through the hoops of the tent on the sides and top. Leave the top center parts of poles apart until you have poles through rest of loops and attatch them at the top of tent. front, back and center usually work pretty good for order. Doint middle last because it is the highest point. Hope not too confuseing. I camped a month every year for many years. You never forget.
Dec 23, 2012 | Sport & Outdoor - Others
I am trying to purchase a sunshine leisure executive 320 tent for the family I was told that the executive 320 was the largest sunshine tent, so I thought I would scan the net where I found you.
Jan 13, 2011 | Sport & Outdoor - Others
I need pitching instructions for a Great Outdoors Executive 320 tent. Can anybody help please?
I recently borrowed a similar tent and this forum was all the instructions I had (so thanks, they helped). I have since found the instructions, scanned them and made them available to others (to view/print/download) at https://docs.google.com/open?id=0B1SdA-vKLONwZ05vTGZKdF9BTzQ
Paul.
Dec 23, 2010 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
539 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
