LG WD-80154TP washing machine is showing OE, which means the plug or filter is clogged. I cleaned both and am still getting the same message. What do I do now?
I got the message OE and looked at the manual and it said the drain pipe is clogged or pinched, so I cleaned it and cleaned the filter but I am still getting the same message. Now what do I do?
I have this LG front loading washing machine WD-80154TP. It does not take water in. We cleaned the inlet filter. The hose is also in good condition with good water pressure and there is no blockage. I am getting the IE message. Did all the trouble shooting steps as given in manual. it just happened from a week. Nothing is helping out. I guess there is a problem with the machine water inlet mechanism of opening and closing valve. Did self diagnostic of washing machine by pressing power button + time saver button + spin button. bot still the water doesn't enter. What do I do?
Posted on Oct 12, 2014
    Sergeant:
  • 264 Answers
Have you done a reset turn off machine by the mains leave off for 10 min's make sure door is open at all times make sure machine on/off button is off and the programmer is set to the off if you havent got a off on the programmar put it on a spin program ok then switch the mains back on turn on the machine on off button then press start then shut the door that is a reset if you still have problems get back to me ok
Posted on Nov 07, 2012
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
SOURCE: LG WM2277H - OE error
THE ABOVE SOLUTION WORKED LIKE A CHARM. IT WAS A TINY BONE STUCK IN THE PROPELLER BLADES. THANKS FOR THE SOLUTION!!!!!!!!
Posted on Jun 20, 2008
  • 98 Answers
SOURCE: Washer won't drain.
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Apr 01, 2009
omaharox
  • 166 Answers
SOURCE: OE error in washing machine
This is a drain error as you have figured out Good Job!
Now this can be caused from a broken impeller in the pump and or a plugged tub to pump hose.
Have you washer any rugs which may have came apart in the wash?
If so the hose from the tub to the pump may be restricted causing the code.
The hose will need to be cleaned.
This is a job best left to a pro.
Posted on Jan 20, 2010
  • 354 Answers
SOURCE: my lg washing machine is
Could be a manufacturers glitch ,might want to cal a servoice center to see . Basically the washer is having problems draining ,check the drain hose going to the tub sink and make sure it isnt up in the air or something. Another posibbility is that the hose or drain has something in it backing it up to a sensor,could run some bleach through it to see if it clears
Posted on Feb 17, 2011
My LG washing machine is showing OE fault what do it mean ?
OE means uneven load.
If you can open door, put a dry towel in with the washing and try spinning again ...
Nov 20, 2017 | LG Washing Machines
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
Help!! the washing machine wont spin out it keeps commin up wiv oe?? plz help
OE means that the drain filter or hose is blocked or kinked or clogged.
Clean and straighten the hose and clean filter.
Good luck
Feb 08, 2010 | LG WD-16115FD Front Load Washer
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Message OE
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Dec 23, 2008 | Washing Machines
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WASHER/DRYER
OE is a drainage error.
This can be anything from a plugged filter screen to a faulty drain pump.
The filter screen location and cleaning procedure can be found in your owner's manual or online at the LG website.
Aug 05, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
466 people viewed this question
Top Washing Machines Experts
