Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG front door washing machine gasket, how to replace it ?
It leaks, seems to be a common pb with LG's.
  • onthethejob1
    onthethejob1 May 11, 2010
    i can help you take it off but not you will never get it back on without the lg spring removal tool..let me know...onthejob
How do i replace the door seal on my intello LG washer the old one is torn
Posted on Dec 19, 2009
How do i replace the door seal on the LG F1443FDS washing machine
Posted on Sep 24, 2011
Washer is dripping water at the front when filling and washing
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution.It is possible that water can leak if there is gaps on the front door gaskets and must be checked for damaged gaskets which can give poor sealing of the door. So in this case the leak will happen more during the cycle and not on the drain cycle end.
check this video to see how to replace the door gaskets.
http://www.espares.co.uk/advice/washing-machines/a/7/1397/how-to-replace-the-door-seal-on-a-washing-mac.html
Jul 30, 2011 | Kenmore Washing Machines
The rubber gasket around the drum opening is leaking and rusting
You can replace it by lifting the lip of the rubber around the edge and finding the wire where the springs connect there you can stretch the springs apart, remove the wire and pull off the rubber. Just make sure first that is where the leak is, sometimes a leak in the soap dispenser water tube can seem like door gasket leak.
May 16, 2011 | LG WM2277H Front Load Washer
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
Common causes
door gasket damaged(torn)
Dispenser fault
Lint filter door not fully closed
It sounds like you might have a damaged outer bowl, broken by a foreign object(coin, wire,screw)
Mar 25, 2011 | LG WM-2277HW Front Load Washer
LG front loading washing machine. SEVERE water leak from front door. Gasket has been checked and is OK. Seems there is quite a bit of 'play' (i.e. slack or free movement) in the front door since if you...
This is a very common problem with the LG front loaders, and some other front loaders for that manner. There was a few recalls on them and some parts that were supposed to fix the issue. Even if the gasket looks ok i would replace it, as they have updated the design of the gaskets to fix issues on models that were having issues leaking. Most of the time its just a bad gasket and you cant really do anything other then replace it. Front load washers are about the worst appliance made today in my opinion, the repair shops around here are always full of broken and leaking front loaders. I have fixed quite a few myself, some work ok after the repair, some fail again in a matter of months, its a real duck shoot on them. The biggest failure rate though is the gaskets! And most of the time they look ok but still leak like a screen door.
May 04, 2017 | LG WM-2077H Front Load Washer
My LG front loading washer is leaking at the door.
carefully check gray door gasket fot tears/waves/stretching on outer edge. if so, replace gasket. be sure gasket and door glass are clean where surfaces meet.
Apr 28, 2010 | LG WM2688H Front Load Washer
Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
Jan 03, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Leaking water
If your LG washer is a front loading machine, the bellow or gasket may need to be replaced. this is a common problem with front loaders as the bellow can be pierced by anything that may be in or even on your clothes. I would visually inspect every inch of the front bellow to see if there is a TEAR or PIN HOLE. this can be hard to detect sometimes but can save you alot of grief. hope this helps
Thanks
Oct 11, 2009 | LG Washing Machines
LG Washer leaks from front door
search the parts stores on internet then check ebay i find many times the common parts such as door gaskets can be had cheaper on ebay
Sep 29, 2009 | LG WM-2277HW Front Load Washer
Gasket around the door
HAVE NEW DOOR GASKET, HOW DO YOU GET FRONT OF MACHINE OFF?
Jan 30, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
2,469 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
