Question about DeLonghi Heating & Cooling
My Delonghi heater type HHP1500S&B when I plug it in it starts to get hot then go cold and stays cold I wanted to open it up but it has soom funny screws can someone tell me the problem the heater also what kind tool I need to open it up thank you.
3 Suggested Answers
  • 958 Answers
SOURCE: Hi I have a concern
nope. it is not normal...
there could be a loose connection on the plug. solution is to replace the plug. make sure connection of wire to the new plug is ok.
tnx 4 using fixya,
drcool
Posted on Sep 24, 2008
SOURCE: need any user and -or service manual for delonghi PAC -75 U
Here is the manual
http://www.appliancefactoryparts.com/content/pdfs/123150.pdf
Posted on Jun 29, 2010
The power button wont come on to heat
Troubleshooting a Tank-Type Water Heater That Won't Start ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
Whether your water heater runs on gas or electricity, it needs a controller to cycle theheat on and off, or the water in the tank would either be stone cold or ... If the buttongoes in and stays in, the thermostat should start working again. ... Screw in a new element, reconnect the wires, refill the tank and turn the power back on.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
AFTER you establish that there is power being supplied to thewater heater .... When the water is cold in the tank the top element will come on first, heating the ... is overly hot and then notice no hot water check the reset button.
Tanklets: Electric water heater problems
Jan 25, 2016 | Water Heaters
How do you open the moist cap? i want yo fill it with water but it wont open
What is this cap on?? Radiator or windshield washer reservoir? Something else?
If the radiator, most newer cars have a plastic bottle or tank that has a "cold" and "hot" level indicated. You should be able to see the coolant level thru the tank. You should NOT need to open the radiator cap if your car has this tank. Add a 50/50 mixture of water and coolant (of a type your car requires) up to the "cold" mark and start the car. Let it run with the heater set to HOT and fan set to HIGH. Continue adding the 50/50 mixture to maintain the coolant level to the HOT level mark on the tank as needed with the engine running. Stop when there is HOT air blowing out of the heater.
If your car does NOT have this tank, you may only open the radiator directly when the engine is COLD. Wait several hours for the engine to cool after shutting off before attempting to remove the cap.
When cold, press DOWN on the cap WHILE turning. Most caps will come off after a 1/4 to a 1/2 turn. Start the engine and set heater HOT and fan to HIGH. Continue to add a 50/50 mixture of coolant to the radiator until the heater blows HOT air. The coolant level in the radiator should be just under (1" or less) from the bottom of the radiator opening.
Was this the info you're looking for?
Sep 13, 2013 | Cars & Trucks
My Coffee from my DeLonghi Magnifica does not seem to be hot enough.
Possible weakness in the thermostat which make the heaters cut off at a earlier state. So try to check the machine for any loose connection to the lines, the heaters or else the switch and thermostat must be looked into .
Jan 24, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
After turning on water heater it stays on for about 10 minutes then shuts off. There is warm water for about 25 - 60 seconds then goes cold. It does restart. Any ideas? Changed propane regulator after...
I'd check position of by-pass valve(s) on back of water heater. Sounds like they may be in wrong position. Remember, you want cold line going ( in) to bottom of water heater to be open, as well as hot (out) at top connection open. Any valves in between should be closed. Depending on what type of by-pass set-up you have, as some are 1,2,or 3 valves. Let me know what you find.
Dec 04, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Heater blows cold air
CHECK HOSES FROM RAD TO SEE IF THERE BOTH HOT.... U MAY HAVE A DEFECTIVE THER.MOSTAT.. IF NEED TO REPLACE, USE A FAIL SAFE TYPE...WHEN THEY FAIL .THEY STAY OPEN SO U DON.T OVER HEAT UR ENGINE &DO ALOT OF DAMAGE CAUSE THERE,S SOME MUCH ALUM IN ENGINES THESE DAYS... ALSO CHECK FOR AIR LOCK IN THE SYSTEM...LEAVE RAD CAP &RUN THE ENGINE TILL IT,S HOT.. WHILE THE FLUID IS CIRCULATING, IT SHOULD EXPELL ANY AIR IF ANY IN THE SYSTEM, GD LK, CHARLIE
Mar 05, 2010 | 2006 Nissan Titan
My heater won't stay hot. 99' Dodge Stratus
sounds like you might have a heater core problem, you also might want to check the thermostat. it may be stuck open
Nov 22, 2009 | 1999 Dodge Stratus
I HAVE EXACTLY THWE SAME SITUATION LISTED IN THE DETAILS/
A thermostat that is stuck open will cause there to be no heat. If its closed is when you will run hot or overheat.
Oct 05, 2009 | 2003 Mitsubishi Galant
Hi I have a concern and just wanted to clarify it. The plug on my Delonghi DEL2400T oil column heater get really hot when on. Is this normal?
tnx 4 using fixya,
drcool
Sep 24, 2008 | DeLonghi Heating & Cooling
Heating & Cooling Logo
138 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
