Hello>>
I have this Belkin N1Vision wireless router ever since feb. 2008.
It worked fine up until yesterday.. then it got into a loop trying to re-start . The boot up bar goes to aprox. 20% and then re-start againg in a loop.. If I use the reset button on the back , after 10 seconds it freezes and shows this message.."dowload mode..." any advise..???
Comments:
Jan 05, 2009
- Thanks to Ramboin and Pyledriver for your reply..
However, the real problemen have to to do with the fact that if I use the "reset button" instead of producing the factory setting, it freezes and shows the message "download mode..." on the router screen..
As far as the power socket , I also tried changing it and did not work anyway....
I guess this is someting more complicated that just pressing one button, but thanks for your comments..
Make sure that power cable is is connected properly i.e power switch is stable in the power socket ?? otherwise you will have to reset the settings by using reset button.
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
Unit came with PC2-6400U Memery. Can I mix this with PC2-6400 memory or will I have to only use...
(More)
Unit came with PC2-6400U Memery. Can I mix this with PC2-6400 memory or will I have to only use PC2-6400U to increase memory?
