Question about Sony Playstation 3 (PS3) Console
High definition lead into ps3
My brother put a high definition lead into my ps3 and i have now taken my ps3 back home after christmas and plugged in the normal lead into the back and it won't register with the tv, it glows red where the high def went in. is there a way to solve this?
  • 73 Answers
Try resetting the consoles setting to default,you can acquire this by just putting your finger still on the power button for lets just say 5 secs.until you hear it beeps.then remove your finger.let me know what happens
Posted on Jan 05, 2009
Im trying to connect my ps3 to hp vs15. i really need help!
HP VS15 model does not support HDMI cable input. (high definition multimedia interface) It only supports VGA (blue) analog signal only.
Hope it helps.
Oct 03, 2014 | HP vs15c Monitor
How to you connect PS3 to to model 37PD5000
Good day!!!
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be used not only for playing games but also for watching high-definition movies. The best way to connect a PS3 to a high-definition viewing device such as a video projector is through the PS3's high-definition multimedia interface (HDMI) output. The HDMI connection can transmit up to 1080p high-definition from the PS3 to the video projector using a single cable. Attaching and setting up the HDMI cable will only take a few minutes and will let you watch high-definition video from the PS3 on the video projector.
  1. Connecting HDMI
    • Attach one end of the HDMI cable to the HDMI output connector of the PS3. Turn the HDMI cable around if it does not slip right into the HDMI output, because the HDMI cable can only fit into an HDMI connector one way.
      Attach the other end of the HDMI cable to the HDMI input connector that is on the video projector. Make sure both sides of the HDMI cable is securely pushed into the connectors of the PS3 and of the video projector. Turn on the video projector. Press the "Menu" button on the video projector's remote. Navigate to the "Sources" setting on the video projector's Menu. Select "HDMI" from the "Sources" setting. Press the "Menu" button on the remote control again to exit the Menu.
    Adjusting the PS3
    • Turn on the PS3. Wait for the "Home" menu to appear on the video projector, although the quality of the video seen from the video projector will be muddied and dark. Navigate from the "Home" menu to the "Systems" icon using the game controller and select the "Display Settings" tab. Choose "Video Output Settings" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen.
      Choose "HDMI" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen. Choose "Automatic" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the "Confirmation" screen. Press the "X" button on the game controller to make the settings active. Return to the PS3's "Home" menu.
    Watching the PS3
    • Insert a Blu-ray disc into the slot at the front of the PS3. Wait as the Blu-ray disc begins to play the video content on the video projector from the PS3 through the HDMI cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
Thanks for using fixya..
Jul 16, 2011 | Hitachi 37PD5000 Television
Can I see High definition video with the monitor or do I need to Change?
if you have a standard monitor with the 15 pin plug on each end then the answer is no. The 15 pin (d-sub) carries an analogue signal and high definition is digital. You need to have a graphics adapter with an HDMI (high definition) output and a suitable HDMI (high definition) monitor to plug it in to (using an HDMI lead, of course).
Apr 14, 2011 | Computers & Internet
Only sound comes when i connect HDMI cable to my TV for the ps3
you need to select High definition output on the PS3. Connect it via hdmi and via standard lead switch the tv to standard so you can see the picture then select high definition output. Switch over to hdmi and you should see a picture
Mar 01, 2011 | Video Game Consoles & Games
My ps3 audio and video won't work. the power on it works and I it allows me to put cds into it, but nothing comes up on any tv i use it with. how can i fix this?
Hold power button for five seconds, allow system to reboot with default video settings. Common occurrence when moving PS3 from standard to high definition and back.
Oct 28, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is not working because when i plug in all the leads the picture or sound does not work so i bought a new cable but it still does not work I think it may be because i plugged it in to a hd tv then...
Ok, please follow these steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep once when you first press it then beep again 5 seconds later, let go of the power button when you hear this second beep
Step 3. Wait for the PS3 to restart
This basically resets the video output back to standard definition where you should now be able to set it up properly.
Hope this helps
Sep 26, 2010 | Sony Playstation 3 (PS3) Console
PS3 USA compatibility in India for running Bluray moviea and game
As long as the movies and games are the actual things and not some burnt rip-off discs you'll be fine. The movie companies do this so their stuff isn't copied illegally.
Merry Christmas!
If this has helped you, please give me a good rating!
Dec 08, 2009 | Sony Playstation 3 (PS3) Console
Hi I recently played my ps3 on my friends tv using an hdmi lead and all was fine. Now i have returned home and tried to play my ps3 without the hdmi lead and it wont work can you help please.
go back to your friends with your ps3 and change the tv settings on the ps3 back to scart output but also take your scart lead and have it plugged in at the same time. once you have selected scart output unplug the hdmi cable to make sure the settings are right. hope this helps you.
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
