Question about Honda Pressure Washer PSI 3000
John deere 3000 psi honda engine
It runs good for about an hour and a half then it starts surgeing and kills on me . i;ve checked the oil the engine seems very very hot when it stops .IT WANT RUN UNLESS YOU LET IT COOL FOR AN HOUR OR SO , ITS ONLY ABOUT 7 MONTHS OLD WOULD APPRECIATE ANY ADVICE.
  • asjohn94 Jan 05, 2009
    john deere 3000 psi honda engine i used it for the 1st time in about 3 months.I used it for 3hrs this past friday and it worked fine i used it for about an hour and half sat and it started surgeing and died on me .It would not start until it cooled off. I checked the oil it was fine i was toid by a coworker today that it sounds like bad gas let me know what u think
  • Honda Master
  • 19,396 Answers
If the engine stops when it is hot, check the air intake, and the air filter.
On some engine there is also an hot air intake going to the carburetor, check it out.
Posted on Jan 10, 2009
  • 4,806 Answers
Hi there
It sounds to me that the air filter needs to be changed and the engine will need a flush to get get rid of any dirt that may be trapped in the engine, bad gas can also cause problems but is rarely the case. After the engine has been flushed and the filters changed the the pressure washer should work fine, you can buy an additive to mix with the gas to prevent further problems like this one.
Good luck and kind regards
Posted on Jan 05, 2009
    Brigadier General:
  • 5,158 Answers
Buy yourself a bottle or two of gasline antifreeze... use one now and keep one for a spare... it sounds like you have some water in the fuel from condensation. when the tank gets low after running for awhile is when it starts sucking water.
Robert
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it stops because the engine has overheated. A couple of ideas to consider if it is using a Honda GX390 engine:
  • choke off after starting;
  • clean air filter;
  • lead-free gasoline used (not leaded nor gasohol);
  • TY15977 gasoline stabilizer used when stored long;
  • blower housing or cooling fins clear;
  • engine oil (which you have addressed).
Good luck and Thank you for using FixYa.
    President:
  • 846 Answers
First off it should have Automatic cool down system that cycles water through it and pushes warm water from the pump onto the ground if this is not happening that might be causing it to shut down to protect itself.
Clean Debris
Daily or before use, clean accumulated debris from cleaning
system. Keep linkage, spring and controls clean. Keep area
around and behind muffler free from any combustible debris.
Inspect cooling air slots and openings on the pressure washer.
These openings must be kept clean and unobstructed.
Cleaning system parts should be kept clean to reduce the risk of
overheating and ignition of accumulated debris
  • Quickfx PC Repair Jan 05, 2009
    Here is a contact number if you need further assistance
    In North America or Canada, call the John Deere Customer
    Service Center.
    • Call (888) 228-3068 and provide product serial number
    and model number.
    Bad gas wouldn't cause it to need cooling down before it started back up. Something is overheating it and causing it to shut off.
  • 679 Answers
Problem is in the Bearing or bush need to be oiling or replaced.
Thanks for using FixYa.
  • rockfixya
    rockfixya Jan 07, 2009
    did u check the Bearing?
    Genius:
  • 1,550 Answers
Gas cap is not venting properly causing vacuum in tank and wet or dirty air filter.
    Genius:
  • 1,913 Answers
Check engine bearing it neeed some serviceing of grese and oil.
also check coolinf fna system work properly.
2007 JD 450J 2500 hours: checked oil levels - Hydraulic and transmission. Engaged drive, normal PSI, crawled at very low jerky speed. Backed up some and then it stopped no PSI and no longer moves.
sometimes they have air pockets disengage the transmission
as to push. start put in gear and run this will help burp out air.
shut off and engage the transmission and try.
Dec 12, 2016 | John Deere Garden
No spark to the plug Kohler 8hp lawnmower engine
Check ingition switch, check battery voltage 12-12 1/2 volts,check in run position same voltage, check in start position same voltage
We've check switch first. If not problem we've check the points for proper voltage and opening and closing.
Jan 17, 2012 | John Deere Garden
Honda GX270 I have no spark. Where to start. Can oil alert be by passed?
Oil alert or the module where the oil alert wire plugs in to could be faulty. You can remove all the wires at the coil for test including the kill switch wire (always use a new spark plug for test, then place the new plug in stroage for later use). I test the coil off the engine on a growler. If the oil alert components are faulty, do not repair. Just check the oil more often. Good luck
Oct 18, 2011 | Honda Pressure Washer PSI 3000
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
My pressure washer works 4 a while then starts to sputter & dies?
I am going to suggest a tune of of the engine. Change the oil and oil filter. Check the air filter is clean and replace it if it isn't. A new spark plug.
Jul 05, 2009 | Karcher 2500 PSI Pressure Washer
1989 Ingersoll-Rand 185 cfm air compressor will not build up air
ITS A POSSIBILITY AND YOU BETTER HOPE ITS NOT SPINNING BECAUSE THE SCREW COMPRESSOR IS LOCKED UP. CHECK THE OIL LEVEL IN THE SUMP AND SEE IF THE ROTOR WILL TURN WHEN NOT RUNNING. TYPICALLY THE DIESEL ENGINE WILL TURN HIGHER RPMS WHEN IT HAS NO DRAG ( NO COMPRESSOR HOOKED UP ). YOU CAN GET THE PARTS FROM INGERSOL RAND OR ANY RENTAL YARD - UNITED, PENSKE, SUNBELT, ETC. THEIR MECHANIC SHOPS ARE USUALLY FOR HIRE AND CAN EVEN INSTALL IT FOR A CHARGE. ALSO MAKE SURE NOTHING BUILT A NEST IN THERE. IF YOU REMOVE THE SCREW, MAKE SURE AND WATCH FOR SHIMS. THOSE SHAFTS NEED TO LINED UP PERFECT TO REDUCE VIBRATION. GOOD LUCK
Apr 06, 2009 | Air Tools & Compressors
Honda Pressure Washer PSI 3000 Logo
100 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
