Question about Kenmore 55693 Side by Side Refrigerator
Ice maker won't stop making ice
Frigidare bcm95
  • 135 Answers
If your shutoff arm stays up, the switch inside is bad. Usually have to replace the entire icemaker. Send model # from tag on fridge for part lookup. hope this helps!
Posted on Jan 05, 2009
BCM95 Ice Makers wiring diagram
Google: www.u-line.com/media/downloads/service/41921_service_manual.pdf, this is a PDF manual.
Sep 26, 2013 | Kitchen Appliances - Others
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
I have a frigidare electric stove. The oven got
Hi
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 26, 2010 | Frigidare GLEC30S8C 31 in. Electric...
Hello I have a frigidare upright freezer i want
You can't....most freezers have set position so air can rotate evenly for a reason.
Jul 15, 2010 | Freezers
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
How do I clean my oven
Get some easy off oven cleaner. Use gloves. Do not even clean as that tends to melt down expensive controls.
Jan 16, 2010 | Frigidare FED300E Electric Range
U-LINE BCM95 NOT CYCLING
These units take a full cycle to get to the fill cycle, so you won't get ice on the first cyle unless you manually fill the tray when you first power it on. You may have some air in the water line and need to cycle a few times to fully bleed the air out. Also check the water inlet for debris in the filter screen using a small brass brush, then bleed out air -with water on- while tightening back hose connection avoiding need to bleed while cycling. Lyle
Nov 11, 2008 | U-Line Icemaker
Frigidare model GLFU2067FW3 Deluxe temperature display flashes 'E' and set temperature every second and compressor runs continuously.
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 Access and save or print files: OWNERS GUIDE, and PARTS MANUAL. (Check in OWNERS GUIDE on pages 8-10 for basic trouble shooting.)
Step 6 save all PDF files to a new folder name it FRIGIDARE for easy availbility.
Sorry this is all the information that I have at this time.
Thank you and good luck.
Apr 27, 2008 | Frigidaire GLTF2940ES Front Load Washer
How to install a frigidare ice maker IM115.
the wires should be behind a cap that covers the hole for the water tube on the pack panel in the freezer.
Nov 19, 2007 | Refrigerators
Kenmore 55693 Side by Side Refrigerator Logo
156 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
