How to change a drain hose on an electrolux ew1280f washing machine
  • 154 Answers
SOURCE: Washing machine not draining
If you are confident you can do it pull your pump off washing machine and pull the pump houseing apart most will come apart and make sure there is nothing in the pump maybe a small piece of plastic or other item in it. you could also try taking the hoses off the pump and just flush water through it backwards this will also sometimes work I have come across this a lot and normally it is something in the pump interupting the water flow. There may also be sand or small pebbles in the drain holes under the adgitator if flushing the pump doesn't help check under the adgitator for something in the holes. Hope this helps
Posted on Jul 21, 2008
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Posted on Jan 21, 2010
SOURCE: error code E20 electrolux washing machine EW1280F
• E10 = there is no water filling • E20 = the water is not drained • E40 = door open
Download Manual - http://laundry.manualsonline.com/manuals/mfg/electrolux/ew_1280f.html
Posted on Feb 15, 2010
  • 353 Answers
SOURCE: LG front load washing machine - need to replace drain hose
It's jusy one clip go in from the bottom
Posted on Mar 20, 2010
marka19
  • 1430 Answers
SOURCE: replace drain hose on mod LW6501W2 washing machine
Enter model # at www.appliancehelponline.com for diagrams and illustrations.
Posted on Apr 09, 2010
I have a EIFLW55HIWO Electrolux Washing Machine that leaks from the inside of the cabinet. How do I get into it and what should I look for? Thank You for any help you can give me.
I'd check if the drain hose is secure, although I'm not exactly sure what cabinet u are talking about. When the machine drains the water, it kind of shoots it out, not a lot, but enough for the water to spill if the hose isn't well secured. Also, I'd check if the hose is damaged in any places. But to ur best knowledge, where does it look like the water is coming from?
Jun 03, 2015 | Electrolux Washing Machines
Machine is stuck on drain
You did not specify which model of the washing machine you have. It can be:
- a blocked drain pump, filter, drain hose..... and the pressure switch can not switch to "empty" position.
- faulty pressure switch
- activated anti-flooding device
Dado
Sep 01, 2014 | Electrolux Washing Machines
What is the problem why water does not drain after rinse cycle?
Hello friend, thanks for your post!
I understand that your Electrolux washer is not draining properly. Some possibilities for your washer not draining could be an issue with the drain pump or control panel. You should additionally check the drain hose to make sure there are no restrictions. If your washer continues to not drain properly you should seek assistance from a professional to repair the appliance. I hope this is helpful. -Matt
Aug 12, 2014 | Electrolux Washing Machines
Water leaks during the wash cycle
Frigidaire by electrolux leaks. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 07, 2013 | Washing Machines
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
Hi, Our Electrolux EWF1083 is not spinning and ...
Hello,E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
The drain pump may be blocke.check www.serviceforce.co.uk
Thanks
May 19, 2010 | Washing Machines
Error code E20 electrolux washing machine EW1280F
Feb 04, 2010 | Electrolux Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
