Question about Reliance Water Heaters
Exhaust fan for Reliance StaKleen 802 PV water heater will not turn off. Solution?
Burner works, but fan will not turn off after burner turns off.
  • 74 Answers
SOURCE: AO Smith water heater won't fire.
I bet your thermo couple is bad or your ports are clogged? How old is the unit?
Posted on Apr 16, 2009
co7196
  • 3433 Answers
SOURCE: no hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
Posted on May 06, 2009
  • 297 Answers
SOURCE: I have a 6 gal Atwood hot water heater. I can
Kenny did you change the thermo coupler?
Posted on Jul 14, 2009
  • 587 Answers
SOURCE: I have a Rheem Classic Series Super Quiet 80 gas
Sounds like it could be a dirty or bad flame sensor.
When the burner lights ,there is a flame sensor in the flame and it is suppose to sense the flame and send a signal back to the control board which will keep the gas valve open, if it gets dirty or is bad it doesn't send the signal back to the board and the board will shut the gas valve off and after three tries it will lock out the furnace and you have to reset it to get it to work again.
The flame sensor looks like a wire and it's in the flame usually it will get gas deposits on it, then it won't work.
You can clean this sensor with an extra fine piece of steel wool, but before you attempt to do this DISCONNECT ALL POWER TO THE FURNACE.
Posted on Jan 05, 2010
SOURCE: Gas water heater: burner doesn't fire, replaced gas control valve
Hello,Don't worry about the rust flakes as every burner collects then and is normal.The new control should click.Please check incoming gas pressure supply 3.5"WC natural gas / 9"WC for LP.Check it at the piolt tube with a pressure dial meter,I assume the water temp now is cold.Did you change the thermocouple also as this provides the power to run the control?
Posted on Apr 22, 2010
Burner in Aliance 501 water heater keeps turning off after it heats up have to light pilot back on
if its getting gas and no drafts blowing it out. its a bad thermal coupling.if coupling is bad, it will put the flame out,as a safety feather to shut the gas off. good-day!
Nov 18, 2012 | RELIANCE ELECTRIC WATER HEATER
I have a Reliance gas 501 water heater model #5 40 PORT980. Yesterday, we had no warm water. I looked and the pilot lit was lit. I turned the temperature knob to very not and it lit the
Reliance
2nd and 3rd digit of serial number is year
C05 is 2005
What color is flame? Should be clear blue.
Pilot is burning so thermocouple is good, and sitting in pilot flame.
Pilot flame should be clear blue.
Otherwise clean burner parts.
Is water at tank hot??
If burner is not turning on, the gas control thermostat is probably bad.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Otherwise more information is needed.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Sep 19, 2012 | Reliance Water Heaters
The pilot stays lit but the burner won't light.
Its an ELECTRIC hot water heater yes?
No burner or pilot then hey!!
Mar 03, 2011 | RELIANCE ELECTRIC WATER HEATER
Describe your Reliance & 30 Gal LP
TURN OFF THE GAS VALVE AND WATER TO THE TANK REMOVE THE PIPES FOR THE DRAFT USE A SHOP VAC AND CLEAN THE DIRT AND DUST FROM THE INSIDE OF THE DUCT WORK ALSO WHERE THE BURNER IS LOCATED YOU CAN VACUME THERE ALSO AND REINSTALL THE DUCT TO THE FLUE
Aug 23, 2009 | Reliance & 30 Gal LP Gas Water Heater
BURNER TURNS OFF LAST THAN A MINUTE AND BLACK SMELLY EXHAUST FUMES
your flue is clogged need to clean it, and also need to clear the intake around the combustion chamber===burner
Jun 08, 2009 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
76 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
