Question about Compaq Presario 5304 (120969-004) PC Desktop
Have a compaq 5304, and it will not boot up, it acts like it then it goes compaq page and continues to redo that until I shut it off
    Problem Solver:
  • 7 Answers
Your pc is re-booting, the quickest way to solve that prob. is to restore the pc, (hope you have or made the restore disk.) just insert the cd into the drive and re-boot. follow the on screen instructions to restore your pc.email me at arjoon.ken@gmail.com and let me know if you got it going.
Posted on Jan 05, 2009
Continue reboot loo
There are a lot of possible reasons for this.
1. Fan is bad.
2. Motherboard has gone bad.
Do you still see the Compaq logo when you turn it on?
David
Jun 10, 2013 | Compaq Presario 700 470024-192 Notebook
Compaq presario 5304 boots to desktop,but nothing is on my desktop
If you are not a screen after the computer boots up.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
Hope this helps.
Dec 01, 2012 | Compaq Computers & Internet
How to reset sanzo zio phone
WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
8. Allow the phone to completely reboot. This may take a few moments.
9. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
Dec 02, 2011 | Sanyo Cell Phones
Would like to know how you access the setup menu or BIOS
I believe that you want to press the F2 button as soon as you turn it on, and keep pressing it until the BIOS setup screen comes up, If F2 doesn't work then try F10
Apr 04, 2010 | Compaq Presario 5304 (120969-004) PC...
Laptop wont boot on, it starts but turns off again
I'm guessing ou have windows XP?
if so you hae a corrupted regisry and need to boot from your Windows CD and at he first et of questions choose Eneter to intall windows, then F8 to continue and then it should tell yo another Windows insatallation has been found and ask if you wish to perform an automatic repair.
Give it a try and enjoy :)
Jan 22, 2010 | HP Compaq Presario CQ50-210US Notebook
When we start up the computer It boots up to the point where the desktop appears briefly. Then the screen goes blank/dark and nothing else occurs. If shut down it will strat up and get to the desktop...
You may want to try boot into SAFE MODE.
Do this by pressing F8 repeatedly until you are offered boot options by windows.
select SAFE MODE and continue on. Note this may take longer to boot and is normal.
when it goes into windows it will ask you if you want to continue so click yes.
If you have recently installed any programs esp. toolbars then you should use the ad/remove programs to delete them.
Also if you have antivirus AND antispyware now would be an ideal moment to let them go to work.
Now try a reboot.
Aug 24, 2009 | Compaq Computers & Internet
My compac boots up ok but when im using the pc one of the web pages goes blank(white) and acts as a screen saver. cover the entire screen. covering all icons and margins. just a white screen..even when i...
i have the same problem,also bought new hp for grandson and it to has problem, tried hp help did no good, only cure i found is to hit desk button on keyboard and programs open and on the task bar it will show windows blank page and you can double click and close blank page. hope this helps. robert
Jun 27, 2009 | Compaq Computers & Internet
How to enter bios presario 5304
When you are starting up the PC, keep jabbing the DEL key for the BIOS screen to appear......sodeep
May 16, 2009 | Compaq Computers & Internet
Compaq armada e500 boot up
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there which will prevent the continuation of the unsuccessful boot routine. If you can reach the Safe Mode, run Restore and go back to an earlier point in time, you may have to go back several times because if you have picked up some kind of malware, it may have been backed up with everything else.  Unless it is a really smart bug, you might be able to circumvent it.
Aug 22, 2008 | Compaq Armada E500 Notebook
Compaq Presario 5304 (120969-004) PC Desktop Logo
145 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
