Question about Home
Water running after flush - Home
    Problem Solver:
  • 6 Answers
Usually change is too long. take the lid off the back of the tank see if the chain is getting caught under the flap
Posted on Nov 08, 2012
Dual flush. Water keep running after flush
Check flapper valve in tank
Nov 07, 2017 | Home
How do I stop water running into pan after toilet has been flushed &refilled.
If there is water still running into the toilet bowl, there is a problem with your flapper or flush valve. The most common problem, and least expensive to fix, is the flapper has gone bad and is allowing water to escape past it. Replace the flapper and the water should stop running. If not, it is possible the flush valve or one of the seals holding it to the tank has gone bad and needs replaced. Try replacing the whole flush valve. They come in a kit that includes the valve, flapper, and seals.
Feb 26, 2015 | Home
I have a 1999 Ford Taurus that would not heat, took to shop they flushed the system, replaced the water pump and it ran hot after thet flushed the system took it back they flushed the system again and
Did you have red antifreeze prior to the flushing? Ford engines are generally aluminium and should be using blue antifreeze which is suitable for aluminium engine blocks! I think the antifreeze is reacting to the aluminium.....re flush and use blue!
Dec 29, 2014 | 1999 Ford Taurus
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
Flush radiator
The easiest way to flush, if radiator is left in the vehicle, is to have the car at normal operating temperature, open the radiator drain, and put a garden hose into the cap opening. Turn it on till as much water enters the radiator as is leaving the drain. Run the engine as you are flushing, and run it till the water runs clean out the drain. Then shut off and refill with a 50-50 mix of water and antifreeze.
If you take the radiator off, you could run the hose into the bottom hose fitting and let it drain out the top hose fitting or the radiator fill neck. A simple back flushing method that may help dislodge and flush out any particles-but the first method should work well enough if your radiator is in good shape and not clogged up with rust and scale.
Apr 29, 2013 | 2003 Buick Century
After flushing, water fills up tank and continues
Your problem is the water fill valve. Check this link.http://www.rd.com/17646/article17646.html
it's not the flapper or flush valve.
Mar 05, 2010 | Home
I'm flushing my radiator in ford e-350 v8 with 5.4l......has strait water in it now......when i flush I'm trying to figure out where the heater return hose isto flush the core or do I even need to...
when i flush my radiator.i would first drain out all my old antifreeze.fill radiator up with water then put a bottle radiator flush. pour in radiator.then i will crank car up turn on heater wide open allowing radiator flush flush out radiaator and heater core when done i will drain out water. put in more water flush out all radiator flush out engine and radiator.then put back in antifreeze.you dont want to run water hose to heater core it will rupture it water pressure too high.
Dec 08, 2009 | Water Heaters
How do you convert a 1997 760 Yamaha Waverunner from fresh water to salt water
There is nothing to convert. After running it in salt water, you need to flush the engine out either on a garden hose or by running it in a fresh water lake or river prior to storing. Salt water is very corrosive and you need to flush your engine just as soon as possible after removing it from salt water. DO NOT let it sit overnight, it will start corroding internally and doing damage.
Aug 24, 2009 | Hayward Sand Filter System & Tank 21" 1...
Proper method on coolant system flush
Best way is to buy a flush kit. It is an adaptor that you put in your heater hose and can hook up a garden hose to. You cut the hose and put this device permanently in the line. Remove the thermostat, don't put the new gasket in there yet just put the outlet pipe back on and bolt it down. Run the car when cold with your hose running for about 10 minutes with the radiator drain valve open on the bottom of your radiator and the cap loose, water should come out of the drain valve and the radiator cap. This will flush your engine adequately, why waste money on distilled water, save that for topping off your battery. Turn off your engine continue to allow water from your hose to flow as long as you are seeing any thing other than clear water flow until it flows clear. Turn off the hose, put the cap on the flush port you installed. the port stays under your hood and allows you to flush your engine as needed. Let the water drain through the drain valve. Put in a new thermostat, with a gasket this time. Refill with water and antifreeze as directed in your manual. You should be good to go.
May 21, 2009 | 1997 GMC Jimmy
Home Logo
18 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
