Question about Lexmark JetPrinter Z12 color InkJet
Blinking lights on a lexmark Z12
Both lights are blinking. I have looked and there is no paper jam
3 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: Blinking lights on Lexmark Z12 printer
Unfortunately, the Lexmark website is set up so I can't provide you with direct links to the workaround for these problems....
Go here: http://support.lexmark.com/perl/support/support.cgi
Do a search on "blinking flashing lights + Z12"
and try to follow the steps outlined in the troubleshooting guides that calls up.
This is the most likely candidate, but there are others that could cause this symptom:
Lights Flashing on the Printer ID: 241
Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed.
If the power light on the printer is blinking, you may have a carrier stall. To check this:
First unplug the printer.
Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
Once the cartridges have been moved across, you can clip them out.
Try to print without the cartridges in the carrier.
If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
I hope one of these options will provide you with the solution to your problem. If not, please write back with a report of what you tried and we will try to help you further.
If I have managed to answer your question or solve a problem, please take just a moment to rate this posting....thanks!
  • Test the cartridges one by one and do the printer hardware test (refer to the relevant document for your printer) to establish which one is defective. The defective cartridge needs to be changed.
  • If the power light on the printer is blinking, you may have a carrier stall. To check this:
    1. First unplug the printer.
    2. Move the cartridges to the left by hand. In order to do this, you need to grip the top of the carrier belt (a black/grey belt with cog-like teeth) and pull it towards the right-hand side of the printer.
    3. Once the cartridges have been moved across, you can clip them out.
    4. Try to print without the cartridges in the carrier.
    5. If you no longer have a carrier stall, put the cartridges back into the carrier and clip them into place.
Posted on Mar 28, 2009
  • 114 Answers
SOURCE: LEXMARK z12 IS PRINTING SAME LINE TWICE LIKE
uninstall/reinstall the printer software and drivers
Posted on Sep 14, 2009
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
Sep 04, 2014 | Lexmark E Office Equipment & Supplies
3 FLASHES POWER LIGHT COMMUNICATION PROBLEM
Power light blinks slowly
The printer is out of paper in the middle of a print job.
Load more paper. See "Loading paper" on page 20.
Power light blinks rapidly
There is a paper jam.
Clear the paper jam.
Aug 13, 2012 | Lexmark Z1300 InkJet Photo Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Sep 14, 2009 | Lexmark JetPrinter Z12 color InkJet
My printer sounds like it's printing, but the paper comes out bla
Most likely cause is the ink cartridge needs replacing / refilling. Did it stop printing part way through a page?
Aug 17, 2009 | Lexmark JetPrinter Z12 color InkJet
Mar 28, 2009 | Lexmark JetPrinter Z12 color InkJet
Lexmark, paper jams and prints in same place, over+++
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | Compaq Lexmark Color Jetprinter Z12 InkJet
Lexmark z12
You can download the driver here, directly from Lexmark:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Z12+Color+Jetprinter
NOTE: Lexmark does not have Windows Vista drivers for this model. However, it has been reported that Windows 2000 drivers work well on Vista.
Feb 11, 2008 | Lexmark Z12 Printer
Lexmark JetPrinter Z12 color InkJet Logo
20 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
