Question about Ricoh Aficio CL3500N Laser Printer
Hi i would like to ask aboutthe error message that i have for RICOH aficio CL3500N, the error was REPLACE/SUPPLY....thanks
    Problem Solver:
  • 9 Answers
Have a look at problem ID:
http://www.fixya.com/support/t1129504-replaced_toner_but_keeps_saying_replace
This should help you..
Sophia
Posted on Jan 05, 2009
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
My printer Ricoh aficio cl3500n does not print and all the lights on. Why?
The first step is to turn the machine off and then turn it back on. Do all the lights come right back on, or is it okay until you try to print to it?
If all the lights are on, there should be an error message appearing on the display. It might say out of paper, or out of toner, or a cover open, or it might show a code (such as "sc 501").
What is the code or error message that appears?
Jul 09, 2010 | Ricoh Aficio CL3500N Laser Printer
Error 441 Ricoh Aficio CL3500N Laser printer... what should I do?
Hi
It is EVELOPER MOTOT LOCKED.
I can only gave you a link to look at but it only have the error codes.
http://grou.ps/www_diycopymachines_com/talks/20700
Feb 09, 2010 | Ricoh Aficio CL3500N Laser Printer
Sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Nov 16, 2009 | Ricoh Aficio CL3500N Laser Printer
Purchased new fusing unit for ricoh cl3500n; installed; tried to reset computer by holding escape for 5 seconds; does not clear out error message 'replace fusing unit' ; nothing will print; can not get to...
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
Jul 07, 2009 | Ricoh Aficio CL3500N Laser Printer
Error message replace/ supply
If you open an internet connection and an the top address bar type in the IP address you will see you printer and be able to see the supply that needs changing
Jan 05, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N error code SC581
Q1 - Possibly, I have not seen an SC581 error before. Usually using too much power would give you something like an SC240 error "Power Supply Excessive". So it depends on the extent of the damage. You could also have to replace the main board, motors, etc.
Q2 - You will have to pull back the feeder tray, remove the back panel, there is a cover over the main board and the power supply is below it and fairly easy to get to. But if other components were damaged it could be a much more involved repair.
Jul 24, 2008 | Ricoh Aficio CL3500N Laser Printer
Assembly of Ricoh color laser printer - error message
On the Ricoh 3713 you can do a hard reset by going on the main board toggling dip switch 101-1 on and then off, entering 97, pressing the "aps" key, and then power cycling the printer. Might work similarly on the CL3500N.
Apr 04, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
94 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
