Question about Kenmore Washing Machines
Washing maching leaks
When i tried to remove my washers pump, i thought you just pulled it off but it wouldnt come off so i wedged a screwdriver to try to get it off and looks like there is a small seal on the pump on the shaft that isnt allowing it to come off. I pushed it back on in original position and couldnt see it anymore, it spins, drains, but leaks and when it stops the drum sounds like water was still in there but cant see it in the drum. so what did i do and it has a steady leak coming off the motor where the pump meets. its old kenmore washer with one dial. 110
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
You need to replace the pump. Here is the correct pump for that washer.
Posted on Nov 07, 2012
SOURCE: Frigidaire washer won't wash
checking brushes can normally be done in situ. you will need a simple multimeter to put across brushes to check continuity but disconnect wires to brushes before doing this. worn brushes would normally cause no motor rotation at all.
replacing brushes can sometimes be done in situ but often it is easier to get the motor out.
Posted on Oct 12, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: Lady Kenmore 90 series not spinning or draining, leaking
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore washer dryer combo leaks water under drum from shaft
Rear Tub Bearing Replacement
This advice is for replacing the rear wash tub shell of most FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud "rumbling" type noise during the spin cycle, excessively vibrates, or won't spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
DISASSEMBLY:
1. Unplug washer and turn off water supply.
2. Disconnect washer inlet supply lines and remove drain hose from standpipe.
3. Using a shop vac, pull a vacuum on the drain hose to remove all residual water from the drain lines, tub and drain pump. If you do not own a shop vac, remove the lower panel under the door and locate the drain pump. If the drain pump has a clean out trap, lay out some old towels, and open the trap to allow water to drain. If the pump does not have a drain trap, disconnect one of the drain pump hoses.
4. Remove the lower panel under the door (if you haven't done so in the previous step) and remove the washer top and back panels.
5. Disconnect the dispenser hose from the top of the wash tub and disconnect the hose on the side of the tub going to the pressure switch.
6. Remove the hose that leads from the bottom of the wash tub to the drain pump and remove the drain hose that leads to the standpipe.
7. Remove the door bellow (rubber door boot) from the door frame ONLY and push inside the tub. Leave the other end of the door boot attached to the tub shell. If this is a small front loader, the bellow is cemented to the washer door frame. Use a putty knife to slowly peel the rubber from the door facing. If this is a large HE or Duet model, the bellow is held in place by a small hoop spring. It is located in the seam of the bellow along the door frame at the six o'clock position. Pull the spring out and carefully stretch it apart to remove the hoop from the seam. With the hoop removed, the bellow can be pushed inside the wash tub. Remember to remove the bellow from the water inlet tube that leads from the dispenser.
8. Remove the washer support shocks from the wash tub. The large HE model and Duet models are removed by grasping the upper portion of the shock and turning counter-clockwise. The shock will snap loose and can be pushed aside. Leave the lower portion installed in the bottom of the washer. If this is a small front loader, the shocks are held in place by plastic pins. The pins have a locking tab that needs to be compressed while pushing the pin out of the hole. This is NOT any easy task and it will take some effort. HINT: If you use a long socket that fits snugly over the pointed end of the plastic pins, it will compress the locking tab and enable you to use a hammer to carefully tap them free. NOTE: Large HE models and Duets have 4 shocks, while the smaller models may only have 2.
9. Remove the Drive Motor belt by grasping it near the top and pulling towards you while rotating the large pulley. The belt should slip off.
10. Remove the Drive Motor and Motor Control Board. Carefully label all connections, so you know here the go when have to re-install them.
11. Remove the back casing brackets so the entire back of the washer is open.
12. Remove the rear counter weight from the wash tub to minimize some of the weight.
13. This next step may require two persons: With the tub still suspended by the upper support springs, slowly lay the washer all the way on its back while supporting the wash tub. NOTE: Place something under the washer to support the tub shaft as you lay the washer back (i.e., old blankets, cardboard boxes, etc.) Once the washer is lying down, remove the upper support springs and set the cabinet upright. The wash tub should be now free from the washer cabinet.
14. Set the wash tub assembly upright and remove all the screws around the perimeter of the tub shell halves. NOTE: An electric screw driver with socket attachment works wonders and will speed up this process. If the tub is held together with clips, use a screwdriver along the tub edge under each clip and pry up to remove.
15. NOTE: If you plan on reusing the door bellow, use care not to damage any of the rubber. Place some old towels down and lay the wash tub assembly with the front opening face down. Lift the rear shell off the inner wash basket shaft. You can now inspect the spider arm supports of the spin basket. If the supports are cracked or broken, or if the shaft is worn, you will need to replace the spinner basket.
