Question about Whirlpool GHW9300 Duet Washer
Control locked light is on and will not start
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Posted on Nov 07, 2012
I can't start my dishwasher. What lights up is control lock. I've never had this problem before.
To turn off control lock - Press and hold control lock for 3 seconds. The control lock light should turn off.
Sep 25, 2015 | KitchenAid Dishwashers
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Control lock light is on and dishwasher doesn't start
There is a Control Lock which locks all the control buttons, so the dishwasher cannot be started. It is enabled by pressing and holding the lock button for about 3 seconds. To disable, press and hold the lock button until the light goes out. A single beep will be heard when the feature is turned on.
There is also a Keylock feature which locks the drawer shut and disables all the controls so the dishwasher cannot be opened or started. It is enabled by pressing and holding the lock button for about 5 seconds. To disable, press and hold the lock button until the lock light goes out. Two beeps will be heard when the feature is turned on.
Both these functions are safety features that enable the consumer to lock the dishwasher controls to prevent children from inadvertently starting the appliance.
These instructions are on page 12 of your owner's manual. If you no longer have a manual, you can obtain a FREE copy at managemylife.com. Just go to the site and type in your number under the "Manuals" link. These manuals are available in .pdf (Adobe) format that you can download or print for FREE.
(posted by Jeff Rockwell)
http://www.whirlpool.com/owners-center/owners-center-homepage.content.html
Mar 11, 2013 | Dishwashers
I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
Nov 03, 2017 | Maytag Refrigerators
The "Control Locked" light is
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Mar 31, 2011 | Washing Machines
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Jun 17, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Control lock light
control lock light ? have you got any blockages or dirty filters you may have to clean them.
Jul 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
Apr 16, 2008 | Whirlpool GHW9150 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
