Question about Cooper Wiring Devices 6009W-K ROTARY DIMMER REPLACEMENT KNOB WHITE
How do I get off a rotary dimmer switch. The knob seems to be stuck
3 Suggested Answers
  • 22 Answers
SOURCE: replace dimmer switch with toggle
Both wires should be black because the switch interrupts or breaks the connection to the light. It doesn't matter which black wire goes where. Just be sure the power is OFF and then undo the dimmer switch (usually has wire nuts connecting the black leads) and then connect the wires to the new toggle switch.
Turn on the power and feel good about your work!
Posted on Jul 24, 2009
VtToolMan
  • 704 Answers
SOURCE: wiring dimmer to knob and tube
You should attach the green grounding wire to the metal box using a green grounding screw. You don't want to leave the wire loose, as any contact with the switch screws could cause a short.
Also, you should wrap the switch with at least 2-3 complete wraps of electrical tape to prevent the screws from contacting the sides of the wall box.
As a side note, you should likely have a complete check done on your house if you still have knob and tube wiring installed, as the dangers associated with this very old wiring are many. Typically, older K&T wiring was used in homes well over 60 years ago and houses then only had minimal electric current drawing devices, such as lights and a couple of other small appliance devices (toasters, coffee pot, TV and radio, etc.)
The problem with older homes with K&T wiring still in use, is that the circuits can be easily overloaded with modern electric convinences and lead to a possible fire situation, especially since there is no dedicated ground to help mitigate short circuits, etc. Also, the rubber based insulation used on this type of wiring deteriorates after 40 years (+/-) and rodents tend to chew on exposed wires in attics and crawl spaces.
I don't wish to alarm anyone, but as a Licensed Master Electrician, I've seen and done my share of repair work involving Knob & Tube wiring and even had a couple of homes that had a mix of it and other, newer wiring, that I've completely rewired. Many states require K&N wiring be replaced before a home can be sold, so getting a jump on it will make your home safer and better suited to operate all the devices that people tend to have, in today's society.
Hope you find this Very Helpful and best regards!
Posted on Sep 10, 2009
Knob falling off
More details are needed. If it is a rotary dimmer you can possibly spread the shaft tines a bit if it has them or find the clip that was holding the know on. Hot melt glue placed in the knob first then pressed on the shaft may work. Just do not over fill the hole.
Jan 29, 2014 | Schlage Electrical Supplies
I need a wiring diagram to wire two way dimmer switched in place of normal switches
Take off the 2 wires from the old switch... put on the 2 wires from the dimmer. the 3rd wire is a ground it is green put it on a ground screw at the back. If your switch has more wires it is likely a 3 way system and needs a 3 way switch instead.
Apr 04, 2013 | Cooper Wiring Devices 6009W-K ROTARY...
Did I break my dimmer knob?
You can get the knobs separately if you look. First check if the knob was a half circle or a serrated style, i think the replacements have an adapter to fit either style.
Jan 20, 2013 | Electrical Supplies
I have leviton 6681 dimmer switch. The full range of dimming full-on to full-off is about 1/4 turn of knob. Is this correct? It's connected to 4 incandescent bulbs for total 240 watts.
That range seems a little small, but I think still within reason. The reality is that dimmer manufacturers consider the basic rotary dimmer to be the red-headed step-child of their product offering. They offer it because they have to, not because they want to - and as such, typically dump as little money into the quality of the product as possible.
Mar 03, 2011 | Leviton Dimmer - 6681-A - Almond
My rotary dimmer doesn't switch 3-ways. I have to push the dimmer button to "on", then I can use the other switch to turn on/off.
You posted under Leviton rotary dimmer.
Lutron and Leviton have many 3-way dimmer styles, and both make 3-way rotary dimmers.
I remember years ago replacing 3-way switches with dimmers and having same experience as you. One dimmer has to be ON for the other dimmer to dim.
Later I learned when you replace both 3-way switches with dimmers, you buy a control-and-companion dimmer set. One dimmer is main, and it lets you dim from both locations. The two dimmers communicate with each other electronically. Buy these dimmers at lighting store that specializes in fixtures and dimmers. Ask for most experienced salesperson.
I checked to see if rotary dimmers are made in the companion set. And neither Leviton or Lutron show 3-way companion set rotary dimmers.
1) Leviton spec sheet on rotary 3-way dimmers does not show companion dimmer. This indicates that Leviton rotary dimmers don't have capability of communicating with each other.
2) Lutron has image of 3-way rotary dimmers.
Image shows single rotary dimmer in 3-way & 4-way circuit.
This tells me that Lutron does not have companion dimmer for 3-way rotary dimmer.
Nov 30, 2010 | Leviton Decora Rotary Dimmer 600-Watt SP...
Lutron Glyder Slide Dimmer GL-603P (new dimmer switch) on - off by pushing the button in center of knob -- pushing button does not turn dimmer on -- seems to be stuck in the off position -- is dimmer...
Sadly, yes, it just sounds like the switch got stuck. You should be able to yank that knob off and try to manually unlatch it with something thin and long (like a pencil) - just, do me a favor, and make sure whatever you use isn't conductive, there shouldn't be any exposed electrically, but just be safe about it.
If that doesn't work, call their tech support center at 1-800-523-9466 - they will most likely replace it for you.
Oct 04, 2010 | Lutron GL-603P Glyder 3-Way 600 Watts...
Rotary dimmer turns but won't click on? It was working up until half an hour ago. It just trns and turns. The light is off
probably the plastic knob is stripped out. pull it off and see if you can turn the dimmer by hand.. if so get a new knob.
Dec 28, 2009 | Electrical Supplies
Replace dimmer switch with toggle
Jul 24, 2009 | Cooper Wiring Devices 6009W-K ROTARY...
Light switching
At any hdwe store or home center there are dbl switches available in a standard toggle or rocker (as they are sometimes called) there will be two feed screws with a jumper so power only needs to be attached at one terminal, and two screws where power exits, one for each set of lights. There should be a wiring schematic included if a boxed switch is purchased. The cover plate that is used is also used for a dbl wall outlet.
Jun 22, 2009 | Cooper Wiring Devices 6009W-K ROTARY...
3 way dimmer switch ace 6443v-k only dims in one direction.
At the switch you have a common ( either a hot or a wire going to lt). And two Travelers( Wires going from one switch to the other) Make sure your not mixing one of the travelers up with the Common easy mistake happens all the time. Travelers are always in the the same at the other end of the 3w switch , you may need to take it apart and look. If you need further help send me more details I hope this helped
Dec 15, 2008 | Cooper Wiring Devices 6009W-K ROTARY...
Cooper Wiring Devices  6009W-K ROTARY DIMMER REPLACEMENT KNOB WHITE Logo
88 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
Steve
Dennis Boxerman
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
