Question about General Electric DHDSR46EGWW Dryer
Ge dryer model #DHDSR46EE1WW. Dryer will not stay running
Timer seems to work. I turn the start dial; it starts, but won't stay running. If I hold the start button to the right it will continue to run.
2 Suggested Answers
  • 29 Answers
SOURCE: Ge dryer model #DHDSR46EE1WW. Dryer will not run
You most likely have a bad motor. Try to spin the dryer drum by hand with the door open, door swich held or taped down, and while pressing start. This will likely get the motor going. If this works try closing the door and starting it again. If it works now the motor may have just had a hard time starting do to it's position or the drum's postition. If it only works when you help it out manually you have a bad motor or maybe a sticky drum/jammed belt/etc. Good luck!
Posted on Apr 28, 2009
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
Dryer was making high pitched squealing noise and now won't run
Please supply the model number so we can help further.
May 20, 2012 | Hotpoint Dryers
DHDSr46ee1ww has new heating element and switch but will not start.
Have you checked the motor kill switch? Its located by the motor.When the belt comes off the idler pulley actuates this killing power to the machine. Sometimes the switch goes bad over time and needs to be changed. The part number is wd21x10261 and runs around $12
May 18, 2012 | Dryers
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
My amana DLG330RAW dryer won't stay on. it has a combo timer and start dial turn the dial to the timed settinG and push...dryer starts part way through the cycle, the dryer...
Hello PB,
What i would most suspect as being the problem of why the dryer just stops randomly before the cycle is done,is a problem with the door switch or the door catch...does the dryer restart as soon as you restart it?? if yes i would check that the door catch was broken so the door will pop open stopping the dryer. Also check the door switch using a meter set to measure ohms and see if the contact is burnt ( a good door switch will be zero ohms resistiance)
GENE
Sep 17, 2011 | Amana DLG330RAW Gas Dryer
Broken Start Knob
You can buy this switch from ap wagner for $24.50
Go here and put in your model number, and the parts list will come up
http://www.apwagner.com/
May 21, 2009 | GE Dryers
Ge dryer model #DHDSR46EE1WW. Dryer will not run- just makes loud humming noise. Replaced the start switch and it still will not run at all. PLEASE HELP!
Apr 28, 2009 | General Electric DHDSR46EGWW Dryer
General Electric DHDSR46EGWW Dryer Logo
51 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
