Question about Sanyo DP46849 46 in. HDTV
The screen just went black, there's only sound
Just had the same thing happen last night on my Sanyo DP19657.
Posted on Nov 07, 2012
  • Rob Davenport Nov 07, 2012
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Black screen wont turn off
http://www.google.co.in/#hl=en&biw=1024&bih=634&sclient=psy-ab&q=electronicshelponline.blogspot.&oq=electronicshelponline.blogspot.&gs_l=hp.3..0.1796.15359.0.15921.31.20.0.11.11.0.344.4969.0j1j15j4.20.0...0.0...1c.8bG2f1qU75E&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&fp=ce3f36f7ae84d971
Aug 24, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Sanyo DP46848 LCD TV has black screen with colored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 16, 2017 | Sanyo DP46848 LCD TV
I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Screen went black while watching, now ony have sound
Look at the venting grills, you should see whit lights inside the set. If not, the backlight inverter board may have gone out or the power supply supplying the power to the inverter board may have gone out. Those are the two places to look first. It may have bad capacitors in the power supply.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 06, 2009 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Tv screen went to different color dots then went black
SCAN AUDIO SERVICES
8101 ORION AVE UNIT 5
VAN NUYS, CA 91406
BEST & CHEAPEST SERVICE
HIGHLY RECOMMEND THEM
Jul 28, 2009 | Vizio VA26L 26 in. LCD HDTV
Polaroid flat screen LCD tv went out
sounds like your powersupply just went out on you tv this will need to be replaced
May 12, 2009 | Televison & Video
Screen went black
Check the power supply for 12 volts dc, it must provide at minimum 3 amps of power to trigger the on circuit. If not, replace the adapter... if you need one, please contact me.
Jan 12, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sanyo DP46849 46 in. HDTV Logo
43 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
