Question about Compaq Presario 700 470024-192 Notebook
No Sound I have the volume turned all the way up but I have no sound.
  • emenez20 Jan 05, 2009
    It is the Presario C727US Notebook PC
  • sophia38
    sophia38 May 11, 2010
    Hi
    What Operating system are you running?
    Have you recently rebooted your computer?
    The driver is probably missing.
    Sophia
    Scholar:
  • 83 Answers
Hi
We need to know the type of OS you are using?
If its Windows, type "dxdiag" in the sun command .
1. click the start button
2.click the let mouse pointing the run command.
3. type dxdiag
4. the go to sound toolbar. Check if there are any hardware installed.
5. If none you need to download the driver. Here are suggested websites in order for you to search the audio driver.
1.http://compaq-solution.tk/
2.
http://thisisfordevices.blogspot.com/search/label/Compaq%20Presario%20700%20%28470024-192%29%20PC%20Notebook
http://www.fixya.com/support/p357906-compaq_presario_700_470024_192_pc/solutions/page-5
Try to reply to me if still your problem was not solved to give you more solution.
Thanks.
Jonags3
Posted on Jan 05, 2009
Kenwood KA 995 amp. volume control, as you increase or decrease the sound, a loud clicking sound is heard.
Katrina, this sounds like a dirty potentiometer (volume control knob). Try turning the unit off, and exercising the knob. That means turn it full turns, many times, like 70 times. Then try it again with power. Sometimes this helps.
Sep 21, 2016 | Kenwood Audio Players & Recorders
Tip
Troubleshooting Laptop Sound Problems - No Audio Output
Symptom:
Can't hear any sound out of my laptop.
Diagnosis & Solution:
If you can't get any sound out of your laptop, the most likely cause is the volume being turned down or muted. Newer laptops monitor the external sound control so when the volume is turned up or down manually, the volume control in the operating system tracks right along with it. But with some laptops, especially those with external dial volume controls rather than toggles, the volume dials are independent of the software volume control and can't be monitored in software. In this case, if the volume dial is turned down on the outside of the laptop, the sound is turned off and nothing can be done in the operating system to change that. The only way to get the sound back is to turn up the external volume dial control.
If you have checked the external volume control on the laptop and the standard laptop volume slider in the operating system (the little speaker icon in Windows system tray) & you still can't get any sound out of the laptop, then the next step would be to check for any other software volume controls. Depending on the software installed and what you are trying to do, there may still be multiple volume controls and mixer panels scattered about the operating system. If the wrong channel is muted or turned down all the way in one of these independent controls, the laptop will not produce sound.
Most of the time, the first sign most laptop users get that their audio isn't working is the absence of operating system sounds, like the Windows rush on start up, or chimes with e-mail activity. Of course, these sounds can be turned off by design as well, through the Sounds option in Windows Control Panel. So, before looking at hardware problems, make sure these sounds are not turned off.
If you try to play an audio CD and the media player shows that the song is progressing but you can't get any sound out of the laptop speakers, odds are that the volume is turned down or muted. But it could also be due to an onboard sound hardware failure. If you are confident the volume is turned on in all possible locations and you've checked Windows Device Manager for a report of a hardware failure, try listening through headphones. If the headphones work, the wiring to the internal speakers has broken or come loose. Wiring failure is only likely if the speakers are in the lid and therefore wired through the hinges.
If you don't get any sound out of the headphones & you haven't missed a "mute" being checked off somewhere in software controls, then it really is a hardware failure. If the problem is with all sounds, including Windows chimes, internet radio, etc, then the problem is that the integrated sound processor has failed. In this case, unless the sound system is on a daughter card, it means the fix would require replacing the motherboard. But if the only thing you can't do is play audio CD's, then the problem is that the output from the DVD/CD player is muted or not getting to the amplification stage.
In modern laptops the DVD/CD players feature Digital Audio Extraction (DAE) which means that music CDs can be read digitally & the data passed to the built-in sound card or an external sound card replacement for processing, amplification then output. If there's a problem with the DVD/CD connector or if the wiring has been damaged, the music CD may get spun around without the sound making it to the sound card. The DAE output chip rarely fails on the CD/DVD drive, but the connector can fail. Make sure that digital playback is enabled in the properties tab of the drive in Device Manager.