16. Remove the spinner basket assembly and inspect the front tub shell. In most cases the front shell can be reused and will not require replacement. If the inside of the front shell is damaged, however, it will require replacement.
REASSEMBLY:
1. Reassembling the tub shell parts and inner spin basket is self-explanatory. Just make sure you tighten all screws evenly in a crossing pattern as you tighten the tub shells. If the tub is held together with clips, they can be tapped back into place with a hammer. Use the same crossing pattern to ensure the shells are tightened evenly.
2. Lay the assembled tub shell with the opening face up. Make sure you support the spin basket shaft.
3. Lay the washer casing down over top the washer tub shell.
4. Insert the upper shell support springs into the wash tub and support spring brackets.
5. Raise the washer casing to the upright position, making sure the tub does not swing forward into the washer front. Re-install the rear counter-weight and washer back brackets.
6. Re-install the washer support shocks.
7. Re-install the drain line hose.
8. Re-install the Motor Control Unit and Drive Motor.
9. Re-install the Drive Belt pulley and belt. The belt is installed by placing it into the Drive Motor shaft, first. Make sure there is a one-groove gap between the belt and the end of the drive shaft. With your left hand hold the belt on the drive pulley and guide it around as you turn the pulley with your right hand in a clockwise direction. This can take some effort.
10. Re-install the hoses that lead from the bottom of the wash tub to the drain pump, and pressure switch.
11. Re-insert the water inlet tube into the rubber door bellow, ensuring the rubber is seated past the flange on the tube.
12. Pull the door bellow through the door frame opening and reseat it. If this is a small model front loader the door bellow will have to be cemented back in place with appliance door gasket adhesive. If this is a larger model front loader that has a hoop spring to hold the bellow in place, insert as follows:
- Place the hoop into the groove of the door bellow along the facing of the door frame with the spring in the 6 o'clock position.
- With both hands gradually work your way around to the 4 and 8 o'clock positions and stretch the spring apart.
- Push the spring and hoop into the groove.
NOTE: It may require a second person to get the door bellow back in place.
1. Re-install the rubber dispenser hose to the top of the wash tub.
2. Re-install back panel and top panel and hook washer back up to water source. Make sure the drain hose is placed back in the standpipe.
3. Leave the bottom washer panel off and plug unit back in. Test operate and check for leaks. If no leaks are present, re-install bottom panel.
Some other parts that may have to be considered when performing a rear tub shell replacement:
- Rubber Door Bellow
- Spinner Basket (if arm supports are damaged)
- Front Tub Shell (if signs of internal damage)
- Drive Pulley (can sometimes become damaged trying to remove old one)
- Drive Belt (check belt during parts removal for wear)
- Wash Tub Support Shocks (The shocks can sometimes break when trying to remove)
NOTE: 1. If you replace the front tub shell you will need to remove the door bellow and front counter-weights and install them on the new shell. 2. If you replace the spinner basket, some do not come with the wash tub fins. Make sure you remove and re-install the old ones in the new tub if required.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
  • 472 Answers
SOURCE: Clothing jammed front of washer and pulled front
have you tried unplugging unit for a couple of minutes to reset? if so it is possible the motor control got wet and this could be the culprit. there are also some wiring around the front of unit are we positive nothing got disconnected... let me know
Posted on Dec 31, 2010
Kenmore Elite HE 4t front load washing machine leaking water bottom right bottom at the end of wash
Unplug the power cord from the electrical outlet. Pull the machine far enough from the wall to get behind it to work
Use a putty knife to pry up and remove the end caps from the control panel. Remove the retaining screws from the control panel with a Phillips screwdriver.
Lift the control panel, and push it toward the back of the appliance. Unplug the wiring harness from the control panel. Remove the retaining clips using a flat-tip screwdriver to release them from the cabinet. Tilt the cabinet of the washer away from the frame, and set it aside.
Remove the pump retaining clips using a flat-tip screwdriver. Pull the pump from the motor shaft. Release the hose clamps using a pair of pliers, and pull the hoses from the drain pump.
Connect the hoses to the new drain pump using a pair of pliers. Place the pump on the motor shaft, and secure it with the retaining clips.
Set the cabinet in place on the washing machine frame, and install the retaining clips with the flat-tip screwdriver. Plug the wiring harness into the control panel. Close the control panel by pulling it forward, and install the retaining screws using a Phillips screwdriver. Install the end caps on the control panel, and push firmly to lock them into place.
Plug the power cord into the electrical outlet. Push the washing machine into place against the wall.
Custom Car Parts
Jun 06, 2012 | Kenmore Washing Machines
Leaking water from the front of the washer checked the hoses and they are not leaking
If this is a top load washer the problem is usually the pump. If you can tilt the washer up at the front and support with two pieces of 2x4. Shine a light under the maching and take a mirror to observe. Fill the washer 1/2 full of water and advance the time into the spin cycle. Observe under the maching to see where it is leaking. The pump is located at the front of the washer. If the pump is leaking, replace the pump.
