Question about ASUS P7H55-M LX Motherboard
ASUS P7H55-M LX frequently shutdown and start again
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Asus p7h55-m lx Trying to
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 29, 2011
Shutdown is not properly, automatically restart
check your front panel for the right jumpers
Jan 21, 2014 | ASUS P5G41TM LX Motherboard
Asus P7H55-m\csm nic shut off when instalin W-7 updates
Hello here is the homepage:
http://usa.asus.com/Motherboards/Intel_Socket_1156/P7H55MCSM/#download
You first have to make sure, ALL the mainboard drivers is installed.
Especialy the graphic driver.
Please select your windows system, and install the drivers needed.
Any file from here, needs to be unziped before you install the driver.
Good luck
Mar 15, 2013 | ASUS P7H55-M/CSM Motherboard
Asus p7h55-m black screen when i installed video card.. then i thought my video card is not functioning.. i get it and use on board vga.. its the same problem.. black screen, keyboard no light.. no si
Have you tried removing the new video card? Try that first.
The fact that your keyboard doesn't light most likely means that either your power supply is being pulled down by the video card or is now gone. Was your power supply rated high enough wattage for your computer with the new video card? If the video card was higher-end then it's possible that it killed the supply.
It could also be the motherboard that's gone. Static discharge when putting the video card in, or a bad video card can destroy a motherboard.
May 31, 2012 | ASUS P7H55-M LX Motherboard
Hi, i just bought and installed a p7h55m lx motherboard and all the internal connection were all done but there is no signal coming from the vga on-board to the monitor?what might be the things I miss in...
Make sure you have the VGA cable plugged into the video card if you have one. Also, make sure you have the 24 pin power connector connected to the motherboard as well as the 12v rail (should be a 4 or 8 pin connector that plugs in to the top right of the motherboard when looking at it right side up.
May 08, 2011 | ASUS P7H55-M LX Motherboard
Asus p7h55-m lx Trying to load server 2003. System starts to load at about 36 minutes left system shuts down and re boots tried New mb New chip New memory Call ASIs support they d Couldn't help...
hope this helps
Mar 29, 2011 | ASUS P7H55-M LX Motherboard
I need driver for windows 2000 for ASUS P7H55-M LX
On this page: http://support.asus.com/download/download.aspx Type your model ( )in the search box and click to Search info. Select your model (click on it) andyou redirect to download page. If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 10, 2011 | Computers & Internet
I have recently used an ASUS P7H55-M/CSM motherboard with an i3-core processor--both new for this build. Unfortunately, I don't seem to get a video signal (tried 3 different monitors, including HDMI and...
did you check to see if there is a connection not plugged in or a jumper setting causing the conflict. also depending on what your using the pc for (especially graphics) you might want to install a video card.
Jan 16, 2011 | ASUS P7H55-M/CSM Motherboard
ASUS P7H55-M LX Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
