How do i connect my DVD to TV
Have no Manuel
    Welcome Back:
    Visited the website for 2 consecutive days.
You have a few options that depend on the types of OUTPUT jacks you have on your DVD player & the types of INPUT jacks that are on your TV. If both devices have HDMI capabilities, using that kind of cable is the easiest & best sounding/looking of all the options. If you have COMPONENT jacks (red,blue & green cords), just connect the appropriate color to each end. *Note: to get audio while using COMPONENT cables, you must also use the red & white connectors from the audio OUT jack on the DVD & connect them to the red & white audio IN jacks on the TV. The other connection method is by using the COMPOSITE cables (red & white for audio, yellow for video)
Posted on Nov 07, 2012
Trying 2 watch dvds on my 32 in funai tv cannot down load user manuel
do you have a hdmi cable connected to the tv?
what are you using for a dvd player?
Feb 05, 2016 | Funai Televison & Video
My Panasonic viera TX-26LXD70 says that there is no DVB service found and to check my aeriel or Local DVB service availability. There is no socket to put the co-axial cable in the tv. The tv still works...
Use HDMI from the DVD player and hook up the antenna to the TV..... or DB9 connector on TV.... DO NOT watch DVD from a D VD player or compost cable from the DVD it looks like junk. consult manuel how to hook up your TV
Feb 27, 2014 | Panasonic Televison & Video
Hi I have a JVC 32 D200 with the DVD on the side,
It is metric screw: 4mm thread and approximately 20mm long with a washer
Jan 27, 2010 | JVC LT-32D200 LCD TV
I can't get the JVC system hooked up with my DirecTV Satellite system where I can use it with my TV and VCR/DVD I tried everything in the manuel please help thank you
You need to plug all the audio "out" of the individual units to the audio "in" on the theater system and change the function/unit switch to the unit you want to listen to. If hooked up this way the theateer system has to be on to get any sound no sound will come from the tv. The easiest way is connect everything to the tv, and if the tv has an audio output jack, plug that into one of the inputs on the theater system. Connected this way anything that comes out of the tv goes into the theater system and you can still get sound from the tv at all times.
May 26, 2009 | JVC TH-G30 Theater System
Nne help hooking up speakers to entertainment system
If you have a optical out on your dvd player and optical in on the receiver that is the best connection for digital sound, the vcr section will have to be hooked up analog using rca cords
May 26, 2009 | Mintek LCD TV Progressive Scan DVD Player
We purchased an AKIA TV Type TR2136 Model CFTD2085 from a friend it has a DVD and VCR combination but we didn't get an owners manuel to assist in the use of the DVD and VCR. I want to know how to get an...
look on the back of tv for a 1800 number to call for help and if there is one call they should be able to help you also can search the net for akia manuel with your model.
Mar 07, 2009 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
No sound coming out of the Portable DUR7
is it from the tv no sound coming it mabe be due to faulty cable or due to the wrong connection to the tv do check the Manuel for the connection there is no problem with the dvd player
Jul 03, 2007 | Durabrand DUR7 Portable DVD Player
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
