Question about Fuji FinePix S304 Digital Camera
I have a Fuji A360. I've used this for a long time. It now shows zoom error when you turn it on and the lens won't come out. Is there a way to fix this. thks sam
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Posted on Nov 07, 2012
SOURCE: zoom error message
The higher end fuji's are good cameras. The A345 and A350 are a piece of crap. Low end Walmart cameras.
Posted on Dec 02, 2007
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Posted on Feb 19, 2008
SOURCE: Fuji s7000 zoom error
have same problem fujifinepix6900zoom is solution same
Posted on Jun 01, 2008
  • 244 Answers
SOURCE: Telescopic zoom lens won't expand
Lens may have jammed.
possible solution : daveward712@aol.com
Posted on Feb 27, 2009
  • 244 Answers
SOURCE: Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
Posted on Apr 08, 2009
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Zoom error Fuji S1000fd
I have seen instances where people managed to get this problem fixed themselves. the zoom mechanism, it seems, is not all that complex. If you think you've got nothing to lose (there is a risk factor) just take it apart and have a look. Good luck!
May 05, 2012 | Fuji FinePix S1000FD Digital Camera
I have a zoom error alert on the screen of my fuji j37 digital camera. When i turn the camera on the lens comes out and retracts straight away.
I had this problem for the first time yesterday, on my fifth use of the camera from new. The user manual says to turn it on and off a few times which I did but to no avail. I found advice on a different forum that said to hold your finger over the shutter as you turn it on, so that the lens doesn't have time to retract again. Sort of use your finger nail to hold the shutter up while the lens extends. Tried this and it worked, switched it off and back on agiain and it seems to be going fine now.
May 16, 2010 | Cameras
Fine-Pix A400 is showing Focus Error and will not allow photos to be taken. In addition, the lens will not retract when the camera is shut off. This problem occurred after using the zoom procedure several...
Here is a quick fix to try. If you attempted to remove the focus error doing the 3 times on and off, and it didnb't help to this. Power the camera on, you will hear the gear skipping as if it is slipping. Right at the moment you turn of the camera push the lens in manually slightly and gently. This will reposition the timing of the lens to focus. This usually fixes the Focus error when the lens is stuck in the out position and never retracts. I have had this happen twice, and it cleared both times by doing this. Good Luck
Jul 22, 2009 | Fuji FinePix A400 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Feb 18, 2008 | Fuji FinePix F45FD Digital Camera
Fuji finepix A600 camera - Zoom error
good luck...
Jan 02, 2008 | Fuji FinePix A600 Digital Camera
A210 zoom error
When you first turn the camera on, grab the lens, pull on it slightly. Turn the camera off and try it again. If it doesn"t work the first time , pull on the lens slightly again. It worked on mine
Dec 23, 2007 | Fuji FinePix A205 Digital Camera
ZOOM ERROR
I used to get that error all the time with a earlier Fuji FinePix with the slide-over lens cover. If the cover wasn't pushed back completely, the lens would extend only so far and then give an error. Make sure that there's nothing (dirt, hair) on any of the lens surfaces and make sure the lens is fully extending when you do turn the zoom on. Don't let anything touch or bump the zoom while it's moving, either.
Not sure if this will help, since you have a different model. This is what worked for me, though.
Nov 16, 2007 | Fuji FinePix F470 Digital Camera
Zoom error
when the lens comes out, gently pull it as far as it will go, wiggle it a bit and it should right itself. just tried it with mine and it's sorted.
nice
Nov 07, 2007 | Fuji FinePix A600 Digital Camera
Fuji FinePix S304 Digital Camera Logo
76 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
