Question about Belkin N1 Vision Wireless Router
N1 Vision won't boot up...
I got this Wireless Router since Feb 2008 with no mayor issues so far... it worked fine.
Then, out of the blue, the re-star bar goes to aprox. 20% and re-star on a permanent loop..
If use the re-star botton on the back after 10 seconds, shows this message "download mode..." and freezes..
I have tryed everything and nothing seems to work..
I check on the web and other people has gotten the same problem but nobody seem to have a solution..
Unfortunately I live in Latin America iand no tech support avaliable..
Any advise on how to solve this problem..??
Have you heard of this issue before..??
Thanks in advance for any comments on this problem....
Javier Coll
  • 1 more comment
  • jcoll Jan 05, 2009
    Hello acd..
    Thanks for your prompt reply...
    However, as I mentioned in my post the main problem is that is not possible to reset my router because when I use the reset button in the back of the device, I got a message on the N1 Vision screen "download mode....." and then nothing happens and the router freezes..
    Is there anything else that I can try...???
  • jcoll Jan 08, 2009
    The real problem is that the reset button wouldn't perform as it supposed to be.. so the whole procedure is not possible to apply..
    Thanks anyway...
  • jcoll Jan 09, 2009
    Thanks againg acdr....
    I tryed that before and nothing happened.. even tryed on another PC...
    To be honest, I think that the problem is on the hardware, because everybody who I consuted with on this event, assume that pressing the reset button will bring the router to the factory setting, and that's the root of the problem ..the darn reset botton do not take it to the "factory setings" because the router enters the "download mode..." instead..
    As I understand now after receiving information from Belkin support technitians, it is normal to get this "download mode ..." message on the router screen after pressing the reset button for more than 10 seconds..?? In other words I guess the only real solution would be to try and ask for a replacement but as long as I am living in Latin America and bought it in the States I guess I am screwed.. (pardon the language)..
    Thanks againg for your advise anyway...
I searched for solution for some hours and find only questions, no usable answer.
So I had to start debugging myself.
Router just stopped working one day by itself.
On boot the progress bar goes about 20% and hangs forever.
Screen backlight is wobbling a little.
What I did:
I cracked the router open and found that four of the capacitors were ballooned:
I changed the capacitors(470mF 6,3v or higher - about 1eur total sum.) and the router booted up once as new. Next time same problem - it boots on 20% and hangs.
That was the time I noticed that the screen was wobbling and I tested the router with another power adapter and voila - problem was finally fixed.
So, to fix the problem:
  1. Try with another power adapter.
  2. If that does not help, crack the router open and change those ballooned capacitors:
This is how to crack it open..Behind the sticker there are two screws:
5_17_2012_2_03_21_pm.jpgAfter removing them just crack it gently open. Those hooks are holding it tN1 Vision won't boot up... - 5_17_2012_2_05_17_pm.jpgtp://" alt="5_17_2012_2_05_17_pm.jpg" class="h_mi" />
Good Luck!Kalev
Posted on May 17, 2012
  • 1 Answer are a man...thanks alot, finally I found a solution...thanks once again
Posted on May 30, 2012
  • Shaikh Faisal Jun 01, 2012
    Dear Kalev Bro.
    I opened my Belkin N1 Vision v1021UK model and replaced ballooned capacitors. Also I changed the power adapter but still I am facing the same issue.
    My question is to you that please let me what firmware is in your router? Because mine firmware is 1.00.15 lots of people discuss some other websites about 1.00.15 is not stable. Please try to help me out. :(
  • 1,913 Answers
Reset your router.
reset switch is in bck side of router.
press it for 15seconds.
then clik on link
1 link is right for router.
then username "admin"
or blank
then set dhcp enabled in router settibngs.
then setr your lan card properties as ip auto.
then check .
Posted on Jan 05, 2009
  • kishor khatri
    kishor khatri Jan 09, 2009
    connect it with other power suplly may be earthng problem.
Belkin n1 vision router freeze up. download mode or looping in bootup mode. what next?
Disconct wireless devices...connect to pc via cable...Go to SSID settings... change bandwidth from 20/40mhz to 20mhz only ... rebooting issue will be soloved... link speed will show 65-150 Mbps .. bt dont worry.. u will get the whole bandwidth available .... after that reconnect wireless devices ... it wont reboot by itself ...
Jun 19, 2011 | Belkin N1 Vision Wireless Router
How many pc's, laptop's & printer's can i link up to belkin n1 vision wireless router model f5d8232-4
You can uplink a fairly good number of PCs or laptops with Belkin N1 as it supports high bandwidth. Keep in mind that upon adding every new PC, the overall bandwidth for the other PCs is reduced. If the PCs/ laptops do not require much bandwidth, you can connect / add more PCs to the network.
Generally, I have uplinked upto 10-15 clients to one router and the network worked just fine. It all depends upon the network environment and the bandwidth usage by each client PC. If the PCs are using just email and simple internet browsing (and remain idle for most of the time), you can add more clients to your network as not all the systems consume network resources at the same time.
Hope it helps! Good Luck!
Apr 01, 2011 | Belkin N1 Vision Wireless Router
My wireless doesnt work on my belkin n1 wireless router
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 24, 2010 | Belkin N1 Vision Wireless Router
Slower throughput having gone to talk talk
That is there way of saying they don't want to support that router or don;t want to accept their network is having trouble. If you do get another router and still have the same problems then they have no excuses.
Jun 26, 2010 | Belkin N1 Vision Wireless Router
My belkin N1 vision, keep disconnecting from internet. my landline pc works fine. i am only having the problem when connecting with my laptop. i am using a mac book pro with mac os x latest edition. thanks
My N1 Vision does the same thing, If you turn off the guest account, you should find its ok. Only when this Guest account is on, thats when it disconnects. Hope this helps. John
Oct 03, 2009 | Belkin N1 Vision Wireless Router
Belink F5D8635-4v1 Firmware 1.00.17 Boot Code Version 1.1.5
Firmware 1.00.23 fixes the VPN issue on the f5d8635 series.
Sep 09, 2009 | Belkin N1 Vision Router
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
Belkin N+ modem router (F5D8635) not recognizing Maxtor 1TB HD
I could not find the F5D8635 model but here is the Firmware update page for the N1 Vision Router.
Try updating your firmware.
Jul 03, 2009 | Belkin N1 Vision Wireless Router
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Belkin N1 Vision Wireless Router  Logo
3,049 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
