Question about Koiiler XM-7676W Car Audio Amplifier
KOIILER XM-9697
WIRING
4 Suggested Answers
Soundawake
  • 40 Answers
SOURCE: i dont have aproblem with
It's only worth ~$50.
I've seen a 2000W one go for $60
Posted on Feb 28, 2011
  • 111 Answers
SOURCE: I have a Koiiler XM-6666
You need to match what is on the amp. If the amp has a single fuse, or multiple fuses rated at a total to 80, then you need to use an 80 amp fuse at the battery.
Posted on Apr 23, 2011
timbadger21
  • 64 Answers
SOURCE: koiiler xm 6660 manual &wireing
u can get one online on wholesale.com
Posted on Jun 22, 2011
What os code 12
The FI light on our Yamaha is much like the check engine light on your car. If it comes on it is real easy to check the code, and for the bike to tell you what is up. Just ground the diagnostic wire and it will start reading them out. Mine just had one code, but it will read out as many as you have. Then you can know what to address to potentially fix issues with the bike. There are more than this, but below are some basic codes to work with. Service Codes FI Indicator Light (LED) Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction
31 Vehicle-down sensor malfunction, wiring open or short
32 Sub throttle sensor malfunction, wiring open or short
34 Exhaust butterfly valve sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank key detection
51 Stick (Ignition) coil #1 malfunction, wiring open or short
52 Stick (Ignition) coil #2 malfunction, wiring open or short
53 Stick (Ignition) coil #3 malfunction, wiring open or short
54 Stick (Ignition) coil #4 malfunction, wiring open or short
62 Sub throttle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
May 01, 2016 | 2005 Yamaha FZ6 Fazer
I need a diagram for the lighting harness and list of what each wires controls. i also need a list of the colored wires to determine what wiring effects. my dashlights are out.
It may be helpful to know the make of the vehicle, year, model, engine????
Free Automotive Wiring Diagram for ALL Make & Model ...
www.wiring4cars.com/
Free Automotive Wiring Diagram in Full Color for ALL Cars, Trucks, Vans and ... who just need to trace down one circuit (i.e. radio wiring diagram, a/c circuit, ...
How To Wire Fog And Driving Lights Harness Wiring Diagram
www.accessconnect.com/fog_driving_lights_wiring.htm
Position the lamps at an equal distance from the center of the vehicle and as far apart as ... Note: This is a general wiring diagram for automotive applications.
Automotive Wiring 101 - OnAllCylinders
www.onallcylinders.com/.../wiring-101-basic-tips-tricks-tools-wiring-veh...
Dec 5, 2013 - Automotive Wiring 101: Basic Tips, Tricks & Tools for Wiring YourVehicle ... This chart can be used to determine proper wire gauge. First .... A factorywiring harness includes the necessary wiring for standard electrical ... The gauge youneed depends on the current draw of the accessory and the wire length ...
Jan 23, 2016 | Cars & Trucks
Where can I get a wiring diagram?
NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS ...
www.faqqq.com/.../need-wiring-diagrams-for-lionel-1055-texas-lionel-doll...
Question Product: Lionel Dolls, Playsets & Toy Figures Question Details: NEED WIRING DIAGRAMS FOR LIONEL #1055 TEXAS NEED WIRING DIAGRAMS ...
treadmill wiring diagram Dolls, Playsets & Toy Figures ...
www.fixya.com > Forum > Tags > treadmill wiring diagram
Ask your treadmill wiring diagram doll, playset and toy figure questions. ... need a wiring diagram for a massey ferguson 135 tractor lookin for a complete wirng ...
pactrol p16 wiring diagram Dolls, Playsets & Toy Figures ..
Jan 17, 2016 | Toys
How many wire harness clips connect to module besides the antenna
Engine Control Module Wiring Harness Replacement - 1.4 L ...
workshop-manuals.com/.../repair.../engine_control_module_wiring_harn...
3. Unclip the 3 wiring harness clips (1, 2) from the engine control module wiring harness brackets. ... Disconnect the wiring harness connection adapter plug (4).
Engine Control Module Wiring Harness Replacement - 1.6 L ...
5. If equipped, disconnect the engine oil level sensor wiring harness plug (7). ... 10. Unclip the 2 wiring harness clips (2, 6) from the wiring harness brackets.
How to fix wires that break out of plug clips on a wire harness
Dec 01, 2015 | Cars & Trucks
What is code 14 on 03 zx636
Hi, here you go:
Service Code Problems
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
36 Blank Key detection
39 ECU communication error
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
83 Oxygen Sensor #2 inactivation, wiring open or shout (Equipped Models)
94 Oxygen sensor #1 malfunction, wiring open or short (Equipped Models)
95 Oxygen sensor #2 malfunction, wiring open or short (Equipped Models)
Feb 01, 2011 | kawasaki ZX-6R Motorcycles
I have a 2000 dodge neon the wiring harness is messed up does the wiring harness from a srt fit?
interio wiring or enging wiring? Interior wiring fit, the engine wiring not.
Jun 01, 2010 | 2000 Dodge Neon
I need to see a wiring diagram for my gsx 1100 `91
GSX 1100 91 model wiring diags. Copy and paste to your address bar.
http://www.gsxr711.com/tech_drawings/wiring/GSXR1100-1991-wiring-diagram.png
or
http://www.gsxr711.com/tech_drawings/wiring/GSXR1100-1993-wiring-diagram.png
Mar 10, 2010 | 1991 Suzuki GSX 1100 GM
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
Koiiler XM-7676W Car Audio Amplifier Logo
139 people viewed this question
Top Koiiler Car Audio & Video Experts
xxxxxx xxx
Are you a Koiiler Car Audio and Video Expert? Answer questions, earn points and help others
