Question about Cell Phones
HOW DO I UNLOCK PANASONIC BD77GN-K MAKING IT REGION FREE
Have tryed the holding power/eject/play and stop for 5 seconds and this will not work.
  • Cell Phones Master
  • 14,641 Answers
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Posted on Nov 07, 2012
Require a Unlock Code for region free
DVP 3618 - how to unlock region codes?
1. Power ON the DVD player with no disc inside
2. Go to the SETUP icon and press OK; next, go to
Preferences and press OK
3. With preferences highlighted,
3a. Press NEXT CHAPTER (button above AUDIO, it looks like
this: >'),
3b. Press PREVIOUS CHAPTER (button above SUBTITLE, it looks
like this: '<)
3c. NEXT CHAPTER >'
3d. PREVIOUS CHAPTER '<
4. The OSD will show the current Region Code
5. Press the Navigation Up or Navigation Down buttons to
select your desired region, or 0 for region free
6. Press OK to confirm your region selection
It works for DVP 3618 model.
Dec 04, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
How unlock region codes on a U.S. model samsung bd-e5900
I have just checked the physical layout of the US remote compared to my Aus/NZ model. They look almost identical, except for the button on mine named REPEAT..and on yours named HUB. This is the button immediately below the PAUSE button. Why don't you try the following HACK (which definitely worked me)..but push your HUB button instead of the REPEAT.?. It may work...fingers x'ed. 1. Ensure that there is no disk in the tray. 2. Switch the player off and then back on. This is necessary to clean-boot the firmware. 3. Wait until the main menu page appears and the player stops doing anything. 4. Press the eject button to open the tray. (The button is between the "Power" and "TV Power" buttons at the top of the controller.) 5. Press the eject button to close the tray. 6. Wait while the player searches for a disk. 7. As soon as the "No Disk" message appears at the top right corner do the following. 8. Press the REPEAT button - just above the TV channel selector at the bottom right of the controller. 9. Enter 76884 on the number pad. This is The Code If You Have A Region 4 Player (Other Region Codes Given Below) 10. The region code "4" should appear at the top right corner of the screen.(this just flashed on then off, so keep an eye on the screen) 11. If you see "4" over the top right corner, quickly enter "9" to make the player region free. 12. Power down and power up again. 13. Play a foreign DVD to verify the change. Other Region Codes To Be Used In Step 9 If You Dont Have Region 2 Player Samsung Region Codes 1 - 2 9 3 3 4 2 - 5 7 5 3 8 3 - 5 6 7 3 2 4 - 7 6 8 8 4 5 - 5 3 8 1 4 6 - 2 4 4 6 2 YOu may have to try many times. YOu have limited time window to enter the numbers. As soon as you see "4" on the top right corner, quickly enter "9".
Dec 30, 2012 | Samsung BD-E5900 Smart-3D Blu-ray Player
Can I play a dvd region 2 dvd on a Philips 5 disc changer 783c dvd player? its a uk release of a german film. The DVD player gives system menu selections stating many nationalities
just because it may have many languages does not mean it is multi-region.
what you need to do is search for "region free hack" and the model of your player.
If there is one for your player the process takes less than 30 seconds to do (did on my single play philips which is region free whoo hoo)
beware though you may have to spend some time finding the free codes and there are a lot of sites out there that want to charge for this info (dont pay just persevere)
The method is usually power on the dvd press eject whilst holding down a key combnation until a menu comes up then selecting 0 ZERO as the region or somthing similar there are variations even from the same manufacturer.
I disagree with the whole region scam and do not class hacking a dvd player as any form of piracy. its simply allowing me the freedom to choose what i watch from whatever country i want.
Aug 11, 2009 | Philips Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Panasonic SA-HT520 error message
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 20, 2008 | Panasonic SC-HT520 System
Samsung dvd-r155 unlock region code
Region codes for Samsung:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Works just fine on my region 4 R155. Hope this helps.
Aug 03, 2008 | Televison & Video
Samsung code
1. Cold start the player, by holding down the PLAY and STOP buttons on the player.
2. You should see a set of language options. Release the PLAY and STOP buttons.
3. Select your language.
4. Press REPEAT (not the repeat A-B button) then the following codes for the required region the player is already set to (region you bought the player in):
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
5. A code will appear, indicating the region setting of your player.
6. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
7. Press OPEN on the Player to open the disc tray.
8. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified.
Jul 05, 2008 | Samsung DVD-P244 DVD Player
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Need setting to change regional code on samsung DVD P172
This works to change region code 5.
This is how it works.
1)Power on player.
2)Ensure that there is no DVD inside the player.
3)The tray should be closed.
4)Press "Subtitle" on the remote control.
5)Press 53814 for region 5 (For other regions see any of the other cracks)
6)The region code 5 will be displayed on the left top corner of your screen.
7)Now press 9. A 9 will be displayed on the top left corner of the screen.
8)Press Subtitle on the remote again
9)Power off the player.
10)Power it on again and you are region independent!!
Worked for me.
Mar 13, 2008 | Samsung DVD-HD870 DVD Player
Unlocking
Follow Carefully:-
1:- Power On Your Player.
2:- Press And hold Play And Stop On The Front Panel ( player )
3:- After a short While Options Will Appear To Change region Settings. Choose Between 1 And 6.
4:- Press The Play And Stop Buttons On The player.
Your Player Should Now Be The Region Of Your Choice.
Hope This Helps You Out.
Mike @ Compurepair.
** Please Do Not Rate This post Until your Problem Has Been Solved/Resolved.
We also offer Full Advice On Making The Player Multi-region Capable Or Region-Free, For A Small Fee.
Thankyou.
Feb 27, 2008 | Samsung DVD-V1000 DVD Player/VCR
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
