Question about Craftsman 4 Cycle Blower/Vac
Died and will NOT start.
I was using my less than 1 year old Craftsman blower (Model No. 358.794760) one evening a few weeks ago and, with almost a full tank, it died. It had never died while "hot" before. I was 99% done so I quit working. Last week I got it back out and followed the proper ignition protocol...NOTHING. I bought a fresh gallon of gas and mixed it properly, changed the spark plug, cleaned the air filter...NOTHING. It seems to me like it's not getting any "fire". I can pull on the cord until blue in the face. Is there some type of electrical part that could be the culprit?
  • johnl1304 Jan 11, 2009
    I have the same problem with mine changed spark plug, put in gas, cleaned carborator, like the other person it seems not to be getting any spark to it.
  • Jim Giesen May 11, 2010
    Ok. Is there spark?
    Does it have compression?
    Did you have oil in the fuel mix? siezed engine.
    Was the spark plug coco coulor or gray?
  • 979 Answers
I experienced a similar problem with mine and I replace the little plastic tube that is immersed into the fuel. It had some stuff in it and preventing fuel from getting to the engine. It was only about 1.50 to replace.
Posted on Feb 03, 2009
My craftsman leaf blower won't start. It gets gas and spark. Is there an ignition issue I should be looking at. The same thing happened with my Poulan blower a couple of years ago and the re
Remove the carburetor carefully noting which fuel line goes where. Remove the section of the carb that the fuel lines attach to. Examine the main carb housing that attached to the part that you removed and you should see a very small screen that is probably blocked from fuel additives that the government requires. Clean that screen and reassemble and reinstall the carb and use fresh fuel/oil mix and use a fuel stabilizer in your mixed fuel.
Nov 16, 2014 | Craftsman Garden
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Craftsman yard blowr vac 358.794774
If there is a fuel cup on the carb take it off and clean it out real good and also clean the fuel jet. It could be dirty with old dirty gas. You can clean fuel jet by blowing it out with air compressor or a real fine wire. Be very careful you don't disturb the float when you do this.
Dec 30, 2017 | Garden
Won't start
May have moisture in the fuel. Try draining the old fuel out, put in new, add Stabil, or some other fuel stabilizer, clean & gap plug. Should start.
Oct 31, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman leaf blower Model # 358794761
Sounds like you have dirt in carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 17, 2009 | Craftsman Garden
I have a 25cc Craftsman Blower/Vac model 358.794941 which will not start. I have replaced the spark plug and carburetor. This is 2 years old and not even 10 hours on it.
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
Oct 05, 2009 | Craftsman Garden
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Craftsman 4 Cycle Blower/Vac Logo
564 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
