Question about Dishwashers
How to remove spray arms from Electrolux DX302 Dishwasher?
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
SOURCE: dishwasher not washing dishes properly
i removed the half wash solenoid on the side of the water pump and notice the plastic flap was ajar and getting forced down with water pressure even though half wash hadnt been selected. i removed the plastic flap, replaced solenoid and bottom spray arm works fine now. we never use the half wash cycle so it was a good result for us.thanks for all your help. regards rob
Posted on Nov 26, 2008
SOURCE: Electrolux DX302 Dishwasher power button wont stay on
I rang Electrolux and have ordered a new switch....
Posted on Jan 14, 2009
SOURCE: Can't remove lower spray arm
the nut screws off counter clock wise.
Posted on Mar 18, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Yes!
Posted on Apr 24, 2009
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
Hi there, I have an ESL424 Electrolux dishwasher and I'm having some problems with it not washing dishes properly. Is there any common reason for this? The problem seems to be more apparent in the top...
first thing is to ensure the top spray arm is turning freely. make sure nothing is blocking it, for example one of them dishwasher fresheners.
also check the holes on both spray arms to ensure they not blocked up, also if you can remove the spray arms and clean them out, also clean out the filter.
i also always susjest putting the upper basket on the highest setting as high plates etc. in the bottom basket can stop spray arm turning
after checking all of the above, put the spray arms in the 12 o clock posistion and turn the dishwasher on, when it starts washing open the door to see if they have moved.
also always use a good quality diswasher tablet, cheaper ones dont always give good wash results.
Jun 25, 2011 | Electrolux 18 in. ESL424 Built-in...
What does the error code 50 relate to for our electrolux dishlex DX302 dishwasher?
Thanks for this information. I was able to follow triburi's instruction and just make sure all the electrical connector is connect properly. It works after i put it all back. I guess i am just lucky one of the connection come lose.
Jun 19, 2011 | Electrolux Dishwashers
Hi I have a Dishlex DX302. After an intense wash it leaves a film of scum / powder on the dishes and sometimes does not wash properly. I have tried using various soaps and also tried to use a dishwasher...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 17, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
Electrolux dishwasher DX302 isn't drying the dishes. What might be wrong?
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Dishwashers
Top spray arm does not rotate, is mechanically
try checking the water holes in the arm, as when they spray out the arm turns. If they are blocked in any way it does not turn, try using a needle to check they are clear.
Aug 07, 2009 | Electrolux Kenmore 24 in. Built-In...
I need a user manual for my Electrolux dishwasher Model DX302
Call Electrolux @ 877-435-3287
Make sure you have your model/ serial # handy
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Jun 20, 2009 | Electrolux Dishwashers
Dishwashers Logo
Top Dishwashers Experts
