Question about RCA R52WH73 Projection Television
TV turns itself off
Recently my TV started turning itself off. ANd we can't turn it on again for an hour or more. We had someone come and look at it and he wanted to charge us $250 to take out some sort of plate with a microchip or something and then hd' bring it back the next day and install it again. He said with this model it has done this before and it usually happens when the tv gets moved around a lot (example: it happened once before when we moved from out of state and we still had a warranty on it and got it fixed. Then a year later we installed a new cable system and the tv had to get moved and again just a few weeks ago we installed an XBOX).
Any advice?
  • RCA Master
  • 5,138 Answers
If you can solder i can help you fix it yourself ! On Deflection board there is 3 capacitors cp150 2200uf 16v if it is puffed up on top it is Bad other 2 220uf 35v cp114,cp120 they are green with gold writing on them Deflection board is First board to left on bottom/ board to right is SSB board this has your turners on it. Also CK second ribbon connector that connects from deflection to SSb board. Id say its Bad Capacitors on deflection board. Thats why set takes time to come back on it will finally get to where it will not come on.
Posted on Jan 08, 2009
TV just shuts off randomly. Any idea what the problem might be?
The door switch of some of these units caused that problem. see following web site: http://www.amazon.com/AA41-0756C-Switch-Sensor-SAMSUNG-HLP4663W/dp/B00NH49Y4E
May also be the lamp itself
Apr 09, 2015 | Samsung Televison & Video
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
Tv continuely shuts off
When it shuts down notice what light is lit , what color and is it solid or blinking. Respond to this same post for assistance and I will assist you with the issue.
Jan 01, 2013 | Mitsubishi WD-60737 60 in. HDTV
I have an LG 50PS8000 plasma tv which is nearly 2 years old. For the last few months its has occassionally been getting a red haze over the entire screen which either dissapeared on its own or went if you...
I've also had a popping noise on our 50" LG plasma TV, however the picture has not gone, but has turned grainy and colors are weird. Can this also be a blown fuse or a more severe problem (ysus board or similar)?
Apr 08, 2011 | LG 42LC2D 42 in. LCD HDTV
Picture goes out - but has sound
i have had this problem on one of my tv s all i did was remove the back of the tv and re-solder all the joints around the tuner (thats where the arieal goes) they go with time because the joints there get so hot . hope this helps
puggy
Jul 07, 2009 | Televison & Video
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV turns on and off by itself
you need change memory ic 24C08 near microprosessor.
Oct 10, 2007 | RCA 27F530T 27" TV
KV 27S65 Sony Trinitron 27"
So far you have done all you can and you have done everything right. The fact that the TV turned off by itself and then turned back on by itself suggests that one or more solder joints have come loose inside the set. A qualified tech should find this easy to fix, and Sony sets are always worth repairing, so it is now time to have the set serviced by a tech experienced in Sony standard sets.
Sep 01, 2007 | Sony KV-36XBR400 36" TV
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
RCA R52WH73 Projection Television Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
