Question about Cell Phones
Lg mobile model no. Ce1068 battery point short circut .its battery backup is not actual .solv it
Hi, I am Indra,, I have a LG Studioworks 563A monitor,, always time is ok,, but evening time is some disturb me,, this monitor evening time voltage capability fault with UPS,, when i start my computer, UPS...
Not sure I fully understand the question but I'll give it a shot. If you mean that your UPS backup shows a fault.. more then likely the problem is with your UPS backup and not your monitor.. (unless your monitor is shorting out or has to much feedback to the power)
A few things that can cause this is a BAD UPS battery or a underrated UPS backup for devices. Based on the information you gave this monitor is a OLD CRT type monitor which uses quite a bit of power. I would first try the UPS backup with other devices to see if the same problem happens just like a computer or any other electrical device with out the LG connected. If the same problem occurs replace the battery and/or UPS backup, if it doesn't ... then you might have to just replace the monitor as it might be shorting out. With out proper test equipment a definite answer might be hard to come by.
Nov 05, 2013 | Computers & Internet
LG AT&t SKU codes
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 01, 2012 | AT&T LG CU515 Cell Phone - Black
How can i unlock my LG Kf310
you can get the unlock codes for your LG model mobile, through this site http://www.theunlockarena.com/lg/rs13wp8/
It has the best instructions and easy methods for unlocking your LG model mobile phones........
Oct 21, 2010 | LG KF310 Cellular Phone
UNLOCK CODE FOE LG C2000 PHONE
For the best unlock code for LG model mobile,
you may try this site http://www.theunlockspot.com/lg/rs10wp8/
It has the step by step instructions and methods for unlocking LG model mobile phone!!!!
Jul 11, 2010 | LG C2000 Cellular Phone
Battery backup problem
if ur mobile problem is heat then circuit short
Jul 03, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Change the backup battery in MC9060
Hello mis1539. I think I can help you here. First: are you sure the backup battery is defunct? Bear in mind that the backup battery takes about 15 hours to fully charge and will discharge if the main battery or power source is disconnected or goes completely dead for anywhere from 30 minutes to a few hours. If the backup battery discharges, the process starts all over and the backup battery will need to be charged for 15 hours again. If you think the backup battery may have discharged at some point, it could be that it never full re-charged so it will discharge and lose your settings (cache/flash memory) almost instantly. It is worth mentioning that about 95% of my clients that have this problem have fixed it by simply making sure that the unit is in it's cradle, with the battery in and charging overnight to fully recharge the backup. Again, I really would implore you to give this a shot before resorting to cracking open the unit and getting to the backup battery (which is no fun task, I assure you). If this doesn't work for you, please let me know and I can help you further. I hope this solves your problem. Good luck!
Sep 23, 2009 | Symbol MC9090 Mobile Computer Portable...
What type of datacable is using for LG KG110
Hello
you can download the software from here
please vote for me
from
hkmthumma
Jan 24, 2009 | Sony CONNECTOR, EXTERNAL UPS System
Hard reset ipaq 111 running windows mobile verson 5.2
hi,
just so you know, this is a LG KU990 forum.  these phone dont run windows mobile of any version.  I think there is a backup battery built into the phone.  Also, are you saying the hard reset 3 keys did not perfrom a hard reset or that the hard reset did not do annthing?
Sep 09, 2008 | LG KU990 Viewty
Cell Phones Logo
55 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