Dec 29, 2009 | Kenmore Washing Machines
Water leaks from washer after rinse or draining
Hello, the most likely cause is the pump. Whirlpool's and Kenmore's are direct drive machines which means they do not have a belt. The pump is hooked up directly to the motor. To confirm this is the pump tip the machine back so that you can access it underneath. Make sure you wedge something underneath so it does not fall on you. Next take a look where the pump joins onto the motor shaft, this is where you will find the leak. This pump is a sealed unit so you will have to replace the whole pump. You can do this by removing the inlet and outlet pipes. Next with a screwdriver release the 2 clips holding the pump and remove the pump.....reassemble with new pump in reverse order. Good Luck!! If you have any further question's please feel free to comment. Mike
Oct 10, 2009 | Kenmore Washing Machines
Washer is leaking, but I dont know why
Hello, the most likely cause is the pump. Whirlpools are direct drive machines which means they do not have a belt2.gif. The pump is hooked up directly to the motor. To confirm this is the pump tip the machine back so that you can access it underneath. Make sure you wedge something underneath so it does not fall on you. Next take a look where the pump joins onto the motor shaft, this is where you will find the leak. This pump is a sealed unit so you will have to replace the whole pump. You can do this by removing the inlet and outlet pipes. Next with a screwdriver release the 2 clips holding the pump and remove the pump.....reassemble with new pump in reverse order. Good Luck!! If you have any further question's please feel free to comment. Mike
Oct 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Greasy oil and water is leaking from under the washing machine?
Hello, the good news is the water is coming from the pump and is easily replaced, the bad news is if you are seeing a yellow oily substance your transmission has a leak and will go bad at some stage soon. The question here you need to ask yourself is do you want to spend $35 on a new pump when your going to need to buy a new washer? If so pull the machine out and puch it back so it leans against the wall umder it's own weight. wedge some thing underneath the washer so you can access the bottom without the washer falling on you. you will see the pump attached to the motor which is attached to the transmission. remove the 2 clips and 2 pipes from the pump, remove the pump and replace it, reassemble in reverse order, you should be able to see where the leak came from the pump at the point where the motor shaft connected to the pump. Also while you are under there look at the base of the transmission, you should see some oily residue where the transmission fluid is leaking. Hope this helps! if you have any other questions please feel free to comment again. Good Luck!! Mike
Jul 21, 2009 | Whirlpool LSR5132PQ Top Load Washer
LSQ9649 Whirlpool washer body panel
Remove Phillips screw from rear of console head. (one on each end) Pull console toward you and turn up. With a flat head screwdriver remove clips on top of machine( both ends) pushing down and up. un-do wire for lid switch. Open lid and grab inside lip , Tilt back at 45 degree and walk backwards Cabinet is now removed. More than likely your pump is leaking locted in front of motor with 2 clips,
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water pours out from washer underneath
The most common leak for those washers is from the drain pump a really easy and inexpensive repair. It is located underneath toward the front. To diagnose turn on water to tub fill 1/4 the way, pull out machine about 2 feet, tilt backward,you can use a mirror, I just poke my head under. is should be clearly evident where the leak is. The tools to change the pump it requires a screwdriver and pliers. There are two clips and to hose clamps,remove and replace in reverse order.
Mar 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW5300 SQ Water leaking...Help!!
The water pump is the front and has probably failed.
REMOVE POWER
To access the pump, lift the console by one of three ways.
1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
3. Insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white or gray in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The pump is mounted to the motor with two spring clips. Look at the face of the pump for any signs of melting or blistering. (grey bubbling)
Jun 15, 2008 | Whirlpool WTW5300SQ Top Load Washer
Washing machine Whirlpool Lsn1000pq1
My washer is doing the same thing. I put it up on blocks so I could see where it was leaking from. On mine it was leaking from the pump which a big white piece of plastic in front of the motor. The pump has two hoses connected to it the **** the water out of the tub and pump it out the drain hose. Disconnect the two hose clamps, remove the hoses (use force). There are two spring clips on top and one bottom. I laid mine on it's side to remove them. There two slots one top, one bottom for you to use when prying the clips off. Place screwdriver under clip and between grove and push/pull until they come off. Carry pump to the sink, fill with water and see if it leaks from somewhere, should be obvious.
Jun 01, 2008 | Whirlpool LSN1000LW Top Load Washer
Washer leaking water
need ot pop off the front cover, insert a screwdriver pop top lean back and remove screws holdng front panel on. try running now see where water coming from (id look to pump assy first)
Feb 29, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
21 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
