Question about Reddy Heater-30-55,000 BTU Variable
Reddy Heater 70 (Kerosene) won't start
I just purchased a 70000BTU Kerosone heater. I plug it in a 110v inverter that's connected to my car's 12v outlet.
When flipping the switch ON on the heater, the fan turns sporadically, starting and stopping all the time - no flame either.
I'm trying to start the heater in very cold weather and was wondering if temperature was a factor for Reddy Heaters, or if the inverter (a 300watts model) did not produce enough power (I'm thinking the Reddy Heater fan doesn't draw that much power ).
Any comments welcome.
Norman
  • 2 more comments
  • norman_godin Jan 10, 2009
    Thanks,
    I changed my 300w inverter for a 400watts model...same problem.
    How much power *is* required to start this thing ?
    (I do not have access to a regular 110v outlet in the field and I'm trying to avoid the purchase of a bulky gas generator).
    Insights ?
    Thanks a lot for your quick response.
    Guess I'll have to buy yet another inverter.
    Although the booklet's spec sections for my RC70ET says motor requires 2.8 amps for 'normal run'.
  • norman_godin Jan 12, 2009
    Problem solved.
    Needed to hookup inverter to my car's battery poles instead of 12v outlet (accessories) inside the car; which isn't powerful enough.
    Thanks
    Norman
  • 232 Answers
In the same temperature range that is giving you trouble, run an ext cord (110v) from a known good household circuit and plug the heater into the cord. If the heater runs OK, then the inverter is your problem.
Posted on Jan 07, 2009
  • Jerry Magee
    Jerry Magee Jan 10, 2009
    Look on the label on your heater. Amperage will be listed. Most of these heater require around 4 amps to start. Do the math. 4 amps x 120v = 480 watts. Go get a bigger inverter or do what I suggested- find house current.
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
I have a 24' travelaire 1989 rv. is there a switch to go from electrical hook up to battery operated lights in the camper
there is a power inverter,somewhere near the front of the trailer, RV Basics 12 Volt DC Systems
http://www.winnebagoind.com/resources/manuals/pdfs/Winnebago_Catalog.pdf
Atwood Mobile Products: 574-264-2131
Carefree of Colorado: 800-621-2617
Carriage Carpets (Shaw Flooring): 877-706-3054
CCI Controls: 800-521-5228
Coleman: 316-832-4357
Denso: call Fleetwood 800-322-8216
Dometic: 800-544-4881
Fantastic Vent: 800-521-0298
Generac: 888-GENERAC
Intellitec: 800-251-2408
Kidde Safety Products: 800-880-6788
Kwikee Products: 800-736-9961
Magic Chef 800-688-1120
Magnadyne: 800-638-3600
Norcold 800-543-1219
Onan: 800-888-6626
Power Gear: 800-334-471
Riverpark: 800-442-7717
Suburban: 423-775-2131
Suburban Dynatrail Furnace Manuals
Thetford: 800-521-3032
Velvac: 800-783-8871
Winegard: 800-288-8094
Xantrex (invertor/chargers and control panels )
http://www.rverscorner.com/wiring/index.html
Manuals 1989 older RVing The Midwest Connection
May 14, 2015 | Camper Vehicle Parts & Accessories
I purchased an Eljer "Emblem"
Congratulations.
Is this a fix question?
Dec 20, 2017 | Eljer Whirlpool In-Line Heater-...
Have an old 70000btu unit w/out tstat. Brand new motor. Sometimes unit fires right up when plugged in, but sometimes not. When not, there is a spark on the ignitor, but motor does not turn. Ideas?
There should be a short delay, about 5 secs, from the time you plug the unit in until the motor starts. If the start time is longer than that, it could be the electronic control board. A good source for parts and information is Croteau Enterprises 978-465-3221.
Jan 18, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
My Master 110,000 btu heater won't start after plugging it in. The tank is full of fuel. Any recommendations .
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 18, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
May 20, 2010 | Eliminator MotoMaster Mobile Power...
How to convert electricity from 110 to 220 volts for my SHARPE Microwave oven
Ah, the problem of the ages. There are 2 solutions. One is a transformer of the proper size, and the second is to purchase a heavy duty battery charger (that runs on 220 volts). Connect the red and black (+ and -) wires to a 12v to 110v voltage inverter, similar to what you would plug into a 12v auto 'cigarette lighter' socket to produce 110v current from a car battery. The charger turns the 220 vac to 12 vdc, and the inverter turns the 12 vdc into 110 vac. This works, as it is what I did when I moved from the US to England.
Feb 04, 2010 | Sharp R-230 Microwave Oven
Reddy Heater-30-55,000 BTU Variable Logo
280 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
