Question about JVC Televison & Video
No sound on my jvc model lt-40a320 when i plug in my hdmi cable
When i plug in my hdmi cable to the tv from my laptop theres a picture but no sound
4 Suggested Answers
  • 1694 Answers
SOURCE: JVC TV model AV-31BM4 picture cutting in and out randomly
Bad connection inside tuner...replace tuner or repair it ...or
by-pass problem by using yellow red and white A / V inputs
from source box or VCR.................................T.
Posted on Feb 29, 2008
bernardlunda
  • 318 Answers
SOURCE: JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Posted on Apr 30, 2009
  • 541 Answers
SOURCE: I have a VIZIO (HDMI
Unplug the set for about 30 minutes. This will reset the unit hopefully. Thanks for using fixya.
Posted on Jan 21, 2010
Why can't I use the HDMI port on a JVC LT-42E478?
your hdmi is not connected tight or the cable is bad,or it is dirty,use canned air to clean out plug.extend your comp screen to the tv
Jul 14, 2015 | JVC Televison & Video
Laptop will not connect to tv
the tv might not be able or new enough to handle the picture of a laptop or computer check to see if it is able to
Apr 23, 2013 | JVC Televison & Video
I have a JVC LT 32 EX 18 TV. When connecting my laptop over HDMI, playing on a playstation or WII the sound and picture work perfectly. When I want to watch normal TV over cable though the problems start...
If the rear inputs work consider connection for the channels with a box using one of the rear inputs--sounds like a tuner related issue and going to the rear inputs bypasses that.
Nov 07, 2012 | Televison & Video
Can someone please help me get my laptop working through HDMI cable onto TV on a sony VAIO VGN-FW23G. I need to know the process to do this
1. Check the computer for changing output (some computers use <F5>, <F8>, depending on which brand they are. I believe Sony uses <Function><F7> or <F7>).
2. Check what channel the HDMI port is on (e.g. AV1, HDMI1, HDMI2, etc.) - you need to know this if your TV doesn't automatically switch to the new input.
3. Plug the HDMI cable into the TV HDMI cable-in port.
4. Plug the HDMI cable into the laptop HDMI cable-out port.
5. Turn on the computer.
6. Press the <Function><F7> simultaneously ONCE. The screen should flicker and show up on TV.
7. Sometimes you may have to go to "Display Preferences" and select Dual Monitors or external monitor if your computer doesn't do it automatically. Repeat Step 6 after.
** You may have to adjust Display Resolution to 1024 x 768 or lower in order for the TV to work. After it works at a lower display (800 x 600, for example), you can adjust the resolution to the maximum the TV can accept.
Oct 26, 2012 | Fujitsu Computers & Internet
JVC LT-40A320 FLAT PANEL BURN-IN
Change input device to some other you know really works. If problem persists, this may need attention by a qualified technician.
Jul 26, 2012 | JVC Televison & Video
JVC LT-42X579 42 in. LCD TV
If it has more than 1 port try another---If it has component try connection there.
Mar 22, 2012 | JVC LT-42X579 42 in. LCD TV
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
Jan 12, 2009 | JVC AV-36D303 36" TV
Televison & Video Logo
77 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