You can replace your built-in laptop sound card with a PC card, with a USB sound card or USB speakers. These replacements make good workarounds if the integrated audio system fails. They also bring with them a whole new level of software with more volume controls, which are integrated with the existing operating system software. When shopping for replacement sound cards, keep in mind that USB solutions are much cheaper than PC cards. Also, when purchasing USB speakers to replace the laptop's sound system, don't buy speakers advertised as "USB powered". The "USB powered" speakers only draw their power from the USB port, they still need to be plugged into a regular audio jack to output any sound.
Please Vote for this Tip if you found it helpful.
M. Omran
on Nov 03, 2010 | Computers & Internet
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Different volumes on different inputs When I'm
Some TV's have sound adjustment settings for outputs such as HDMI. It might be turned down. If you have an optical connections on both TV and sound system you will get better sound with that.
Jan 24, 2018 | Yamaha HTR-5740 Receiver
Sound braking up in windows media
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Volume problems on computers often happen for a variety of reasons. Volume troubleshooting, however, is one of the easiest problems to troubleshoot because there are only a few things that usually cause the problems. Usually the problem isn't even an error but just merely an adjustment that needs to be made. Test your speakers. This is the first thing you should check if you can't hear anything coming out of your computer. First try turning up the volume know and make sure you are in fact turning the volume knob and not a tone or balance knob. Make sure the speakers are completely plugged in to the wall and the computer. Test with another set of speakers or headphones after you have done this. Check the computer volume level. On the taskbar is a volume icon, which usually looks like a small speaker. Click on the icon and turn the volume up. Make sure it has not been muted. Double clicking on the icon will bring up a panel of several volume controls. Try turning up the volume on each slider. Go to Control Panel and choose "Sounds and Audio Devices." Under the volume tab, click speaker volume and turn up the level if needed. Turn up the application volume. Most programs that use sound have an additional volume control just for that program. Find the volume control and turn it up. Usually it is located in the lower right or left corner on the program, but you may have to search for it. Troubleshoot the sound card. Download the latest drivers from your sound card manufacturer's website. Go to Control panel > System > Hardware > Device Manager. Click on "Sound, Video and Game Controllers." Click on your sound card, select the driver tab and then click on "Update Driver." Point to the file where you saved the latest drivers from the website. After this, restart your computer. The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity clean your computer of dust using a can of compressed air or fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer If this doesn't solve your problem, try reseating the sound card into your computer. Hope this helps.
Jan 07, 2013 | Microsoft Windows XP Home Edition
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
I have a huge problem with these headphones (the Sennheiser HDR 120)... and my wife bought two of them... They have great sound on the computer, but once the green light turns off on the base? There...
The volume of the sound source (Mac) must be sufficient, otherwise the transmitter automatically turns off. Turn up the volume on the Mac, and turn down the volume on the headphones. There is no way to disable the Automatic On/Off function of the transmitter.
Aug 12, 2011 | Sennheiser RS 120 Consumer Headphones
Tv + converter box = no sound
Try these steps: Turn the volume on your converter box all the way down. Turn the volume on your TV up to ½ way. Now turn up the volume on your converter box until it is at a comfortable level. More information at http://www.ezdigitaltv.com/index.html
Mar 31, 2009 | Sansui CDVD1310 13" TV/DVD
MPVR+ CB Picture Sound
I have this camera and unfortunately there doesn't seem to be a way to turn that sound off. It's odd because I have an IS-DV2+ also and if I turn the volume all the way down, that sound is muted as welll. I don't know what goes on at Aiptek...
Dec 14, 2007 | Aiptek MPVR Digital Camera
Volume
Hi the volume is just a big fuzzy sound. You can listen to anything. Mute button does work and volume adjustment does work. No Sound at all other than fuzzy sound.
Jan 07, 2007 | RCA 32F531T 32" TV
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
