Question about Altec Lansing VS4121 Computer Speakers
Am only getting sound out of left speaker
My balance on my volume is fine. So thats not the problem. Ive unplugged and plugged back in every component including the power source. Is it just a short that can't be fixed?
  • 154 Answers
If you have a multimeter, measure across the speaker connector (2 pins on the same plug) and depending upon the make and spec of speaker. you should get between 2 and 16 ohm reading. If a sjhort circuit is shown, then normally the speaker coil ahs blown or there is a short in the actual jack plug. replacing this plug appx 6cm in from the plug should remove any damaged part of the cable. Kind regards
Posted on Jan 05, 2009
I purchased theses speakers January, 2011. At first they worked fine. Then I started having problems getting sound out of the left speaker. The sound would return when I plugged and unplugged the speaker...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 04, 2011 | Bose Companion 2 Series II Multimedia...
HELP ! No/limited volume from satellite speakers
1. Make sure all wall and power outlet switches are on and that all switches for your speaker system are on. Cycle the power switch.(switch is located on the back of the subwoofer) Check power LED on left and right speakers. Is the LED on? If not, power is not getting to your speaker system. Make sure the power cord is plugged into an electrical outlet. 2. Ensure that the speaker input jack is pushed all the way into the appropriate jack. Check all the connections and secure them. 3. Check the connection to the soundcard. Make sure it is connected to the proper jack. This varies from each soundcard manufacturer. (Please refer to your soundcard manual.) 4. Your volume settings are too low or muted. Increase your volume by pressing the + key located on top of the right satellite. You can also check your volume through the volume control located in the taskbar. To mute and unmute the speakers, press the + and - controls at the same time.
the part that is for your problem
This is an indication that the satellite speakers are not plugged in all the way to the subwoofer. You will hear a slight "snap" sound if they are plugged in all the way. The inputs are color coded and shape coded (triangle and square). Make sure they are aligned properly.
Mar 28, 2008 | JBL CREATUREIIWHITE Computer Speakers
I have a set of Logitech speakers s150 USB and Ive had them for about over a year and about a few days ago they were working fine...but now they just won turn on. usually i just unplug them and replug them...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
you might have to get a portable usb sound card if you mean dont have a sound card installed
also try this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or
hope this helps
May 17, 2011 | Logitech S150 2 Speakers
My speakers were working fine and i unplugged everything to move them. When i plugged everything back in no sound. My computers speakers are working just fine but when i plug in the speakers no sound. I...
I suspect you have not plugged them back into the correct socket. The plug is coloured green and therefore should go back into the green socket. you have probably plugged it back into the blue or pink sockets. Use a torch to check that is in the green one.
May 04, 2011 | Harman Kardon SoundSticks II Computer...
I've tried three different sets of speakers and each time the left speaker will not work. I've also tried plugging in my headphones and my left headphone wont work. I've checked all the volume controls and...
Well the jack you plug in has three surfaces. So when you pulled it part way out then the left speaker part of the plug came in contact with the right speaker contact inside the jack and it worked. Speakers are good so if you have checked your volume control in Windows and checked that the balance control is centered it could be that your sound card is defective. You didn't tell me what kind of computer you have and if the sound card is built into the motherboard or if it is an add on card. I don't know if you only have the Window's sound control in Control Panel or if your card has a seperate software for configuring your card but I think the only thing that might disable the left speaker has to be the balance control in Window's sound control or the seperate software.
Nov 15, 2009 | JBL CREATURE II Computer Speakers
I've plugged in my speakers and the woofer but only the left speaker will play sound and its almost a whisper
Try to check for sound manager to check balance is on for both sides (left right) and wave balance is normal value. To call master volume just duble click system tray volume icon (next to clock) and check it.
Aug 03, 2009 | Logitech Z-340 Computer Speakers
Labtec LCS-2424 speakers: left speaker stopped working
I have the same problem sir, only the speaker with volume
control works. Earlier I used to twist the volume control this
way and that way to get the sound from the other speaker also.
Now the same technique doesn't work anymore.
Jun 27, 2009 | Labtec LCS 2424 Computer Speakers
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
Only one speaker working
Even I have faced the same problem for the past six months.. Today i have fixed only issue with the back jack.. removed slowly and fixed it tightly.. it's works. :)
Oct 06, 2007 | Harman Kardon HK206 Computer Speakers
Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Mar 13, 2007 | Logitech Z-2300 Computer Speakers
Altec Lansing VS4121 Computer Speakers Logo
295 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Gomez
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
