Question about Whirlpool WED9050XW Dryer
Electric dryer model YWED9050xw1 is not heating.It is going through the cycle with no heat.the heating elemnet ,thermol cut-off and themistat is good.The status lights is not coming on.
  • 64 Answers
SOURCE: Whirlpool Duet Dryer not heating
The first thing to do would be to check if the element is broken. Most dryers have a couple of screws that hold the top, and it opens like the hood of a car. The next step is to remove the drum, usually a couple of screws holding the front.
Posted on Jul 20, 2008
  • 163 Answers
SOURCE: estate gas dryer model#TGDX640JQ2 running no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
danromarris
  • 101 Answers
SOURCE: My dryer wont heat up...It just blows cold air....?????
It may be the thermal fuse but it could also be the heating element. The way to check is to open it up as described above and run the dryer. Watch the element and if it turns on then off again immediately then it is your thermal fuse. That is only about 15 dollars to fix and you can get a new fuse at any appliance repair shop. If the element doesn't ever come on then the element is burnt out and needs to be replaced. This is a little more expensive. I hope this was helpful and if you have any more questions feel free to ask me. Good luck.
Posted on Jan 22, 2009
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
SOURCE: whirlpool dryer won't heat how can I fix?
Hey, I just read an article online titled, Testing for 240 Volts to Your Dryer - Without a Voltmeter, here's the link http://www.davesrepair.com/DIYhelp/DIY240Vtester.htm
I am not sure how you could test anything else though, such as the thermal fuse or thermostat, without the Volt/Ohm Meter. They are about $10 at any big box home store--we just went ahead and bought one.
Posted on May 31, 2009
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Dryer goes on and spins but no heat. I've opened up the back but what now? Is there a specific part that if blown would cut off the heat? Model is a small one - probably cost about $300 - don't know the...
The thermal cut-off at the top of the heater duct/housing blows when the high-limit thermostat below it fails to cycle the heating element on and off properly to regulate the heater temperature. This thermal cut-off along with high-limit thermostat including the cycling thermostat on the blower housing are wired in series with the heating element and power to it is cut when the thermal cut-off blows as a safety feature to prevent fire. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions in troubleshooting this problem.
Mar 11, 2011 | Roper REX4634KQ Electric Dryer
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 12, 2011 | Dryers
Dryers tumbles but there is no heat
The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components.
Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Also bypass the cycling thermostat if the dryer still doesn't heat with the thermal cut-off and the high-limit thermostat bypassed. Check the heating element visually for obvious broken or damaged coil. An ohmmeter will be of great help in checking the resistance/continuity of the heating element. Replace the heating element if broken or damaged, NEVER attempt to repair it.
The problem is likely in the motor centrifugal switch if the dryer still doesn't heat with good heating element and the three components above bypassed. Indicate the exact model number of the dryer should you need further assistance.
Dec 31, 2010 | Kenmore 600 6965 Electric Dryer
Heating elements gets very hot
check the air flow into the unit if clear and the outlet pipe is clear as well the dryer need to breath freely or it over heats till the thermol cut out shuts it off,,, but this may kill it off all together
Aug 07, 2010 | Whirlpool Dryers
NO HEAT
The electric dryer heating circuit is composed of the heating element, high-limit thermostat, thermal cut-off, cycling thermostat, timer, and centrifugal switch. Parts may vary depending on the make and model of the dryer; specify it for a more specific advice. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
The dryer will not heat when any of its components has failed. Check the continuity of the high-limit thermostat, thermal cut-off, cycling thermostat and the resistance of the heating element using a volt-ohmmeter. The heating element has a resistance range of 8 ohms to 12 ohms depending on the make and model of the dryer while the other three components must have zero resistances.
The timer and the centrifugal switch are less likely to cause a no heat problem and must only be checked when the components mentioned above are found to be in operating condition.
Again, specify the make and model of the dryer for a more specific advice.
Apr 11, 2010 | Dryers
Turns no heat continues to run? roper dryer model # red4340sq1
you need a Thermol fuse. This part is a non resetable fuse. you will need to replace it. it is located in the back of the dryer. you will need to take off the back panel. let me know if this helps
Oct 12, 2009 | Roper REX4634KQ Electric Dryer
Whirlpool dryer LE6810XS110 timer only works on air fluff and tumble press does not work on regular or perm. press
Check to see if the unit will heat up in the time dry. if the heater does not come on in the time dry cycle, then you will need to change the thermol fuse on the back of hte dryer.
Oct 10, 2009 | Whirlpool LER4634J Electric Dryer
My RGX4634KQ2 is not heating up and will not stop cycling
check the vent to see if it is restristed. if not you will need to change the thermol fuse in the back of the dryer.
Sep 20, 2009 | Roper REX4634KQ Electric Dryer
Whirlpool WED9050XW Dryer Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
