Question about Kenmore 700 6972 Dryer
How to get to thermal fuse on kenmore dryer 700
I have removed back panels before on a kenmore HD 70 series,but I cant see how to remove the back panel even with all the screw out.It seems tac welded to the dryer body?
SOURCE: Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Posted on Oct 07, 2008
docjohn174
  • 943 Answers
SOURCE: Thermal fuse kenmore 70 series dryer
HI thanks for your question. the thermal fuse is located at the back of the dryer. remove back panel. thermal fuse is located on the air duct. on the left. a small plastic peace with 2 blue wires to it. replace this part. also clean all venting. this could cause the thermal fuse to fail. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 11, 2008
danromarris
  • 101 Answers
SOURCE: My Kenmore 90 series dryer won't heat
The thermal fuse is going to be located on the heating element housing. When you take off the front panel you will see your lint screen housing. You will need to remove that to get to the element housing. Once that's out of the way the thermal fuse should be right on top of the housing. It is small and has two small wires coming off of it. The wires should be different colors. Just don't get it mixed up with the thermostat. Just match it up with the new one that you have. It is held in place with two small screws. Let me know if you have any other questions or still can't find it, also let me know if this was helpful. Good luck and glad to help out.
Posted on Jan 22, 2009
Sea Breeze
  • 4654 Answers
SOURCE: how to remove front panel from kenmore 90 series gas dryer
Gently pry top of dryer in front corner area. Disconnect door switch inside front. Remove 2 sheet metal screws from inside front. Let me know, Thanks, Sea Breeze
Posted on Mar 21, 2009
mark_37388
  • 100 Answers
SOURCE: I NEED TO REMOVE THE FRONT PANEL OF MY KENMORE 8 SERIES GAS DRYER
One of two ways depending on oh made this unit GE or WPL FIRST look at the top of the door opening for two screws if there is no screws get a flat head screw drive and look with a flash light between the top and front pane you should see a clip about 2 inches from the sides going tworge the middle use a flat screwdriver place in the crack between the top and front panel and hit the back of the screwdriver with you hand should push the clip back an the top pop up do the same onthe other side (before you start if you lent filter goes in the top of the dryer remove the two screws holding that down to remove the front in the side panel going into the front is a screw on both side remove then lift the front up too unclip the bottom clips good luck.
Posted on Mar 30, 2009
Kenmore 70 series electric dryer won't start
There is a thermal fuse (start fuse) located in the back of the machine. Remove the screws from the back panel all the way around. UNPLUG DRYER FIRST, if you look towards the bottom on the left side you should see a little white fuse about 2" long you can ohm this out to see if it's good (remove both wires before you put your meter on it. 99% of the time thats the only problem. If you do not have a meter you can remove the fuse with a 1/4" nut driver and take it to your local appliance parts store and they can check it or just replace it as they are a very inexspensive part. This should take care of the start problem. Good Luck!
Jul 31, 2015 | Kenmore Dryers
Kenmore dryer 70 series
Check the vent for clogs and kinks. Could be something in the blower wheel causing the noise and blocking the vent.
Remove the vent from the back of the dryer, unplug the dryer, and reach inside the dryer vent to check for items lodged in the blower housing.
Feb 04, 2014 | Dryers
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
My dryer stoped working it is a Kenmore 70 series model #110.66712694 What do i check first
if you mean wont start do this : unplug dryer, remove back panel, look for a white part with2 connectors on the blower housing and remove one, using a continuity or ohmmeter put across the leads and if you hear no sound or see no reading in meterreplace that part. is the thermal fuse. this is the most common problem forthat failure.
Feb 14, 2011 | Kenmore Dryers
Kenmore 70 series electric dryer not coming on
next time send the model number,if it's not starting unplug the dryer,on top of the blower wheel housing there will be a thermal fuse,if the filter is on top it's behind the back panel of the dryer,if the filter is inside it's in the front of the dryer,it will be near the duct that the lint filter slides into,you need to remove at least one of the wires before you read it out with a meter,it will be a 3392519 or a 3390719,these are the two most used thermal fuses.let me know what you find,if it is the fuse most likely you need to clean out the dryer.blow out the vent line i use a leaf blower if it's long,clean out the duct that the lint filter slides into and vac out the inside of dryer where the motor is
Apr 23, 2010 | Kenmore Dryers
I have a 70 series. It runs but will not
most likely a fuse ,remove the back and you will see the heater box to your right,it is the smaller fuse on the box,most people replace both,you can get it at your local appliance parts store it is called a thermal kit,the model number is inside the dryer door-mike
Feb 06, 2010 | Kenmore 64742 Electric Dryer
Kenmore 70 Series Dryer Model# 110.64742400
check the thermal fuse if it is blown also change the high limit thermal cut-off fuse www.repairclinic.com shows your parts. go there and enter model number. Also check the heat element. to get into it remove the lint filter and the two screws you'll see there then pry the top up at the front corners. And through the back you should find the heat element and blower housing and thermal fuse and high limit fuse and cycling thermostat.
Apr 06, 2009 | Kenmore 64742 Electric Dryer
The kenmore series 70 dryer stopped running aand i can't get it
Unplug the dryer.
Remove the rear panel and check the thermal fuse attached to the left side exhaust vent. The fuse is 1 and 1/2 inches long by 1/2 inch wide and white in color.
No continuity on a volt meter is a bad fuse. Replace it.
Apr 05, 2009 | Kenmore 73952 Gas Dryer
Aug 22, 2008 | Kenmore 659 Electric Dryer
Apr 29, 2008 | Kenmore 63942 Dryer
Kenmore 700 6972 Dryer Logo
118 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
