Question about Garden
Stihl chain saw ms170 starts and runs then dies
  • 205 Answers
SOURCE: Stihl chain saw won't achieve max rpm
Crank seals are leaking, causes lean or low vacuum for the carb to work properly
Posted on Mar 26, 2009
SOURCE: Chain Saw, Stihl Model 011, cutting off
I've been messin with my poulan 2150 that was doing the same thing. Good, fresh gas, good spark,etc. I noticed whenever I loosened the fuel cap it would literally spray gas out! alas, I removed the muiffler assy and the darn thing fired up the first pull! I've got the muffler parts soaking in gas right now and I'm sure this the problem. It just makes sense especially if you use the same 'mixed fuel' can for weed eater, blower,etc. Check your's out, it could very well be your problem too! GOOD LUCK
Posted on Apr 29, 2009
  • 4 Answers
SOURCE: stihl ms170 keep running in off position
Remove the cover and on the multifunction switch there is a wire with a metal connector on it in the multifuntion switch that when in the off possition needs to make contact with the metal contact that is mounted to the houseing and extends to right above the multifuntion switch usually they get stuck under the switch instead of on top of it.
Posted on Jun 12, 2009
dontbother10
  • 2220 Answers
SOURCE: owners manual for a Stihl 034 AV Chain saw
Stihl Manuals
http://www.stihlusa.com/information/info_product2.html
For an IPL you must contact them.
HTH
Lou
Posted on Oct 19, 2009
dontbother10
  • 2220 Answers
SOURCE: I need a repair manual for stihl ms192t chain saw for down load
Stihl considers ALL IPLs and shop manuals proprietary.
Every time Stihl becomes aware of an on line source they force its removal.
Rules here prohibit any expert from providing you an e-mail address, if I had what you seek I cannot provide a link where you can get it.
You can go here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A large international collection of chainsaw enthusiasts, sellers and mechanics. Not only can you find what you seek you can find someone that has already done it, experienced the pitfalls you will meet, and overcome them. Please do a few searches before posting any question. Joining an existing thread is almost always more fruitful than posting the 4th, 5th, 6th question all asking the same question. HTH
Lou
There are many threads pertaining to Stihl, many also discuss overhaul of different Stihl models. Good Luck
Posted on Feb 04, 2010
Testimonial: "I THANK YOU FOR THE EXCELENT ANSWER. I WILL TRY YOUR SUGGESTION TO SEE WHAT HAPPENS SEEMS LIKE A POOR WAY TO RUN A BUSSINES. GEORGE"
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
What is the best chainsaw for a female to use, need easy start, no electrical?
None, they are too dangerous. You need strong arms in case of kick back.
But if you must, a national and well known brand like Stihl or Husquvarna. The Stihl MS170 might suit you.
"I am very satisfied with every aspect of this saw and love how light weight it is. It starts easily and runs great. I have cut up to 16 inch diameter oak, and it did a great job, considering the size of the saw. The local dealer was very knowledgeable and very helpful."
-Dick44
Kelseyville, CA
The STIHL MS 170 is the perfect lightweight chainsaw for homeowners seeking a great value. Compact, lightweight with just the right amount of power, the MS 170 makes quick work of trimming or cutting small trees, fallen limbs after a storm, and other tasks around the yard. And even at its great price, the MS 170 has many of the same design features the professionals depend on.
http://www.stihlusa.com/products/chain-saws/homeowner-saws/ms170/
Please make sure you also get the safety gear. Vibration proof gloves to stop 'white finger', hard hat, visor, ear defenders, and most importantly chainsaw pants which has carbon fibres to jam the chain rather than cutting your leg off.
http://www.stihlusa.com/products/protective-and-work-wear/chain-saw-protective-apparel/
Homeowner Chainsaws Mid Range Chainsaw Features STIHL USA
Feb 14, 2016 | Garden
How do i replace piston rings stihl ms170 chain saw
Part 4: Stihl chainsaw piston and cylinder replace / repair ...
? 13:54
https://www.youtube.com/watch?v=jCbMCkGqCIQ
Dec 15, 2011 - Uploaded by Andy Reynolds
Refitting the cylinder to the rebuilt crankcase on a Stihl 026 chainsaw. ... Part 4: Stihl chainsaw piston and cylinder replace / repair. .... Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings - Duration: 15:10.
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti ...
? 15:10
www.youtube.com/watch?v=n9RbtjNc-nc
Dec 16, 2011 - Uploaded by Andy Reynolds
Part 3 Stihl 026 chainsaw fitting the rings, piston, anti vibration mountings ... Part 4: Stihl chainsaw piston and cylinder replace/ repair.
Oct 29, 2015 | Stihl MS171 12" Chainsaw
Chain saw dies when cutting into wood
Is the saw oiling correctly? need to check the RPM's at full throttle with bar and chain on to see if it is running right with a tachometer. I suggest taking it to a dealer to have them do the STIHL Engine Check List to determine the exact cause
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Aug 30, 2013 | Stihl Garden
Stihl 023 trouble starting & running
Hi, Replace with correct sparkplug. You have a bad plug replace it and you're good to go.
Mar 11, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
How do I replace the oil pump on a Stihl MS170 chainsaw
The oil pump is pressed in from the bottom. There is a special bolt and bracket to make sure the pump is set to the right depth. Your local dealer should bea able to get the tool for you but it will be cheaper to have the shop do the work.
PS it is more common on this saw to have a dull chain act like it is not getting enough oil than to have a bad oiler.
I am gold certified and have been doing repairs since before the ms series. I have only replaced two oilers in that time.
Good luck
JOE
www.arcolawn.com
Dec 16, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Garden Logo
255 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
