Question about Frigidaire Electric Dryer
"LOC". As I turn the dial to the requested setting, all the times (15min. 55 min., etc.) are displayed, but as I go to push the 'start' button, the screen says, "LOC", and the dryer won't start. What is this LOC mean on the screen? I tried to unplug the dryer in hopes that it would re-set things, but, when I plugged it back in, the "LOC" letters reappear as I try to start my dryer. What can I do? I have alot of wet clothes ready to dry!!
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Regards,
Richard Roth
http://appliancecafe.com
Posted on Nov 07, 2012
SOURCE: Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Posted on Jan 03, 2008
dragonsthatk
  • 547 Answers
SOURCE: LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Posted on Jun 19, 2009
  • 1531 Answers
SOURCE: Frigidaire Affinity Electric dryer E68 error.
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Posted on Sep 17, 2009
Testimonial: "Thanks I relayed the information to my dad (I'm in CA and he is in FL) and he checking it out."
  • 1531 Answers
SOURCE: frigidaire electric dryer aeq7000es1 low heat only code e4a store
this is a door switch issue make sure the door switch is not broken
  • 1382 Answers
SOURCE: my frigidaire affinity dryer displays LOC
Posted on Apr 16, 2010
I have an old "Intermatic Time-All." I no longer
Most time-all timers have two different trippers on dial.
Push down and rotate tripper to desired ON time and OFF time.
Then manually rotate dial until current time lines up with a mark or arrowhead.
To replace timer with new one:
Buy TN311c with 3 sets of on-off trippers that push onto dial, and 3-prong outlet.
http://www.amazon.com/Intermatic-TN311C-Heavy-Grounded-Timer/dp/B00002N5FO
Buy TN111c with 2 sets of on-off trippers, and 2-prong outlet
http://www.amazon.com/Intermatic-Appliance-Security-TN111C70-Settings/dp/B00002N5FI/ref=pd_cp_hi_3
Aug 09, 2011 | Solar Intermaticlamp & Appliance Timer...
Tip
Dialing code on nokia lumi
By default all Nokia Lumia phones are set to automatically correct the dialing code when roaming. This will also apply to a phone that has been used on a different network than the current one, to correct this here are the guides below :-
- If you have been roaming, deactivate your roaming, switch off and on your handset, the phone will then register the current network as your home network. This will deactivate the dialing code request.
- To remove/ deactivate this feature permanently follow these steps, Dialer(where you access your dialing pad)>>Options(3 dots at the bottom/top right-model dependent)>>Call Settings>>>Turn off International assist.
on May 23, 2014 | Cell Phones
I have an old 3 button digital push button watch that I cannot set the time and date for. the top button is "ST/STP", The middle button id "LAP/RST", the bottom button is...
hold in the mode button until it flashes.5 sec.use the right buttons to move the hr up and down. make sure it is pm or am , usually pm is shown and no am. , press mode to set mins, press rights ones to set mins, press mode. it will go thru time and date and yr. ect. last setting and mode will bring you to a set dial. not blinking. some cases rest the whole thing first by pressing all buttons at once for 5 beeps. let go and sets to defaults 1200 and 0's.
Jun 17, 2011 | Watches
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
I have an Armitron 40/8172 watch and can't find an instruction manual. I need to find a way to turn off the alarm feature. I never need to use it. I can get the "ALARM" to stop displaying when I...
Push the mode button until you get to the AL function (alarm). On the right hand side of the dial where you would normally see the seconds go by in the small round bezel, you will see a "--" or a "-1" or "-2" etc., these are the individual alarm programs. Cycle through them with the EL button and turn off/on the individual alarms with the ST/SP button as needed.
Oct 30, 2010 | JCPenney Armitron Sport Watch
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
I am trying to set the time zone for Adelaide South Australia which is +10.30 hours UTC. Is thereany way to add 30 min steps to the UTC time setting
Set watch to CHR mode, pull out crown, all dials will return to 0 posn. HR shoul be displayed on left digital panel. Move hour hand by turning crown to posn half way between 12 and one, press top button (MIN should appear in left panel), set min to 6 o'clock posn. Push crown back in and set time for timezone nearest to where you are that is offset by one hour.
Oct 13, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Memorex MPH4495 change time on display screen
Push the big blue "DIAL" button for 3 seconds, and the hour will blink, change the hour by pressing the up or down keys right by the "DIAL" button. Press the dial button again to move to the minute. You can cycle through the month, day, day of week etc. by pushing the dial button after each setting.
Feb 11, 2009 | Memorex MPH4495 Phone
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
Setting date/time display
First, you have to Enable Customer Programming. - With handset on-hook, dial #06. The display shows [MMC DISABLED]. - Dial the passcode and '1' and then dial #. (If you don't know the password try 1234, 4321, 9999, etc.) At this point, customer programming is open... Next, Setting the date and time. - Dial #55. Display shows [YY MM DD W HH MM]. - Dial new information as follows: YY = Last two digits of the year MM = Month (01-12) DD = Day of the month (01-31) W = Day of the week (1-7; week begins on Monday (1) and ends on Sunday (7)) HH = Hour (use 24 hour clock) MM = Minutes (00-59) - Dial # to set current date and time. The phone returns to normal use.
Oct 30, 2006 | Samsung Prostar 816 Phone
Frigidaire  Electric Dryer Logo
75 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
